05510 - Valves for engine mount (N144)/(N145): Short circuit
Post03-02-2012, 12:23    Subject: 05510 - Valves for engine mount (N144)/(N145): Short circuit Quote
Address 01: Engine.
Part number SW: 03G 906 016 GD, HW: 03G 906 016 GD.
Component: R4 1.9L EDC 000SG 8957.
Revision: --H02--- Serial Number:
Encoding: 0000071
Operating number: WSC 25372 136 68165
VCID: 6BD0441733F7
"One error found:"
05510 - Valves for engine mount (N144)/(N145): Short circuit to positive.
P1586 - 000 - - - Intermittent.
Environmental conditions:
Error status: 00100000
Error priority: 0
Error frequency: 14
Hello Mr. xxx,
Error message: "> 005510 - Valves for engine mount (N144)/(N145): Short circuit to positive."
The reason is quite simple: One or more engine mounts are electrically adjustable in terms of stiffness/damping.
This means that the engine mount is not a simple "rubber buffer," but rather it is filled with a gel that changes its viscosity under electrical influence.
Depending on the tax rate, the rubber buffer is either hard or soft.
The engine control unit adjusts the stiffness of the engine mounts in idle mode to "soft" in order to dampen engine vibrations as much as possible and decouple them from the rest of the vehicle body.
Under load, it is set to "hard" to prevent excessive motor movement.
The error message indicates that either the wiring to the motor mount is faulty or the motor mount itself (internally) is defective.
After checking the wiring to the engine control unit and ruling out issues like rodent damage, the next step is to replace the engine mount.
Best regards, Rainer Kaufmann.
Translated on 18-07-2026, 19:13.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Mount Valves: Buy Now & Save! Diesel Engine Technology
No new posts Engine Mount Valve Error Code: Questions? Diesel Engine Technology
No new posts Timing belt broken, valves okay? Diesel Engine Technology
No new posts Mazda 626 Valve Repair: 1998, 2.0TD, 66kW Diesel Engine Technology
