T5 Hard Starting: Troubleshooting & Fixes
chriskross
Post13-02-2012, 15:31    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
Hello!
"Today I had a problem where my T5 2.5L PD AXD from 2006 wouldn't start in the morning, even after cranking for a long time. It only started after a while when I tried using starting spray."
I replaced the DFI (Direct Fuel Injection) system about 30,000 km ago.
I've generated some log files; could someone please take a look at them?
"Thank you, Chris."
AXD.CSV
 File name:  AXD.CSV
 File size:  17.34 KB
 Downloaded:  724 times
A6 AFB
A6 BRE DPF
Translated on 30-07-2026, 16:05.
HerrBart
Registered VCDS User
Post13-02-2012, 15:54    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
Have you checked the values from the temperature sensor to see if they are providing reasonable readings?
It's important that the engine is cold.
To test the spark plugs, it would be interesting to know whether ceramic glow plugs are used.
You can identify them by the white or green marking on the spark plugs. You should be able to see this even with the connector unplugged. The ceramic spark plugs have a white marking.
Translated on 30-07-2026, 16:06.
chriskross
Post13-02-2012, 16:35    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
Okay, thanks, I'll check that out.
It's not easy to access the glow plugs on a T5 AXD.
What's slightly concerning is the LL (Longitudinal Load) value of 2.2 on cylinder 1; the other cylinders are quite similar.
A6 AFB
A6 BRE DPF
Translated on 30-07-2026, 16:07.
alevuz
Karma: +32 / -0   Thank you, like it!
Post13-02-2012, 17:30    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
Is the PD unit leaking? The high LL value is very noticeable – it would be very unfortunate and costly!
"That sounds like a good fit. How many kilometers are on the engine?"
Are there any issues with a warm start?
Some people in the Touareg forum are struggling with this issue as well; some have had the units re-sealed, while others need to replace the entire head.
Hopefully, it's just a sensor or the glow plugs!
Sure thing! Please provide the German text you would like me to translate into English. I will only provide the translation without any explanations.
Alevuz.
Touareg V10 TDI (AYH)
Translated on 30-07-2026, 16:08.
chriskross
Post13-02-2012, 18:01    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
120,000 km
There are no problems when the engine is warm; this issue occurred for the first time today, and we experienced temperatures of -18 degrees Celsius today.
A6 AFB
A6 BRE DPF
Translated on 30-07-2026, 16:10.
Post13-02-2012, 19:21    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
Cylinder 1 is at the limit; further monitoring is essential.
The cause of the starting problem is not him, but first, as already mentioned, check the temperatures in measurement block 7. icon_wink.gif This is especially important if the engine is cold.
chriskross
Post13-02-2012, 20:30    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
Can the measured value block (MWb) of the idle speed control actually be used to determine whether the sealing rings of the common rail injectors are functioning correctly, or is that unrelated icon_question.gif?
Thank you, Chris.
A6 AFB
A6 BRE DPF
Translated on 30-07-2026, 16:11.
Post13-02-2012, 21:26    Subject: T5 Hard Starting: Troubleshooting & Fixes Quote
It's an indicator. If everything else were absolutely fine, then it would be a fairly good sign.
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 1.9 TDI: Hard Starting Problems & Fixes Diesel Engine Technology
No new posts A6 TDI: Hard Starting & Grey Smoke - Troubleshooting Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 6: Heavy Steering - Causes & Fixes Transmission, Chassis, Body & Interior
No new posts VAG-COM Adapter: Hard to Find? (For Me) Diesel Engine Technology
