Engine Replacement: Find Engines Compatible with ATJ.
daniel_bf
Registered VCDS User
Post25-02-2012, 10:17    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
Hello!
My friend's car has a problem: the ATJ engine in his Passat 3B (built in 1999) has a hole, and the connecting rod is broken.
Now I'm looking for a replacement engine. Which engines can I install that are plug-and-play?
My local engine rebuilder has an AWX engine lying around (I think it's from Audi). He said that, except for the injectors, it's compatible with the ATJ engine. I can't say for sure whether I absolutely need a new cylinder head yet, because the engine is still complete, and it's currently a bit too cold in our workshop to tinker around.
I hope you can give me some information about which other engines might be compatible.
Daniel
Translated on 25-07-2026, 21:17.
mullemaus
Post25-02-2012, 11:29    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
Translated on 25-07-2026, 21:19.
Post25-02-2012, 11:37    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
daniel_bf
Post25-02-2012, 11:50    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
Okay, I don't want to install a new MSTG (main switching and distribution unit) because that would require repinning and rerouting cables, and I really don't feel like doing that.
What if I take the fuselage of the AWX and the head of the ATJ (if it's still in good condition)? Then, wouldn't we be able to leave the electrical system untouched, or am I mistaken?
Daniel
Karma: +590 / -0   Thank you, like it!
Post25-02-2012, 22:26    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
Hi!
Ich hab noch einen def. Loitering around ATJ.
The ZR is torn.
The engine has not been opened yet.
Wenn Du ev. Are you interested?
Get in touch sometime.
Then I can discuss this with the owner of the engine.
whether he approves it.
Translated on 25-07-2026, 21:20.
daniel_bf
Post26-02-2012, 11:18    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
@SteffenViewing profile: Steffen G
I would certainly be interested.
I need to take a look at my friend's engine head now to see if the head or valves have been damaged.
If the timing belt breaks, you can also forget about the engine head.
But please inquire about those details as well (including mileage and year of manufacture), and let me know what you find out.
Daniel
Translated on 25-07-2026, 21:22.
Post26-02-2012, 13:54    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
If necessary, you can attach the PD elements and charger from the old engine to the AWX; the effort is quite manageable. And you don't have to remove any ZK components either. icon_wink.gif
Translated on 25-07-2026, 21:23.
Post26-02-2012, 14:14    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
The compression ratio also differs between the ATJ and AWX models.
Post26-02-2012, 15:20    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
TDI-GTI-4-Motion wrote:
The compression ratio is different between ATJ and AWX.
Unfortunately, the engine is not exactly the same as the previous one.
Post26-02-2012, 15:31    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
That's what I meant. It will probably run fine like this, but I would still prefer a genuine ATJ engine. icon_wink.gif
Translated on 25-07-2026, 21:24.
Post27-02-2012, 21:34    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
@daniel:
So, the engine is essentially cleared for use.
Is this an ATJ engine, with serial number 29970?
It was installed in a Passat Variant all-wheel drive vehicle, manufactured in the year 2000.
The car has a mileage of 185,000 km. The car belongs to my neighbor, and it has always been well-maintained, including regular oil changes with the correct type of oil.
There were absolutely no problems until I changed the timing belt... icon_cry.gif
The engine is currently stored in a container at my place, like when it was removed, and has been there for about 1.5 years.
The bare metal parts are already a bit rusty, for example where the water pump is located. However, that shouldn't be a problem.
If you're interested, I can try to figure it out the day after tomorrow.
and check if the cylinder heads are rusted, and see if the engine still turns over.
and what damage he sustained from the crack in the rear differential. Otherwise, we'll just see if everything else is okay.
Translated on 25-07-2026, 21:26.
daniel_bf
Post28-02-2012, 21:16    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
Okay, I'll pass this along to my friend and then let him know if he's interested, especially considering the mileage.
I'll let you know if you need to take the thing apart. What is your price range?
Daniel
Translated on 25-07-2026, 21:27.
Deus Violentia
Post28-02-2012, 22:07    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
@SteffenViewing profile: Steffen: For reasons known to you ^^, please take some pictures! Thank you!
BKD GRF
AHF EBF
Translated on 25-07-2026, 21:28.
Post29-02-2012, 21:18    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
daniel_bf wrote:
What is the price range primarily?
Best regards, Daniel
Hi!
The used engine that I installed cost 900 euros.
Okay, assuming the pistons and cylinders are all fine, and everything else is okay too...
I think that around 200 euros would be a reasonable price for just the engine block without the cylinder head.
The risk is inherent.
and I also don't have any experience with what happens after a timing chain rupture in that engine.
I wonder how long it will actually last...
Shipping will be an additional cost, we'll have to see about that.
on disposable pallets, with freight forwarder.
or would you possibly pick it up yourself?
Or the unfortunate vehicle owner, depending on where you live.
Translated on 25-07-2026, 21:29.
daniel_bf
Post03-03-2012, 23:09    Subject: Engine Replacement: Find Engines Compatible with ATJ. Quote
Thank you for your offer, but the risk is too high for my friend with your engine. Also, would the AJM engine also fit in place of the ATJ? What's the difference between those two engines?
Translated on 25-07-2026, 21:31.
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Which exhaust manifold fits? Diesel Engine Technology
No new posts Garrett 028145702: Which one fits? Diesel Engine Technology
No new posts Bei Turboschaden auch gleich neuen Kat ? Diesel Engine Technology
No new posts Vag-Com, alter Orginaladapter: Passt der auch beim neuen A3 Diesel Engine Technology
