Air Mass Flow Too Low in Regeneration Mode
alphagolf
Post14-02-2012, 19:28    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Hello everyone, and good evening to you all.
A little while ago, the engine check light came on in my Passat B6 (type 3C) with a 2.0L TDI engine and engine code BMR, and it has been constantly illuminated ever since.
So, I quickly connected VCDS and, just for a quick check, I read out the following:
Dienstag,14,Februar,2012,18:05:39:21274
VCDS Version: DRV 10.6.4
Adresse 01: Motorelektronik Labeldatei: DRV\03G-906-018-BMN.lbl
Steuergerät-Teilenummer: 03G 906 018 EM HW: 03G 906 018 EM
Bauteil und/oder Version: R4 2.0l PPD1.2 G 4369
Codierung: 0000078
1 Fehler gefunden:
005214 - Luftmassendurchsatz im Regenerationsbetrieb zu klein
P145E - 006 - Kurzschluß nach Plus - Sporadisch
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 5
Fehlerhäufigkeit: 1
Verlernzähler: 40
Kilometerstand: 188153 km
Zeitangabe: 0
Datum: 2012.02.14
Zeit: 17:16:56
Drehzahl: 1728 /min
Drehmoment: 40.0 Nm
Geschwindigkeit: 55.0 km/h
0.00 %
23.01 %
Luftmasse/Hub: 327.0 mg/H
Luftmasse/Hub: 583.1 mg/H
Please don't get angry with me, but I know you always want a complete scan right away. However, due to time constraints, I only quickly read out the relevant control unit earlier. I can gladly provide a complete scan tomorrow if you'd like.
Do you have any idea what the cause of this error message is and what it means?
Is my particulate filter possibly full?
Thank you in advance!
Translated on 01-09-2026, 3:56.
Post14-02-2012, 19:44    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
This can have several causes. What's peculiar in your case is that the error message reads "Short circuit to positive."
Therefore, I would first check the mass airflow sensor and its wiring.
If the engine control unit (ECU) has an original data set, meaning it is not tuned:
- Then, check if the actual charging pressure reaches the target charging pressure (MWB 11).
- If not, check the vacuum hoses and also look for any possible leaks, such as those that might occur at the swirl flap adjustment unit.
- Check the differential pressure of the particulate filter (see sections 68 and following in the workshop manual).
- Are the differential pressures plausible? For example, 0 mbar with the engine idling.
- Is the throttle valve and EGR system functional? Unfortunately, they often fail intermittently and gradually (due to the plastic gears wearing out).
Translated on 01-09-2026, 3:59.
alphagolf
Post15-02-2012, 19:20    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Good evening, everyone.
Okay, I'll quickly send you the complete scan today. There's even another error that has appeared. However, I believe the problem can now be narrowed down to the fact that this morning, the orange warning light for the particulate filter also came on. After a restart, the light was off again. When the light was on, the engine was running much higher than normal, and the engine seemed to have very little power. Earlier, I read the ash mass (MWB 068), and the value was 59.79. I've read that it's time for a replacement when it reaches 60. So, it seems like a new filter needs to be installed icon_rolleyes.gif.
I hope it's not too expensive.
Mittwoch,15,Februar,2012,13:37:53:21274
Datenstand: 20110418
Fahrzeugtyp: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 69 72
77
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ7E0XXXXX Kilometerstand: 189340km
00-Lenkwinkelsensor -- Status: i.O. 0000
01-Motorelektronik -- Status: Fehler 0010
02-Getriebe -- Status: i.O. 0000
42-TĂźrelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
52-TĂźrelektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
62-TĂźrelektr. hi. li. -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
72-TĂźrelektr. hi. re. -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Teilenummer SW: 03G 906 018 EM HW: 03G 906 018 EM
Bauteil: R4 2.0l PPD1.2 G 4369
Revision: --H22--- Seriennummer: VWZCZ000000000
Codierung: 0000078
Betriebsnr.: WSC 32247 134 83818
VCID: 74C88B886E2B
2 Fehlercodes gefunden:
001139 - Drucksensor 1 fĂźr Abgas (G450): Kurzschluss nach Plus
P0473 - 006 - Kurzschluß nach Plus - Sporadisch - Warnleuchte EIN
Fehlerstatus: 10100001
Fehlerpriorität: 1
Fehlerhäufigkeit: 254
Verlernzähler: 40
Kilometerstand: 188717 km
Zeitangabe: 0
Datum: 2012.02.14
Zeit: 23:29:18
Drehzahl: 1856 /min
Drehmoment: 88.0 Nm
Geschwindigkeit: 0.0 km/h
Spannung: 14.01 V
Kilometerstand: 30 km
Text: 176 C
Druck: 1576.2 mbar
001137 - Drucksensor 1 fĂźr Abgas (G450): unplausibles Signal
P0471 - 006 - Kurzschluß nach Plus - Sporadisch - Warnleuchte EIN
Fehlerpriorität: 1
Fehlerhäufigkeit: 7
Verlernzähler: 40
Kilometerstand: 0 km
Zeitangabe: 0
Drehzahl: 0 /min
Drehmoment: 144.0 Nm
Druck: 255.6 mbar
Text: -84 mbar
Text: 200 C
Temperatur: 3.0°C
Readiness: Nicht VerfĂźgbar
Adresse 02: Getriebe Labeldatei: DRV\02E-300-0xx.lbl
Teilenummer SW: 02E 300 043 E HW: 02E 927 770 AE
Bauteil: GSG DSG 070 1156
Revision: 04507000 Seriennummer: 00000606060895
Codierung: 0000020
Betriebsnr.: WSC 44551 111 44551
VCID: 160C91005817
Adresse 03: Bremsenelektronik Labeldatei: DRV\3C0-614-095-C2.lbl
Teilenummer SW: 3C0 614 109 A HW: 3C0 614 109 A
Bauteil: ESP 440 C4 H018 0001
Revision: H018 Seriennummer: 0776482048
Codierung: 0032061
Betriebsnr.: WSC 32247 134 80743
VCID: 1C188328A63B
Adresse 08: Klima-/Heizungsel. Labeldatei: DRV\3C0-907-044.lbl
Teilenummer SW: 3C0 907 044 AG HW: 3C0 907 044 AG
Bauteil: ClimatronicPQ46 050 0505
Revision: 00050005 Seriennummer: 00000000000000
VCID: 66ECE1C028F7
Adresse 09: Zentralelektrik Labeldatei: DRV\3C0-937-049-23-H.lbl
Teilenummer SW: 3C0 937 049 J HW: 3C0 937 049 J
Bauteil: Bordnetz-SG H37 1301
Revision: 00H37000 Seriennummer: 00000005884797
Codierung: E70A8E4700281A000000000016000000000B5C415C0000
Betriebsnr.: WSC 05311 000 00000
VCID: 30404798DAB3
Teilenummer: 3C1 955 119
Bauteil: Wischer VW461 012 0503
Codierung: 00063445
Teilenummer: 1K0 955 559 AE
Bauteil: RLS 260606 014 1201
Codierung: 00405541
Adresse 15: Airbag Labeldatei: DRV\3C0-909-605.lbl
Teilenummer SW: 3C0 909 605 K HW: 3C0 909 605 K
Bauteil: 0Q AIRBAG VW8R 029 2521
Revision: 10029000 Seriennummer: 003A3PCS2300
Codierung: 0012369
VCID: 2E7C59E0C087
Adresse 16: Lenkradelektronik Labeldatei: DRV\3C0-953-549-SW20.lbl
Teilenummer SW: 3C0 953 549 E HW: 3C0 953 549 E
Bauteil: J0527 0015
Revision: 00007000 Seriennummer: 3C9953507P
Codierung: 0001212
VCID: 2E7C59E0C087
Teilenummer: XXXXXXXXXXX
Bauteil: E0221 002 0010
Adresse 17: Schalttafeleinsatz Labeldatei: DRV\3C0-920-xxx-17.lbl
Teilenummer SW: 3C0 920 871 HW: 3C0 920 871
Bauteil: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Seriennummer: 00000000000000
Codierung: 0007005
Betriebsnr.: WSC 70831 134 62356
VCID: E1E672DC41D9
Adresse 19: Diagnoseinterface Labeldatei: 3C0-907-530.lbl
Teilenummer SW: 3C0 907 530 C HW: 3C0 907 951 A
Bauteil: Gateway 007 0040
Revision: 00007000 Seriennummer: 0700C06627132C
Codierung: 7FFD8C04C62002
VCID: 2166B2DC8159
Adresse 25: Wegfahrsperre Labeldatei: DRV\3C0-959-433-25.lbl
Teilenummer SW: 3C0 959 433 R HW: 3C0 959 433 R
Bauteil: IMMO 042 0383
Revision: 00042000 Seriennummer: VWZCZ000000000
Betriebsnr.: WSC 131071 1023 2097151
VCID: 39567ABC09C9
Teilenummer: 3C0 905 861 F
Bauteil: ELV 026 0380
3C0905861F ELV 026 0380
Adresse 42: TĂźrelektr. Fahrer Labeldatei: DRV\1K0-959-701-MIN3.lbl
Teilenummer SW: 1K0 959 701 P HW: 1K0 959 793 L
Bauteil: J386 TUER-SG FT 1123
Revision: 12006001 Seriennummer: 00000527968628
Codierung: 0000245
VCID: 3B5A60B403F5
Adresse 44: Lenkhilfe Labeldatei: DRV\1Kx-909-14x-44.clb
Teilenummer: 1K1 909 144 L
Bauteil: EPS_ZFLS Kl.136 H07 1806
Betriebsnr.: WSC 32247 134 51285
VCID: 34484B882EAB
Adresse 46: Komfortsystem Labeldatei: DRV\3C0-959-433-46.clb
Bauteil: KSG PQ46 ELV 042 0472
Codierung: 1991020051034E763004941570084F0E707800
VCID: 39567ABC09C9
Teilenummer: 1K0 951 605 B
Bauteil: LIN BACKUP HORN H07 7001
Bauteil: NGS n.mounted
Bauteil: IRUE n.mounted
Adresse 52: TĂźrelektr. Beifahr. Labeldatei: DRV\1K0-959-702-MIN3.lbl
Teilenummer SW: 1K0 959 702 P HW: 1K0 959 792 L
Bauteil: J387 TUER-SG BT 1123
Revision: 12006001 Seriennummer: 00000028668628
Codierung: 0000244
VCID: 3C5863A806FB
Adresse 53: Feststellbremse Labeldatei: DRV\3C0-907-801-53.lbl
Teilenummer SW: 3C0 907 801 B HW: 3C0 907 801 B
Bauteil: EPB VC8HC001 013 0001
Revision: 013
Codierung: 0000012
VCID: 2166B2DC8159
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\5M0-907-357-V1.lbl
Teilenummer SW: 5M0 907 357 HW: 5M0 907 357
Bauteil: AFS-Steuergeraet 0003
Revision: H09 Seriennummer:
Codierung: 0000001
VCID: F1C6029C9139
Teilenummer: 7L6 941 329
Bauteil: AFS-Lst.-Modul l X018
Codierung: 00000035
Teilenummer: 7L6 941 330
Bauteil: AFS-Lst.-Modul r X018
Codierung: 00000035
Adresse 56: Radio Labeldatei: DRV\1K0-035-1xx-56.lbl
Teilenummer SW: 3C0 035 195 B HW: 3C0 035 195 B
Bauteil: Radio PM6 009 0015
Revision: 00009000 Seriennummer: VWZ5Z7F1018911
Codierung: 0042400
Betriebsnr.: WSC 05311 000 08193
VCID: 1F62B424B72D
Adresse 62: TĂźrelektr. hi. li. Labeldatei: DRV\1K0-959-703-GEN3.lbl
Teilenummer SW: 1K0 959 703 P HW: 1K0 959 795 G
Bauteil: J388 TUER-SG HL 1114
Revision: 11004001 Seriennummer: 00000000274963
Codierung: 0000208
VCID: 3D5E6EAC1DE1
Adresse 69: Anhänger Labeldatei: DRV\1K0-907-383-MY7.lbl
Teilenummer SW: 1K0 907 383 HW: 1K0 907 383
Bauteil: ANHAENGERELEKTR 003 0020
Codierung: 0000001
Betriebsnr.: WSC 05314 000 00000
VCID: EAF415F0BCEF
Adresse 72: TĂźrelektr. hi. re. Labeldatei: DRV\1K0-959-704-GEN3.lbl
Teilenummer SW: 1K0 959 704 P HW: 1K0 959 794 G
Bauteil: J389 TUER-SG HR 1114
Revision: 11004001 Seriennummer: 00000000276955
Codierung: 0000208
VCID: 3E5C69A010E7
Adresse 77: Telefon Labeldatei: DRV\3C0-035-729.lbl
Teilenummer SW: 3C0 035 729 E HW: 3C0 035 729 E
Bauteil: Telefon 6009
Revision: 00009000 Seriennummer: 0000000757793
Codierung: 0016023
VCID: 256EA6CC9571
Translated on 01-09-2026, 4:01.
Post15-02-2012, 19:28    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 01-09-2026, 4:02.
alphagolf
Post15-02-2012, 19:41    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Okay, thank you for the link. It's very well summarized there!
I think I could actually do the installation myself, although it probably wouldn't take more than 1-2 hours of work in the workshop.
However, when it comes to cleaning, I would probably prefer to hire professionals for the job. I've already found some suitable companies through an online search.
However, they also cost upwards of 400 EUR. My question is, what can they possibly do better than I can with a garden hose? Are there noticeable differences between using them and using a hose? Or can I also achieve a cleaning level of up to 98% with a garden hose? If I only manage to clean 40 or 50% with a garden hose, I definitely won't buy one of those.
Translated on 01-09-2026, 4:03.
alphagolf
Post18-02-2012, 15:05    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Okay, unfortunately, I now have a few more errors in the error memory, and slowly but surely, all the warning lights are coming on in my instrument cluster icon_confused.gif.
(Check Engine light is on, glow plug indicator is flashing, and the DPF lamp is illuminated.)
Here is the complete scan:
Freitag,17,Februar,2012,19:10:32:21274
Fahrzeugtyp: 3C0
77
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ7E0XXXXX Kilometerstand: 189470km
Codierung: 0000078
VCID: 74C88B886E2B
3 Fehlercodes gefunden:
Fehlerstatus: 00010001
Fehlerpriorität: 1
Fehlerhäufigkeit: 2
Verlernzähler: 40
Kilometerstand: 189357 km
Zeitangabe: 0
Datum: 2012.02.14
Zeit: 23:14:57
Drehzahl: 0 /min
Druck: 340.8 mbar
Text: -84 mbar
Text: 448 C
Temperatur: 1.5°C
Fehlerpriorität: 1
Fehlerhäufigkeit: 166
Verlernzähler: 40
Kilometerstand: 189368 km
Zeitangabe: 0
Datum: 2012.02.14
Zeit: 23:31:02
Drehzahl: 1856 /min
Drehmoment: 104.0 Nm
Spannung: 12.20 V
Kilometerstand: 50 km
Text: 140 C
Druck: 979.8 mbar
008194 - Partikelfilter Bank 1: Fehlfunktion
P2002 - 006 - Kurzschluß nach Plus - Warnleuchte EIN
Fehlerstatus: 11100001
Fehlerpriorität: 5
Fehlerhäufigkeit: 4
Verlernzähler: 40
Kilometerstand: 189450 km
Zeitangabe: 0
Datum: 2012.02.16
Zeit: 14:14:01
Drehzahl: 0 /min
Drehmoment: 0.0 Nm
(keine Einheit): 4.0
Druck: 0.0 mbar
Lambda: 19.8 %
Zeit: 4892.2 s
Codierung: 0000020
VCID: 160C91005817
Codierung: 0032061
VCID: 1C188328A63B
VCID: 66ECE1C028F7
VCID: 30404798DAB3
Codierung: 00063445
Codierung: 00405541
Codierung: 0012369
VCID: 2E7C59E0C087
Bauteil: J0527 0015
Codierung: 0001212
VCID: 2E7C59E0C087
Codierung: 0007005
VCID: E1E672DC41D9
VCID: 2166B2DC8159
VCID: 39567ABC09C9
Codierung: 0000245
VCID: 3B5A60B403F5
VCID: 34484B882EAB
VCID: 39567ABC09C9
Codierung: 0000244
VCID: 3C5863A806FB
Revision: 013
Codierung: 0000012
VCID: 2166B2DC8159
Codierung: 0000001
VCID: F1C6029C9139
Codierung: 00000035
Codierung: 00000035
Codierung: 0042400
VCID: 1F62B424B72D
Codierung: 0000208
VCID: 3D5E6EAC1DE1
Codierung: 0000001
VCID: EAF415F0BCEF
Codierung: 0000208
VCID: 3E5C69A010E7
Codierung: 0016023
VCID: 256EA6CC9571
Regarding the first issue, I will now replace the differential pressure sensor G450. I believe I still have the very first version installed, with the part number 03G609051A, and apparently it was already very prone to failure (according to information found online).
But I'm really starting to be surprised by these other issues. Could this be related to damage caused by martens?
Translated on 01-09-2026, 4:04.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post19-02-2012, 16:17    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
As long as the engine can't "breathe" freely, the registered errors are sure to remain.
reflexsilber met.
Translated on 01-09-2026, 4:05.
wingmaster
Avatar-wingmaster
Post21-02-2012, 20:31    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Your particulate filter is clogged and needs to be cleaned or replaced.
"Don't replace any sensors or anything else. The cause is a clogged filter. I've seen these exact same errors multiple times in VW and Audi vehicles."
Translated on 01-09-2026, 4:06.
voodoo
Post22-02-2012, 11:26    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Same here... I experienced the same thing.
When my fuel filter was clogged (186,000 km), various inexplicable error messages suddenly appeared.
If you don't replace the filter soon, you're going to have a lot more problems.
For example, with the turbocharger. It's not designed to operate under such high pressure for extended periods.
So, you either need to rinse the filter or buy a new one.
alphagolf
Post25-02-2012, 19:42    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Following your tips and advice, my vehicle has now been out of service for about a week! I finally found the DPF in my BMR after some searching, but unfortunately, the removal is much more difficult than described in the link above. I couldn't access it. For this reason, I've now taken my vehicle to a specialized workshop. They even had to lower the front axle to reach the filter. However, it seems that some sensors were also defective, so they had to order a new 'probe.' The removed filter is currently being cleaned by another company, and the car will remain out of service until then. After that, the differential pressure sensor will still be replaced, as the mechanic said it's providing significantly different readings.
Since a new filter costs a good 1800 euros, which is not exactly cheap, even this effort is worthwhile in comparison.
My vehicle will likely need to remain at the repair shop until the end of next week for the cleaned filter to be installed. Afterwards, I will report back on what was done, what was replaced, and whether all the errors have been resolved.
Have a nice weekend until then!
Translated on 01-09-2026, 4:08.
mullemaus
Post25-02-2012, 22:16    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
, unfortunately, the process is quite different from what is described in the link above (namely, it is obviously much more difficult). In that case, it was even necessary to lower the front axle to access the filter.
That definitely works WITHOUT lowering the axis!! icon_rolleyes.gif icon_rolleyes.gif icon_confused.gif
Translated on 01-09-2026, 4:10.
alphagolf
Post01-03-2012, 21:00    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
I have no idea whether the mechanic needs to lower the axle or if he can manage without it. If the specified time estimates for the removal include that step, then the mechanic might only need 10 minutes for the removal, but I would still have to pay for the estimated hours. It's frustrating, but there's nothing I can do to change it.
The DPF has now been cleaned. A temperature sensor on the filter was also replaced because it was apparently defective. Well, with this car, I'm not really surprised by anything anymore icon_confused.gif.
Now, the car has been in the workshop again for 10 days, and that brings the total workshop time in the last 12 months to a whopping 6 weeks. It's probably best if I stop counting and get a monthly subscription from a car rental company icon_rolleyes.gif.
EDIT: After replacing and calibrating the differential pressure sensor, I still unfortunately have a current error in the error memory. However, I have opened a new thread about this because I'm not sure if it's related. Here's the link: https://community.dieselschrauber.org/en/viewtopic.php?t=26284
Translated on 01-09-2026, 4:11.
alphagolf
Post03-03-2012, 16:50    Subject: Particulate Filter Error 08194: Bank 1 Malfunction Quote
Good day everyone icon_smile.gif.
A few weeks ago, I reached out to you, and I also received various helpful suggestions and feedback regarding my request. Thank you very much for that!
I had the DPF removed and cleaned by a workshop, as mentioned in the thread above. At the same time, a temperature sensor 'after the particulate filter' with part number 03L906088CE was replaced. Today, I installed a new differential pressure sensor with part number 076906051A and calibrated it as follows:
The new differential pressure sensor can then be programmed using VCDS:
- Ignition ON, engine OFF.
- VCDS -> 01 - Engine -> Coding II - 11
Enter the login code from the VCDS tooltip (adjustment for exhaust pressure sensor 1 - G450).
- Ignition OFF.
This process resets the learning values for the new differential pressure sensor.
Previously, a differential pressure sensor with the part number TN 03G906051A was installed.
Now, the new values are:
12:25:43 Block 067: Partikelfilter (Abgaswerte I)
0.00 Druckdifferenz Partikelfilter
0.00 Offset Differenzdruck
Now, the following error is still present in the error memory of the control module:
Samstag,03,März,2012,12:33:49:21274
VCDS Version: DRV 11.11.2
Datenstand: 20120130
Adresse 01: Motorelektronik Labeldatei: DRV\03G-906-018-BMN.clb
Codierung: 0000078
Betriebsnummer: WSC 80093 222 69422
VCID: 74C88B8817A00E3
1 Fehler gefunden:
P2002 - 006 - Fehlfunktion
Freeze Frame:
Fehlerstatus: 11010001
Fehlerpriorität: 5
Fehlerhäufigkeit: 2
Verlernzähler: 40
Kilometerstand: 189616 km
Zeitangabe: 0
Datum: 2012.03.03
Zeit: 12:11:27
Freeze Frame:
Drehzahl: 0 /min
Drehmoment: 0.0 Nm
Druck: 0.0 mbar
Lambda: 19.8 %
Zeit: 4892.2 s
And now, here's the complete scan:
Samstag,03,März,2012,12:29:37:21274
Fahrzeugtyp: 3C0
77
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ7E0XXXXX Kilometerstand: 189610km
46-Komfortsystem -- Status: Fehler 0010
56-Radio -- Status: Fehler 0010
Codierung: 0000078
Betriebsnr.: WSC 80093 222 69422
1 Fehler gefunden:
Freeze Frame:
Fehlerpriorität: 5
Fehlerhäufigkeit: 1
Verlernzähler: 40
Zeitangabe: 0
Datum: 2012.03.03
Zeit: 12:11:27
Freeze Frame:
Drehzahl: 0 /min
Drehmoment: 0.0 Nm
Druck: 0.0 mbar
Lambda: 19.8 %
Zeit: 4892.2 s
Codierung: 0000020
VCID: 160C9100219CBC3
Adresse 03: Bremsenelektronik Labeldatei: DRV\3C0-614-095-C2.clb
Codierung: 0032061
VCID: 1C188328DFB0E63
VCID: 66ECE1C0517CEC3
Codierung: E70A8E4700281A000002000016000000000B5C415C0000
VCID: 30404798A338723
Subsystem 1 - Teilenummer: 3C1 955 119 Labeldatei: DRV\1KX-955-119.CLB
Codierung: 00063445
Subsystem 2 - Teilenummer: 1K0 955 559 AE Labeldatei: DRV\1K0-955-559-AF.CLB
Codierung: 00405541
Codierung: 0012369
VCID: 2E7C59E0B90C643
Bauteil: J0527 0015
Codierung: 0001212
Codierung: 0007005
VCID: E1E672DC38520BB
VCID: 2166B2DCF8D2CBB
VCID: 39567ABC7042B3B
Codierung: 0000245
VCID: 3B5A60B47A7E81B
VCID: 34484B8857204E3
Codierung: 1991020051034E763002941570084F0E707800
1 Fehler gefunden:
01134 - Alarmhorn (H12)
000 - -
Freeze Frame:
Fehlerstatus: 01100000
Fehlerpriorität: 4
Fehlerhäufigkeit: 1
Verlernzähler: 76
Kilometerstand: 189548 km
Zeitangabe: 0
Datum: 2012.03.02
Zeit: 01:11:56
Codierung: 0000244
VCID: 3C5863A87F70863
Adresse 53: Feststellbremse Labeldatei: DRV\3C0-907-801-53.clb
Revision: 013
Codierung: 0000012
Codierung: 0000001
VCID: F1C6029CE8B2BBB
Subsystem 1 - Teilenummer: 7L6 941 329
Codierung: 00000035
Subsystem 2 - Teilenummer: 7L6 941 330
Codierung: 00000035
Codierung: 0042400
VCID: 1F62B424CEA6FDB
1 Fehler gefunden:
00856 - Antenne; am Radio
011 - Unterbrechung
Freeze Frame:
Fehlerstatus: 01101011
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 76
Zeitangabe: 0
Datum: 2012.03.01
Zeit: 17:26:31
Codierung: 0000208
VCID: 3D5E6EAC646A8FB
Codierung: 0000001
VCID: EAF415F0C564483
Codierung: 0000208
VCID: 3E5C69A0696C943
Codierung: 0016023
VCID: 256EA6CCECFA27B
The following 3 lights in the instrument cluster remain illuminated immediately after starting the engine:
- MIL
- Exhaust system
- Preheating glow plug (flashing)
The vehicle is running in a limp mode and barely responds to the accelerator, or accelerates like a Passat with only 60 horsepower. On the highway, with a lot of effort and a tailwind, you can barely reach 110 km/h. Additionally, the DSG transmission shifts much later than usual and maintains the engine speed at a higher level. When stationary, the engine speed seems to be within the normal range.
The workshop that removed and installed the cleaned DPF reset the ash mass to 0g. The current reading from the diagnostic tool (MWB 068) is now 0.01g. The distance traveled since the last regeneration is 184 kilometers. Of that distance, I drove approximately 80 kilometers from the workshop to my home. The number of failed regenerations is currently 4.
I actually only brought the vehicle to this workshop for the DPF cleaning.
Do you have any ideas about what else might need to be done, or what could be broken?
P.S.: The filter was measured externally for back pressure before and after the measurement. If these values are needed, I would be happy to provide them.
Translated on 01-09-2026, 4:15.
Post03-03-2012, 16:53    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
I've added your answer to the relevant topic; it doesn't really make sense to start a new one for feedback. icon_wink.gif
What differential pressure does the new sensor indicate when the engine is idling, and does the value change when you accelerate?
Translated on 01-09-2026, 4:19.
alphagolf
Post03-03-2012, 19:16    Subject: Air Mass Flow Too Low in Regeneration Mode Quote
Hello Rainer,
Thank you for moving it; if you think it improves clarity less, I would still prefer it that way icon_biggrin.gif.
Unfortunately, I haven't been able to implement your suggestion yet, as I first had to fully charge my laptop battery for that process.
At the same time, I wanted to inquire whether it makes sense to follow up on the issue of emergency regeneration from this particular source http://wiki.ross-tech.com/wiki/index.php/18434/P2002/008194?
EDIT: I have now, at my own risk, followed the instructions on the website mentioned above and performed a forced regeneration. Previously, the load factor was over 53%.
After a while (at the end of the forced regeneration), it was at 18.73%. After some time and approximately 20 kilometers, I started another forced regeneration using VCDS (unfortunately, I couldn't log everything because my laptop battery is too weak). In any case, I brought the loading coefficient down to 0.0% during the second regeneration phase. First, the emissions control light went out, then the flashing glow plug symbol went out, and finally, after the forced regeneration was complete, the DPF light also went out. The ash mass in module byte 068 is now 0.03g. The loading coefficient is at 0.0%, and there are no more errors stored in the control module icon_biggrin.gif.
All the lights in the instrument cluster are off and remain off!
Here are the remaining values for Rainer:
19:22:37 Block 067: Partikelfilter (Abgaswerte I)
183,3°C Temperatur vor Abgasturbolader
254,8°C Temperatur im Partikelfilter
4.90 Druckdifferenz Partikelfilter
0.0 Offset Differenzdruck
I read these values after the regeneration cycle was completed, while the engine was idling, in my garage.
If anyone is interested, I also saved the complete scan data at the end of the trip.
Thank you to the developers and everyone involved for this top-quality software called VCDS!!!
The workshop wanted to install a new oxygen sensor for me because of this error, and it would have cost almost 200 EUR.
Translated on 01-09-2026, 4:22.
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Mass Sensor: TDI vs. 1.8T Comparison Data Diesel Engine Technology
No new posts NOx signal too low Diesel Engine Technology
No new posts AGR throughput too small Diesel Engine Technology
No new posts P0237 Audi A3 2.0 TDI: Low Signal Diesel Engine Technology
