chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
07-02-2013, 16:51 Subject: Passat 2009 power loss |
Hi!
I'm having a problem with a Passat 2.0 CBAB CR.
Intermittent power loss with MIL (Malfunction Indicator Lamp) illuminated, speed limited to 100 km/h. The problem disappears after turning the engine off and restarting. Occasionally, the glow plug indicator also starts flashing.
Thursday, February 7, 2013, 1:48:54 PM: 12188
VCDS Version: RKS 11.11.5
Data as of: 20130111.
Address 01: Engine
Label file: RKS\03L-906-022-CBA.clb
Control unit part number: 03L 906 022 BL Hardware: 03L 907 309
Part and/or version: R4 2.0L EDC G001SG 6221.
Encoding: 0000072
Operating number: WSC 00263 219 174313
VCID: 70EB8039638C8F98D1C
"1 error found:"
000665 - Charge pressure control.
P0299 - 000 - Control limit exceeded - Intermittent - Warning light ON.
Environmental conditions:
Error status: 10100000
Error priority: 2
Error frequency: 4
Mileage: 143,483 km
Time: 0
Date: 2013.02.07
Time: 11:26:54
Speed: 2369 RPM
Speed: 101.0 km/h
Last: 52.5%
Pressure: 2070.6 mbar
Pressure: 1611.6 mbar.
Lambda: 97.8%
Lambda: 45.0%
Readiness: 1 1 0 0 0
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Address 01: Fault codes cleared.
Vehicle type: 3C0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
Vehicle Identification Number: WVWZZZ3CZ9E01XXXX
Mileage: 143,640 km
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
10-Parking assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000
53-Parking brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine (CBA)
Part number SW: 03L 906 022 BL, HW: 03L 907 309.
Part: R4 2.0L EDC G001SG 6221
Revision: 13H01--- Serial Number: VWZCZ000000000
Encoding: 0000072
No error codes found.
Readiness: 0 0 0 0 0
I tried testing the vacuum sensor on the turbocharger using a vacuum pump, but I couldn't generate any vacuum.
There is also an electrical component on the vacuum chamber. Valve, I'm seeing this for the first time.
Could it be that the container needs to be electrically controlled in order to create a vacuum inside?
Best regards, Chris.
A6 AFB
A6 BRE DPF
Translated on 07-07-2026, 7:23.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
07-02-2013, 17:19 Subject: Passat 2009 power loss |
Quote: | I tried to check the vacuum sensor on the turbo using a vacuum pump, but I couldn't create any vacuum.
There is also an electrical component on the vacuum chamber. Valve, I'm seeing that for the first time. |
Error found. The electrical connection is used for position monitoring, if I remember correctly about this motor.
The engine code seems to be incorrect. Sometimes, the U-Dose is available as a replacement set.
Translated on 07-07-2026, 7:30.
chriskross Blaumann
08-02-2013, 8:55 Subject: Passat 2009 power loss |
"Thank you, I was just looking for a second opinion."
Rep. Does this vehicle have a can?
A6 AFB
A6 BRE DPF
Translated on 07-07-2026, 7:31.
08-02-2013, 10:28 Subject: Passat 2009 power loss |
CRs and the BMR are perfectly suited to identify this error.
N75 and G581 in a scatter plot - done.
The sensor G581 is the position indicator in the vacuum chamber. You can clearly see if, for example, the membrane is torn.
Normally, there is a roughly linear relationship between N75 and G581.
If the values are too close to the edges, something is not right.
You can also attach a syringe to the container and observe the readings from the G581.
| Description: |
| File size: |
52.2 KB |
| Viewed: |
3758 times |
| Description: |
| File size: |
60.15 KB |
| Viewed: |
4773 times |
Translated on 07-07-2026, 7:32.
Profile PM Garage |
chriskross Blaumann
09-02-2013, 10:41 Subject: Passat 2009 power loss |
Wow, that looks really good. Is there a specific program used to create something like that?
A6 AFB
A6 BRE DPF
Translated on 07-07-2026, 7:33.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
09-02-2013, 11:24 Subject: Passat 2009 power loss |
Does every spreadsheet  and can you also view it with KDataScope?
Profile PM WWW Garage |
chriskross Blaumann
09-02-2013, 19:06 Subject: Passat 2009 power loss |
Okay, thank you!
Is there another question? Is there a trick, or a limit, when the vehicle is stationary and you press the accelerator? The engine speed only goes up to 2500 RPM before it's cut off.
A6 AFB
A6 BRE DPF
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
09-02-2013, 22:04 Subject: Passat 2009 power loss |
Getting off the clutch
Translated on 07-07-2026, 7:34.
Profile PM Garage |
mullemaus Guest
09-02-2013, 23:35 Subject: Passat 2009 power loss |
Or press the ESP switch.
