Pilot Training: Start Your Flying Career Now!
tdi-seppl
Post07-04-2003, 11:07    Subject: Pilot Training: Start Your Flying Career Now! Quote
hi,
"What exactly does Startpilot do? I assume it increases compression significantly, right? My old IHC tractor from 1964, with its 3-cylinder engine, only starts with this stuff now. I think it's become addicted to it, even though it still has 19 bar of compression. (Unfortunately, I don't have a target value because the people who built this tractor are all deceased)."
P.S. It doesn't have an engine control unit yet.
Maybe someone can give me a tip.
Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 30-07-2026, 2:21.
Post07-04-2003, 11:30    Subject: Pilot Training: Start Your Flying Career Now! Quote
So, without an OBD (On-Board Diagnostics) and an officially certified printout of the error memory, absolutely nothing will work. icon_wink.gif icon_biggrin.gif icon_biggrin.gif
Okay, but seriously now:
A jump start does not increase compression; it only ensures that the fuel-air mixture ignites slightly better (earlier).
"A compression pressure of 19 bar for a naturally aspirated engine seems a bit low to me. As far as I remember from my old 1.5L diesel engine, the compression pressure was somewhere between 28 and 32 bar."
Translated on 30-07-2026, 2:23.
98er_alh
Post07-04-2003, 11:47    Subject: Startpilot: Your Guide to Launching a Business Quote
[quote="tdi-seppl"]hi,
[/quote]
I've already written something about WarmStart problems with ALH engines: in 99% of cases, the starter motor is to blame (it rotates too slowly even though it sounds normal). On my IHC 214 D from 1961, I [u]measured everything, replaced parts, and adjusted settings until a new starter motor brought salvation. The "Startpilot" was already permanently attached to the dashboard when I bought it and extended with a hose to the intake manifold. Even today, I still feel the impact of that stuff (extreme pre-ignition due to an uncontrolled ignition timing)... I thought the connecting rods looked like corkscrews.
You could try starting it with a little bit of throttle. The support should be enough.
Good luck, Andreas.[/u]
Translated on 30-07-2026, 2:25.
tdi-seppl
Post07-04-2003, 15:51    Subject: Pilot Training: Start Your Flying Career Now! Quote
hi,
Thank you for the answers.
"Starting downhill with the gear engaged is not possible with this car. It has an S-tronic transmission or something like that, and in that case, everything disengages (you can move forward and backward without using the clutch)."
I've already tried installing a starter motor from a Volvo 844 as a test. It spins much faster, but the engine still doesn't start.
Translated on 30-07-2026, 2:27.
Gremlin
Post08-04-2003, 14:51    Subject: Pilot Training: Start Your Flying Career Now! Quote
We've actually replaced Start-Pilot a long time ago with brake cleaner.
It works the same way, is cheaper, and is ALWAYS available at the workshop...
'By the way: it seems like glow plugs used in pre-combustion chambers tend to fail after a few starts.' It's not something that can be definitively proven, but I think I'm seeing a tendency towards that.
Regarding your tractor:
Does it have a starter motor or a dynamos? Cleaning all the contacts and cables really works wonders.
CU Gremlin.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
There is only one true Porsche: DIESEL icon_wink.gif.
Translated on 30-07-2026, 2:29.
