Spark plug firing order (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Data
michiglaser Post20-09-2010, 15:02
Hello!
Simple question that could probably also be answered through a search if I knew what to search for icon_rolleyes.gif.
My Audi (ASB-TDI) is reporting a faulty glow plug via the diagnostic system – specifically, "glow plug 1."
Where is spark plug number 1 located?
Assuming the naming convention is consistent with the cylinder numbering, I need to know which cylinder is designated as number one.
Thank you very much icon_wink.gif.
Greetings,
Michael.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 11-07-2026, 12:17.
dieselmartin Post20-09-2010, 15:11
Wikipedia wrote:
The numbering of cylinders starts on the opposite side of the engine's power output. This does not apply to German ship engines and stationary engines. However, there are Japanese manufacturers who also start counting from the clutch side.
Vuck.
It's a V-engine.
Cylinder arrangement.
The arrangement is a longitudinally mounted V6 engine located at the front of the vehicle, as viewed from the front (according to DIN 73 021).
Power output.
3 6
2 5
1 4
The arrangement is a longitudinally mounted V8 engine located at the front of the vehicle, as viewed from the front (according to DIN 73 021).
Power output.
4 8
3 7
2 6
1 5
The following numbering system applies to a general-purpose V8 engine (according to ISO 1204, ISO 1205, and DIN 6265).
Power output.
8 4
7 3
6 2
5 1
The arrangement is a longitudinally mounted V10 engine located at the front of the vehicle, as viewed from the front (according to DIN 73 021).
Power output.
5 10
4 9
3 8
2 7
1 6
Translated on 11-07-2026, 12:21.
christians Post22-09-2010, 12:00
For V-engines mounted at the front, it looks like this:
Damn.
3 6
2 5
1 4
front
Gruß Christian
Translated on 11-07-2026, 12:24.
michiglaser Post22-09-2010, 13:49
Strong, thank you very much icon_smile.gif.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
TDI-GTI-4-Motion Post22-09-2010, 19:44
christians wrote:
For V-engines, mounted at the front, it looks like this:
Damn.
3 6
2 5
1 4
front
This is how counting is done according to the standard. However, very few people follow this method when it comes to V engines. Most people count the cylinders in a V engine diagonally (crosswise).
Damn.
5 6
3 4
1 2
front
Translated on 11-07-2026, 12:25.
christians Post24-09-2010, 11:51
Audi is present, but it complies with the regulations.
Gruß Christian
Translated on 11-07-2026, 12:26.
vwSchrauber Post24-09-2010, 11:57
dieselmartin wrote:
The numbering of cylinders starts on the opposite side from where the engine delivers power. This does not apply to German ship engines and stationary engines. However, there are Japanese manufacturers who also start counting from the clutch side.
In the 2.8 TDI engine, with code AUH, found in the LT van, cylinder number 1 is located at the rear, near the timing chain housing. If you don't believe it, remove the injector from what appears to be the first (frontmost) cylinder and then check the error memory icon_wink.gif.
In Deutz tractor engines, the first cylinder is also located on the power output side.
Translated on 11-07-2026, 12:27.
Ratings - Spark plug firing order
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Rear brake caliper, sequence Transmission, Chassis, Body & Interior
No new posts Change MFA Display Order Levels On-Board Diagnostics (OBD)
No new posts Error: Incorrect Request Order - Fix Now! Diesel Engine Technology
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
