PD Nozzles Replace Hex Key Wrenches
linklon
Post18-04-2012, 14:47    Subject: PD Nozzles Replace Hex Key Wrenches Quote
Hello.
I would like to replace the nozzle inserts on my BMP. I wanted to do this according to Rainer's instructions: https://community.dieselschrauber.org/en/viewtopic.php?t=17583
and I've found that the outer sleeve probably comes in several versions.
Rainer uses a 19mm ring wrench in the video he posted. My PD elements have locking nuts with an 8-sided shape and a keyway of 20mm.
Does anyone know where I can get a Bosch or Vag key? And does anyone happen to have the part number?
Best,
Jan
Passat 3c 4 Motion highline BMP
Translated on 04-09-2026, 4:08.
Post18-04-2012, 20:01    Subject: PD Nozzles Replace Hex Key Wrenches Quote
Check out Hazet's website and search for VW-specific tools.
Translated on 04-09-2026, 4:09.
Post18-04-2012, 20:47    Subject: PD Nozzles Replace Hex Key Wrenches Quote
...or order it from Bosch service, or obtain it against a correspondingly high deposit.
try to borrow.
I didn't find anything at Hazet.
Or, if all else fails --> carefully insert the nipple shield with protective flanges.
Secure the workpiece in a vise, then use a sharp, high-quality gripping pliers to hold the nozzle tip.
2. Attach the second pair of pliers (as shown in the video) and, using both pairs of pliers in a synchronized manner, loosen the ferrule.
"Cannot proceed" --> Cancel the process before anything is destroyed.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 04-09-2026, 4:10.
Post19-04-2012, 8:43    Subject: PD Nozzles Replace Hex Key Wrenches Quote
Follow-up question: 8-sided, not 6-sided?
Translated on 04-09-2026, 4:11.
linklon
Post19-04-2012, 10:21    Subject: PD Nozzles Replace Hex Key Wrenches Quote
Thank you for your responses.
@ Herbert
Yes, it's an 8-sided (hexagonal) socket. I also couldn't find anything like it at Hazet.
@ Autoservice: I've already tried the clamping method, but I'm having trouble.
Aborted because I couldn't tighten the sleeve enough in the vise.
"I can't get them out of their round shape icon_confused.gif."
Best,
Jan
Translated on 04-09-2026, 4:12.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts TDI Injector Adapters for PD Engines Diesel Engine Technology
No new posts Daten von DSLA 150P661 Dßseneinsätze Diesel Engine Technology
No new posts Injector Nozzles Replacement for Diesel Injection Systems Diesel Engine Technology
No new posts Replace V6 Injectors: Guide & Parts Diesel Engine Technology
