DSLA 150P661 Injector Data & Specs
golf3schrauber
Post28-05-2005, 15:33    Subject: DSLA 150P661 Injector Data & Specs Quote
Does anyone know the differences between the DSLA 150P526 and DSLA 150P661 injector nozzles?
You can find both types in the Bosch online catalog, but there is no information about the motors used.
The 150P526 would be 0.216mm. The motor has significantly less power with the 150P661. In the acceleration test, it's missing about 2 seconds.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 23-10-2026, 3:40.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts TDI Injector Adapters for PD Engines Diesel Engine Technology
No new posts PD Nozzles Replace Hex Key Wrenches Diesel Engine Technology
No new posts Injector Nozzles Replacement for Diesel Injection Systems Diesel Engine Technology
No new posts Inspection Interval Data On-Board Diagnostics (OBD)
