Golf 5 Headlight Monitoring
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post22-05-2012, 12:28    Subject: Golf 5 Headlight Monitoring Quote
I was contacted regarding this lamp monitoring system.
It's a Golf 5 from the very first years of production.
According to the owner, the lamp monitoring system illuminates regularly, but all the lamps are functioning correctly.
Occasionally, the problem would disappear. A few years ago, VW replaced the wiring harness at the rear because the issue had occurred there before. From that point on, things were quiet until a few months ago.
Has anyone had any experience with this, or are there any known diseases associated with it?
Can VCDS possibly be used to "re-initialize" or perform a reset?
Post22-05-2012, 13:04    Subject: Golf 5 Headlight Monitoring Quote
Which lights are supposedly broken?
Something in the trunk lid... then it sounds like a broken cable in the joint.
klahaui
Avatar-klahaui
Post22-05-2012, 16:35    Subject: Golf 5 Headlight Monitoring Quote
Yes, in the tailgate.
Rep. Should you replace a connector or wiring harness, or is it better to replace the entire thing?
Post22-05-2012, 17:34    Subject: Golf 5 Headlight Monitoring Quote
You can either have it repaired five times, with it constantly breaking down, or you can choose to get a brand new wiring harness – the choice is yours.
klahaui
Avatar-klahaui
Post22-05-2012, 18:43    Subject: Golf 5 Headlight Monitoring Quote
Okay, thank you.
While I doubt it will actually happen, I'm going to pass this along anyway.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Brake caliper-wheel bearing holder, Golf 2 GTD and Golf 1... Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
