Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
25-04-2012, 16:29 Subject: Audi A4 B6 Rear Door Won't Unlock |
A colleague is having a problem with his A4 B6; one of the rear doors no longer unlocks with the central locking system. Is there perhaps a trick to open the door from the inside without causing any damage, in order to remove the trim for repair? Gruß
Translated on 18-08-2026, 18:08.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
25-04-2012, 17:11 Subject: Audi A4 B6 Rear Door Won't Unlock |
Let's try one more time to see if we can trick the lock again.
Possibly disconnect the battery for 1 minute - has that helped before?
I would try to work around it first, before things become unpleasant.
Removing the disguise will be difficult, if not impossible.
because it also serves as a seal at Audi, so it's positioned in front of the door rubber, not between them.
Do you even know how to normally remove the trim?
If no ---> Vehicle data? LG, Onkel BM
Translated on 18-08-2026, 18:09.
25-04-2012, 18:20 Subject: Audi A4 B6 Rear Door Won't Unlock |
Autoservice wrote: |
If no ---> Vehicle data? |
Okay, I'll pass that information along about disconnecting the battery.
He generally has access to the Audi repair manuals. Gruß
Translated on 18-08-2026, 18:10.
Profile PM Garage |
pax Profi-Schrauber
2000 Volkswagen Passat Support
25-04-2012, 20:07 Subject: Audi A4 B6 Rear Door Won't Unlock |
Quote: | | The rear door no longer unlocks using the central locking system | .
It's probably not possible to pull the interior door handle twice on a B6 model.
Bye.
peace
Translated on 18-08-2026, 18:11.
Profile PM Garage |
25-04-2012, 20:27 Subject: Audi A4 B6 Rear Door Won't Unlock |
pax wrote: | Quote: | | No longer unlocks a rear door via central locking | .
Bye.
peace |
He had already tried that, unsuccessfully. Gruß
Translated on 18-08-2026, 18:12.
Profile PM Garage |
25-04-2012, 21:52 Subject: Audi A4 B6 Rear Door Won't Unlock |
So, don't open the lock.
That's a bad situation. Let's try a little bit and hope the engine starts again. MfG. Michael
Translated on 18-08-2026, 18:13.
Profile PM Garage |
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
26-04-2012, 20:13 Subject: Audi A4 B6 Rear Door Won't Unlock |
Is it possible to remove the door handle separately here?
It's difficult to compare, but I've experienced this issue multiple times with the Actros truck. In those cases, I was able to "bypass" the lock by using a small gap and a long wire. Kaum macht man es richtig, funktioniert es!
Translated on 18-08-2026, 18:14.
Profile PM Garage |
26-04-2012, 20:19 Subject: Audi A4 B6 Rear Door Won't Unlock |
Quote: | | It was difficult to compare, but it had already been on the Actros | several times.
Okay. If you're unlucky, the lock might be encapsulated within the mechanism.
Nothing will get through from the outside. LG, Onkel BM
26-04-2012, 20:46 Subject: Audi A4 B6 Rear Door Won't Unlock |
Unfortunately, I haven't heard anything new from him yet... Gruß
Translated on 18-08-2026, 18:15.
Profile PM Garage |
michiglaser Blaumann
Joined: 05/03/2007 Posts: 274 Karma: +6 / -0 Location: Lkr. KEH 2007 Audi A4 Avant Premium Support
02-05-2012, 22:40 Subject: Audi A4 B6 Rear Door Won't Unlock |
Otherwise, it should be mentioned that the door panels for the B6 are relatively inexpensive to obtain from 3-2-1  . T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Profile PM Garage |
02-05-2012, 22:46 Subject: Audi A4 B6 Rear Door Won't Unlock |
Thank you everyone, and also thank you for the tip about the book.
Disconnecting the battery, by the way, didn't help  .
It looks like the dealer will be taking care of it. Luckily, he still has a warranty on the used car. I'll let you know if there's any news. Gruß
Translated on 18-08-2026, 18:16.
Profile PM Garage |
02-05-2012, 23:38 Subject: Audi A4 B6 Rear Door Won't Unlock |
michiglaser wrote: | Otherwise, it should be mentioned that the door panels for the B6 are relatively inexpensive at 3-2-1  | However, as Autoservice already mentioned, with Audi, you always have this frame structure included.
I don't know how it looks in the back of the B6, but in all the Audis I've worked on so far, destroying just the door panel wouldn't really achieve much because you have to remove the entire frame.  MfG. Michael
Translated on 18-08-2026, 18:17.
Profile PM Garage |
20-05-2012, 20:59 Subject: Audi A4 B6 Rear Door Won't Unlock |
The door is now open.
You need to pull on the levers both inside and outside simultaneously while operating the control panel. If anyone else is experiencing this problem... Gruß
Translated on 18-08-2026, 18:18.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18063 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
21-05-2012, 16:55 Subject: Audi A4 B6 Rear Door Won't Unlock |
Roger wrote: | Hi,
You need to pull the levers both inside and outside simultaneously while operating the control panel. If anyone else encounters this problem... |
Thank you for the feedback!
Profile PM WWW Garage |
21-05-2012, 19:03 Subject: Audi A4 B6 Rear Door Won't Unlock |
In addition, I learned today that the door has been working normally again since this "reset"  . Gruß
Translated on 18-08-2026, 18:19.
Profile PM Garage |
