TDI Taxes: Calculation and Reclassification
HolyDream
Post12-04-2003, 21:23    Subject: TDI Taxes: Calculation and Reclassification Quote
What are the taxes for a 1Z 75 and 90 hp engine, and what are they for a 110 hp AFN engine?
Can this be phrased in a way that's suitable for D3 or something similar? Thanks!
Translated on 26-07-2026, 12:46.
Post13-04-2003, 9:17    Subject: TDI Tax & Recoding: Your Complete Guide Quote
HolyDream wrote:
What are the taxes for the 1Z 75 and 90 hp engines, and what are they for the 110 hp AFN engine?
"... the 1Z engine is only available with 90 horsepower! And the 75 horsepower engine (AAZ) is a TD, not a TDI. The taxes for TDI engines are the same. The AAZ engine needs to be modified to meet Euro2 emissions standards."
Early models of the 1Z still had a Euro1 classification, but this could only be achieved through reclassification. You can find more information about this in the forum if you use the search function.
Which ones can be framed in D3 or something like that? Thank you!
The maximum allowed is Euro 2. Euro 3 engines have different engine control units (ECUs) and are technically equipped differently (e.g., with ESP, injectors, TCU...).
Translated on 26-07-2026, 12:48.
eltipo
Post13-04-2003, 9:27    Subject: TDI Taxes: Calculation and Reclassification Quote
In case he wants to generalize, the ALH with 90 hp has the D3... (but not necessarily ESP?!).
greetings
I'm sorry, I can't translate that word because it doesn't seem to be a real word in any language I know. It might be a typo or a made-up word. Could you please double-check the spelling?
Translated on 26-07-2026, 12:50.
Post13-04-2003, 9:34    Subject: TDI Taxes: Calculation and Reclassification Quote
eltipo wrote:
...(but not necessarily ESP?!?!)
Shhh, don't tell anyone:
ESP = fuel injection pump.
If the ALH doesn't have ESP, I'd like to know how you make it work icon_smile.gif.
By the way, the ALH is essentially a 1Z engine with EU3 emissions standards (featuring different ESP components, injectors, fuel lines, and ECU).
Mampf
Karma: +8 / -1   Thank you, like it!
Post13-04-2003, 10:04    Subject: TDI Taxes: Calculation and Reclassification Quote
Bertil wrote:
By the way, the ALH is essentially a 1Z engine with EU3 emissions standards (with different ESP, injectors, fuel lines, and ECU)
If I'm not mistaken, the ALH engine also has a variable geometry turbocharger (VTG), while the 1Z engine has one with a wastegate.
Crunch.
Translated on 26-07-2026, 12:52.
Post13-04-2003, 10:35    Subject: TDI Taxes: Calculation and Reclassification Quote
Oh sorry, I meant the ALE, not the ALH.
I seem to have made a mistake with the letters icon_wink.gif.
Translated on 26-07-2026, 12:53.
kenny
By the way, I believe there are Euro 2 and Euro 3 versions of the AHF. Mine is definitely a Euro 2 version. Converting from Euro 2 to Euro 3 would only save you a few euros per year, but it comes with inspection fees at the TÜV (technical inspection agency).
eltipo
Post13-04-2003, 11:31    Subject: TDI Taxes: Calculation and Reclassification Quote
.....(but not necessarily Spanish?!!)
Right now, in my shopping frenzy, I'm having different associations come to mind.
greetings
Translated on 26-07-2026, 12:54.
Martl-san
Post13-04-2003, 12:57    Subject: TDI Taxes: Calculation and Reclassification Quote
I once inquired with Audi about my A4s:
I was able to switch to D3 without any problems in my A4 with a 1.6L engine and 101 horsepower.
A4 1.9 TDI 110 hp (AFN engine)... This model does not meet the Euro 2 emissions standard.
If you're interested, I can scan the document and upload it.
'cu' translates to 'see you' or 'goodbye' in Spanish. It can also be used as a greeting, similar to 'hi' or 'hello.'
Martl.
Translated on 26-07-2026, 12:56.
Post13-04-2003, 13:32    Subject: TDI Taxes: Calculation and Reclassification Quote
Please do not compare diesel and gasoline engines with each other!
The comparison doesn't quite work. / The analogy is flawed.
Translated on 26-07-2026, 12:58.
C.F.
Post14-04-2003, 13:22    Subject: TDI Taxes: Calculation and Reclassification Quote
Hi.
Perhaps a bit off-topic, but what's the actual difference between the AHL and the AHH engine that's installed in my Passat?
Best regards, Claus.
Translated on 26-07-2026, 12:59.
No new posts Manufacturer's Certificate for Encryption of Audi 80 B4 1Z Upload
No new posts Cat Tax Savings: Retrofit Your Car Now! Diesel Engine Technology
No new posts [Poll] Auflastung für T4 Hinterachse (Steuern sparen) Transmission, Chassis, Body & Interior
