Knautsch
Joined: 06/02/2008 Posts: 10 Karma: +0 / -0 Location: NRW NORD
Registered VCDS User
02-05-2012, 15:27 Subject: ESP Coding for VW Passat 3C - Disable? |
I'm having the following problem:
Volkswagen Passat 3CB, 2006, 2.0 TDI engine, code BMR.
"The AHK (trailer hitch) was retrofitted and an attempt was made to unlock it using a Gutmann tester, but something went wrong. The current coding that I read out with my VCDS is 0064829. However, this may not be correct because since the coding, an error code 02543 for the vacuum sensor of the brake booster has been detected. This sensor is not actually present. The ESP part number is 3c0 614 095s, and the ESP identification number is 440C2 H0150004. The PR code for the brakes is PR-1AT. The VIN is wvwzzz3cz6e233760."
What is the correct coding with AHK for features like parking assistance, etc.?
Best regards.
Wrinkle.
Aktuelles RKS-VCDS vorhanden. RAUM Münsterland/ Süd Niedersachen
Translated on 20-08-2026, 6:18.
Autoservice Profi-Schrauber
02-05-2012, 16:18 Subject: ESP Coding for VW Passat 3C - Disable? |
For questions like this, please always include a vehicle scan with details about the make, model, and installed/configured components so we know which car you're referring to.
Translated on 20-08-2026, 6:19.
Knautsch
02-05-2012, 16:33 Subject: Car Scan: Automatic Vehicle Inspection System |
Wednesday, May 2, 2012, 17:02:37:04850
VCDS version: RKS 11.11.
Data as of: 20120130.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 53 55 56 5D
62 6D 66 6E 6E 64 65 63 6F 6D 70 6C 65 74 65 72 73
Vehicle Identification Number (VIN): WVWZZZ3CZ6E233760. Mileage: 158,490 km.
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brakes -- Status: Error 0010.
08-Climate Control/Heating -- Status: OK 0000
09-Onboard network -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Immobilizer system - Status: Error 0010.
37-Navigation -- Status: Error 0010.
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
53-Parking brake -- Status: Error 0010.
55-Beam adjustment. -- Status: OK 0000
56-Radio -- Status: Error 0010.
5D Control Unit -- Status: OK 0000
62 - Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
Rear hatch (6D) -- Status: OK 0000
Door 72, electric hinge, right side - Status: OK 0000.
76-Parking Assist -- Status: OK 0000
77-Phone -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine; Label file: RKS\03G-906-018-BMN.clb.
Part number SW: 03G 906 018 ER, Hardware part number: 03G 906 018 ER.
Component: R4 2.0l PPD1.2 G 4367
Revision: --H02--- Serial number: VWZCZ000000000
Coding: 0000078
Operating number: WSC 43168 133 95330
VCID: 79FD9F5A30C273B
No error codes found.
Readiness: Not available.
Address 02: Transmission Label file: RKS\02E-300-0xx.lbl
Part number SW: 02E 300 043 E, HW: 02E 927 770 AD.
Component: GSG DSG, part number 082 1133.
Revision: 05108020 Serial Number: 00001009031426
Encoding: 0000020
Operating number: WSC 44551 111 44551
VCID: 1627B4E6219CBC3
Address 03: Brakes Label file: RKS\3C0-614-095-C2.clb
Part number SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial Number: 0940004693
Encoding: 0064829
Operating number: WSC 65793 128 08224
VCID: 326F6876AD34403
"One error found:"
02543 - Vacuum sensor for brake booster (G483).
012 - Electrical fault in the circuit.
Environmental conditions:
Error status: 01101100
Error priority: 3
Error frequency: 1.
Lost Count: 238
Mileage: 158,495 km
Time: 0.
Date: 2012.05.02
Time: 16:12:25
Address 08: Climate Control/Heating Label file: RKS\3C0-907-044.lbl
Part number SW: 3C0 907 044 AD, HW: 3C0 907 044 AD.
Component: Climatronic PQ46 050 0404
Revision: 00050005 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
VCID: 63C1DD32A24E99B
Address 09: Body Control Module
Label file: RKS\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 L, Hardware part number: 3C0 937 049 L.
Component: Onboard network module H37 1301.
Revision: 00H37000 Serial Number: 00000005230741
Encoding: E78A8F0700041A00000A00000F000000000F5D435C0000
Operating number: WSC 05311 000 00000
Subsystem 1 - Part number: 3C1 955 119
Label file: RKS\1KX-955-119.CLB
Part number: Wiper blade VW461 012 0503.
Encoding: 00063445
Subsystem 2 - Part number: 1K0 955 559 T. Label file: RKS\1K0-955-559-AF.CLB.
Component: RainLightSensor 011 1110
Encoding: 00208933
"One error found:"
00924 - Relay for headlight cleaning system (J39).
009 - Short circuit to ground / Ground fault.
Error status: 01101001
Error priority: 4.
Error frequency: 1.
Lost Count: 239
Mileage: 158,495 km
Time: 0.
Date: 2012.05.02
Time: 14:24:00
one
Voltage: 11.80 V
one
one
text
from
text
from
text
from
Address 15: Airbag
Label file: RKS\3C0-909-605.lbl
Part number SW: 3C0 909 605 K, HW: 3C0 909 605 K.
Part number: 12 AIRBAG VW8R 029 2521.
Revision: 10029000 Serial Number: 003A3P77T7RW
Encoding: 0012594
VCID: 2E577C06B90C643
Address 16: Steering wheel
Label file: RKS\3C0-953-549-SW20.lbl
Part number SW: 3C0 953 549 E, HW: 3C0 953 549 E.
Component: J0527 0015
Revision: 00005000 Serial Number: 3C9953507P
Coding: 0001412
Part number: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Combination Instrument
Label file: RKS\3C0-920-xxx-17.lbl
Part number SW: 3C0 920 870 Q, HW: 3C0 920 870 Q.
Component: COMBINATION INSTRUMENT VD1 4240.
Revision: V0034000 Serial Number: 00000000000000
Encoding: 0007105
Operating number: WSC 68144 133 85564
VCID: 316D677AA8327BB
Address 19: CAN Gateway
Label file: 3C0-907-530.lbl
Part number SW: 3C0 907 530 C, HW: 3C0 907 951 A.
Component: Gateway 007 0040
Revision: 00007000 Serial Number: 0700C06505038C
Encoding: 7FFDBC5CE62002
Operating number: WSC 43168 133 84286
VCID: 214D973AF8D2CBB
Address 25: Immobilizer
Label file: RKS\3C0-959-433-25.lbl
Part number SW: 3C0 959 799, HW: 3C0 959 799.
Component: IMMO 067 0364
Revision: 00067000 Serial Number: VWZCZ000000000
Operating number: WSC 43168 133 83556
VCID: F6E7146681DC9C3
Part number: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
"One error found:"
01176 - Key
004 - No signal/communication.
Error status: 01110100
Error priority: 1.
Error frequency: 1.
Lost Count: 164
Mileage: 153,060 km
Time: 0.
Date: 2012.02.27
Time: 11:43:14
Address 37: Navigation (J0506)
Label file: RKS\1T0-035-680.clb
Part number SW: 1T0 035 680 C, HW: 1T0 035 680 C.
Part: RNS-MID H06 2720
Revision: AB001001 Serial Number: VWZ6Z7N6088186
Encoding: 020100000100000200
ASAM Dataset: ------------------------- ------
VCID: 2E577C06790C643
"One error found:"
00857 - CD Changer (R41)
Error status: 01100100
Error priority: 5.
Error frequency: 4
Lost Count: 239
Mileage: 158,488 km
Time: 0.
Date: 2012.05.02
Time: 14:35:18
Address 42: Door electrical driver
Label file: RKS\1K0-959-701-MIN2.lbl
Part number: 1K0 959 701 K
Component: Door seal 024 2801
Coding: 0000245
VCID: 36675466415C5C3
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x-44.clb
Part number: 1K1 909 144 K
Component: EPS_ZFLS, Size 5, Part Number D06 1701.
VCID: 33616D72522E49B
Address 46: Comfort System
Label file: RKS\3C0-959-799-46.clb
Component: KESSY PQ46, part number 067 0336.
Encoding: 00900A08D1430E763804941570084F0E703900030424A0
Part number: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS, not mounted.
Component: IRUE, not mounted.
Address 47: Soundsystem Label file: RKS\3C0-035-456.lbl
Part number: 3C0 035 456.
Component: 08K Audio Amplifier. 0003
Revision: 00001000 Serial Number: 00000000013797
VCID: DDB56BCA042A2FB
Address 52: Power door lock, front passenger side. Label file: RKS\1K0-959-702-MIN2.lbl
Part number: 1K0 959 702 K
Encoding: 0000244
VCID: 377959624656A5B
Address 53: Parking brake
Label file: RKS\3C0-907-801-53.clb
Part number SW: 3C0 907 801 B, HW: 3C0 907 801 B.
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
"One error found:"
00650 - Clutch pedal switch (F36)
010 - Interruption/Short circuit after positive terminal - Warning light ON.
Error status: 11101010
Error priority: 5.
Error frequency: 2.
Lost Count: 239
Mileage: 158,488 km
Time: 0.
Date: 2012.05.02
Time: 15:42:18
Voltage: 11.49 V
Quantity: 71
Address 55: Headlight range adjustment. Label file: RKS\5M0-907-357-V1.lbl
Part number SW: 5M0 907 357, HW: 5M0 907 357.
Component: AFS Control Unit X016
Revision: H09 Serial Number:
Encoding: 0000001
VCID: F1ED277AE8B2BBB
Subsystem 1 - Part number: 7L6 941 329.
Component: AFS-List Module l X018
Encoding: 00000035
Subsystem 2 - Part number: 7L6 941 330.
Component: AFS-List Module r X018
Encoding: 00000035
Address 56: Radio (J0506) Label file: RKS\1T0-035-680.clb
"One error found:"
Error priority: 5.
Error frequency: 4
Lost Count: 239
Mileage: 158,488 km
Time: 0.
Date: 2012.05.02
Time: 14:35:18
Address 5D: Control unit
Label file: RKS\3C0-035-151.lbl
Part number SW: 3C0 035 151 C, HW: 3C0 035 151 C.
Component: J738 011 0018
Revision: 00011000
VCID: 183BBADE2B888A3
Address 62: Door electric strike, left/right. Label file: RKS\1K0-959-703-GEN2.lbl
Part number: 3C9 959 703.
Component: Door seal 021 2507
Encoding: 0000144
VCID: F0EB227EE3B8B23
Address 69: Trailer.
unavailable
Address 6D: Rear door
Label file: RKS\3C9-827-383.lbl
Part number SW: 3C9 827 383 B, HW: 3C9 827 383 C.
Part: J605 TAILGATE 0405
Revision: 00H20001
Operating number: WSC 23250 384 715754
VCID: 306B627EA338723
Part number: 3C9 827 384 B.
Part: J756 REAR COVER 0405
Address 72: Door electric strike, high, right. Label file: RKS\1K0-959-704-GEN2.lbl
Part number: 3C9 959 704.
Encoding: 0000144
Address 76: Parking Assist
Label file: RKS\3C0-919-283.lbl
Part number SW: 3C0 919 283 B, HW: 3C0 919 283 B.
Component: Parking Assist System, 8 Channels, Part Number 004 0011.
Revision: 00004000 Serial Number: 82930611703131
Encoding: 0011024
VCID: 285B8A1E9BE83A3
Address 77: Telephone
Label file: RKS\3C0-035-730.lbl
Part number SW: 3C0 035 730 A, HW: 3C0 035 730 A.
Component: Telephone 2109
Revision: 00008000 Serial number: 0000000011912
Coding: 0020055
VCID: 193DBFDAD08293B
Address 7D: Auxiliary Heater
Label file: RKS\1K0-963-235.lbl
Part number SW: 1K0 963 235 E, Hardware part number: 1K0 963 235 E.
Component: PTC element 0404
Revision: 00800000 Serial Number:
VCID: 2D557B0AB40A1FB
"End"
Translated on 20-08-2026, 7:07.
02-05-2012, 17:56 Subject: ESP Coding for VW Passat 3C - Disable? |
That's really bad. Did you not happen to have an old Autoscan or error memory log in your VCDS-RKS installation directory that contains the correct coding information?
While there are certain codes that one could try, I would recommend going to a qualified mechanic for the journey, for security reasons.
Translated on 20-08-2026, 7:08.
Profile PM WWW Garage |
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
02-05-2012, 20:14 Subject: ESP Coding for VW Passat 3C - Disable? |
Quote: | | That's really bad. Don't you have an old Autoscan or error memory dump in your VCDS-RKS installation directory that shows the correct coding? |
Should I use a comparable vehicle, also a 2006 BMR station wagon, or is that pointless?
3B5 AJM
Translated on 20-08-2026, 7:09.
02-05-2012, 20:27 Subject: ESP Coding for VW Passat 3C - Disable? |
BM wrote: | That's really bad. Quote: | | Don't you have an old Autoscan or error memory dump in your VCDS-RKS installation directory that shows the correct coding? |
Should I use a comparison vehicle, also a 2006 BMR station wagon, or is that rather pointless? |
With identical equipment already  .
I just remembered something: Usually, when contacting customer service at  , you should receive an error log. With a bit of luck, it might also contain the original encoding information.
Translated on 20-08-2026, 7:10.
Knautsch
03-05-2012, 17:25 Subject: Solution: Problem Solved! |
Thank you very much for your answers.
Ross-tech USA provided assistance with the correct coding, which is 0032061 with AHK and 0015677 without AHK.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Translated on 20-08-2026, 7:11.
03-05-2012, 17:43 Subject: ESP Coding for VW Passat 3C - Disable? |
Thank you for the feedback!
Translated on 20-08-2026, 7:12.
