klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
22-05-2012, 12:28 Subject: Golf 5 Headlight Monitoring |
I was contacted regarding this lamp monitoring system.
It's a Golf 5 from the very first years of production.
According to the owner, the lamp monitoring system illuminates regularly, but all the lamps are functioning correctly.
Occasionally, the problem would disappear. A few years ago, VW replaced the wiring harness at the rear because the issue had occurred there before. From that point on, things were quiet until a few months ago.
Has anyone had any experience with this, or are there any known diseases associated with it?
Can VCDS possibly be used to "re-initialize" or perform a reset?
Best regards, Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
22-05-2012, 13:04 Subject: Golf 5 Headlight Monitoring |
Which lights are supposedly broken?
Something in the trunk lid... then it sounds like a broken cable in the joint.
m; Transparency, Teamwork
Profile PM Garage |
22-05-2012, 16:35 Subject: Golf 5 Headlight Monitoring |
Yes, in the tailgate.
Rep. Should you replace a connector or wiring harness, or is it better to replace the entire thing? Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
22-05-2012, 17:34 Subject: Golf 5 Headlight Monitoring |
You can either have it repaired five times, with it constantly breaking down, or you can choose to get a brand new wiring harness – the choice is yours.
Profile PM Garage |
22-05-2012, 18:43 Subject: Golf 5 Headlight Monitoring |
Okay, thank you.
While I doubt it will actually happen, I'm going to pass this along anyway. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
