Intercooler Cleaning: Should You "De-oil" It?
Jericho
Post11-04-2006, 19:31    Subject: Intercooler Cleaning: Should You "De-oil" It? Quote
Hello!
It might be that I'm worrying unnecessarily about this problem, but...
Should you occasionally remove the liquid cooling system and verschandeln out any accumulated...
Flush out the sludge?
Or is this complete nonsense because no oil sludge accumulates there, and therefore the efficiency of the lubricating liquid (LLK) does not suffer?
Or whatever.
Translated on 10-08-2026, 14:12.
Hati
Post11-04-2006, 19:51    Subject: Intercooler Cleaning: Should You "De-oil" It? Quote
Well, normally, the entire charge air cooler circuit behind the turbocharger will be slightly oiled. If there is no defect in the turbocharger, this is first of all perfectly normal and secondly never so much that the intercooler could become 'sludgy.' Furthermore, so much air always passes through it that 'sludge' would not have the opportunity to accumulate.
'Sludge would mean that solid particles are also passing through the intercooler system. But where would they be coming from? From the crankcase ventilation or through the air filter?'
However, mud from outside is conceivable and also reduces the efficiency of the heat exchanger.
Translated on 10-08-2026, 14:14.
Jericho
Post11-04-2006, 20:07    Subject: Intercooler Cleaning: Should You "De-oil" It? Quote
Okay, thanks for the info. It saves me work icon_wink.gif.
Translated on 10-08-2026, 14:15.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
No new posts Kann ich an einem Pumpe Düse Element die "Spitzen&q... Diesel Engine Technology
