Replace the engine damage on the 2.0 TDI 140hp MKB BMP with BMM.
druese
Post31-05-2012, 20:12    Subject: Replace the engine damage on the 2.0 TDI 140hp MKB BMP with BMM. Quote
Hello dear community,
Unfortunately, I have also become a victim of an oil pump issue... defective hex nut ....
The engine is now STUCK after the engine warning light (oil pressure) briefly came on on the highway.
I'm wondering if I should replace the faulty motor with the MKB BMP through the BMM, since the new pump drive runs via gears there.
Could you please provide me with some guidance?
Thank you, Dierk.
Post31-05-2012, 20:35    Subject: Replace the engine damage on the 2.0 TDI 140hp MKB BMP with BMM. Quote
I'm wondering if I should replace the faulty motor with the MKB BMP, as the new pump drive runs through gears there.
As far as I know, the chain drive system no longer exists.
I'll take the engine apart first and then decide.
comco
Karma: +1 / -3   Thank you, like it!
Registered VCDS User
Post01-06-2012, 21:02    Subject: Replace the engine damage on the 2.0 TDI 140hp MKB BMP with BMM. Quote
Regarding your engine, you need to assume a total loss and also a damage to the turbo.
Depending on the wear and tear of the 6-sided oil pump drive shaft, it often slides through over a longer period of time, and then cannot build up the required oil pressure without the warning light being displayed.
I am assuming that you are referring to the drive of the balancing shaft module using a chain.
But the 6-sided gear also occasionally goes over the edge when used with the gear-driven balancing wave module.
To the engine control unit, whether it's a BMP or BMM, it doesn't matter.
If you have a DSG gearbox, you need to make sure that the KWP (kickdown) rod bearing is upgraded when you buy the engine.
Sidebar: If the engine has not yet been opened to examine the cause, it is also possible that the KW (presumably a component) is broken and has become misaligned. Then it becomes much cheaper to get the item running again.
Bye
Jürgen
Bye
Jürgen
_________________________________________
Für den Spass/Winterauto: Audi TT Q und die Arbeitstier: Octavia 2 RS,
Für noch mehr Spass: R1200S, Laverda Formula, SV 1000 und NSU MAX
Georg_G
2012 Volkswagen Golf
Post05-06-2012, 23:04    Subject: Replace the engine damage on the 2.0 TDI 140hp MKB BMP with BMM. Quote
... Sorry for hijacking this thread.
From this perspective -- with the oil pump's declining performance -- would it be sensible to install an oil pressure gauge in order to detect this problem in a timely manner?
Who knows what the oil pressure should be at operating temperature and approximately 2000 rpm?
I am asking because I also operate a BSS that includes an oil pump with a pulsation dampening module. The previous owner had the engine die after 90,000 km; there was a replacement engine installed in 2009, which has now run for approximately 80,000 km.
Best regards, Georg
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis 12.2000, Brummgeräusche durch Freispreche... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace Bosch MAF sensor with Hitachi MAF sensor? (V6 TDi... Diesel Engine Technology
No new posts Upgrade Turbo: Wastegate to VTG Turbocharger Diesel Engine Technology
No new posts Engine Damage: 2.5 TDI Failure Due to Timing Belt Diesel Engine Technology
No new posts TDI engine damage due to re-tapping glow plug threads?? Diesel Engine Technology
