VAGCOM Crash: Troubleshooting and Solutions
huehnerhugo
Post10-04-2003, 22:14    Subject: VAGCOM Crash: Troubleshooting and Solutions Quote
Hello everyone,
I am using the VAGCOM software, version MFT208.2.
'Now I'm having a problem where the program crashes after about 2-3 minutes whenever I connect to a control unit. It's as if the program is being closed. With my adapter on a Golf IV, logging into a control unit actually works quite reliably. The real issue arises during test drives when I constantly have to restart the program and then also have to reconfigure the measurement blocks.'
Thank you for your help.
Translated on 23-08-2026, 7:39.
brezelmann01
Post10-04-2003, 23:00    Subject: VAGCOM Crash: Troubleshooting and Solutions Quote
Hi!
I had the same problem with that version! That's why I switched back to the older 0.81a version. It works perfectly reliably for me!
pretzelman01
Translated on 23-08-2026, 7:40.
haehnlein
Post11-04-2003, 0:53    Subject: VAGCOM Crash: Troubleshooting and Solutions Quote
Me too.
____________
Kein Auto mehr!
Translated on 23-08-2026, 7:41.
joergs
Post11-04-2003, 6:43    Subject: VAGCOM Crash: Troubleshooting and Solutions Quote
We've discussed this before! Version 2.082 has errors related to this issue. Unfortunately, DRV only admitted it quite late. The new version 3.022 doesn't have the problem, and neither do the previous versions.
No new posts Crash VAG Com when accessing specific ECUs On-Board Diagnostics (OBD)
No new posts VAGCOM and Coolant Temperature Diesel Engine Technology
No new posts VAGCOM Codes: Troubleshooting & Diagnostics On-Board Diagnostics (OBD)
No new posts VAGCOM: Kommunikationsprobleme Diesel Engine Technology
