Squeaky Brakes: Troubleshooting 3C Systems
Post23-05-2012, 12:40    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
Hi.
"When I need to brake gently (e.g., going down a ramp in a parking garage), my rear brakes squeal quite loudly."
When switching from winter to summer tires, I was "messing around" with things from the outside, meaning I tried to do something somehow between the outer brake pads and the caliper.
It actually made things worse.
Now, thanks to the change, I know that this is the right place.
What do you think about this?
- Approach the EPB (Emergency Parking Brake).
- Gently squeeze the brake caliper together.
- Insert a piece of cloth between the pliers and the material.
- If necessary, use a cloth with some ceramic paste on it.
- Revert to EPB.
Translated on 07-08-2026, 9:47.
Post23-05-2012, 13:19    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
I think it's more likely that I need to expand it, clean it, break the edges, lubricate it, and then install it.
the better solution is, or, if necessary, replace it with a suitable alternative.
As far as I know, the blocks are covered with a plastic layer or plate on the outside, which is why lubrication wouldn't be effective in that area.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 07-08-2026, 9:49.
Post23-05-2012, 14:02    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
Well, at least the "degreasing" resulted in "more squeak."
And I have to hurry, because it makes less noise/no noise when it's hot.
Translated on 07-08-2026, 9:50.
Karma: +1339 / -0   Thank you, like it!
Post23-05-2012, 15:58    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
servusssss
Post24-06-2012, 12:37    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
I've experienced the same problem with my colleague's vehicle; there's a Technical Service Bulletin (TPI) about it available from the dealerships.
It replaces the brake caliper carrier (or whatever you want to call it) with a new design.
The old mechanism somehow starts to vibrate, and then there's the loud squeaking icon_smile.gif.
Sure. Please provide the text you would like me to translate from German to English. I will only provide the translation, without any explanations.
Translated on 07-08-2026, 9:51.
Post25-06-2012, 9:46    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
Do you have a TPI number for me?
Thank you.
Translated on 07-08-2026, 9:52.
servusssss
Post25-06-2012, 15:20    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
I'll ask about it for you, but I can't promise anything; it's been a couple of years already.
Translated on 07-08-2026, 9:53.
Post25-06-2012, 15:43    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
Above all, the question of cost is always relevant.
Because if I have to pay for everything, I might as well just replace the toppings.
Then things should be quiet again.
Post25-06-2012, 15:58    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
Because if I have to pay for everything, I might as well just replace the linings.
I would do it that way too -- and you have new linings icon_wink.gif.
Above all, I would replace the original equipment (OE) pads with a premium brand product.
The OE manufacturer primarily focuses on other components. It's not impossible that the standard brake pads are a (cheap) product sourced from another supplier.
Translated on 07-08-2026, 9:54.
Post25-06-2012, 16:45    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
Is TRW cheap?
Translated on 07-08-2026, 9:55.
Post25-06-2012, 19:44    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
dieselmartin wrote:
Is TRW cheap?
Unfortunately, it's not included in the price. It's a dealbreaker for me in my vehicle. I have no idea who manufactures these things. They used to be made by Lucas, I think.
Lucas KlÜtze habe ich ein paar Mal verbaut - NIE WIEDER!, wogegen Bremssättel von Lucas standfester als zB. ATE are/were.
Recently, my friend and I finally got rid of everything related to those brake pads. Since then, there's been no more rumbling or noise.
Translated on 07-08-2026, 9:56.
Post25-06-2012, 21:13    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
I just checked again:
Everything is still in its original condition, with the TRW logo and the VW part number visible from the outside through the large holes in the Monte Carlo spokes.
Recently, my friend (who owns a 3C BMR) and I finally got rid of everything related to those brake pads. Since then, there has been no more rumbling or noise.
And what did you put inside?
Translated on 07-08-2026, 9:57.
Post25-06-2012, 21:27    Subject: Squeaky Brakes: Troubleshooting 3C Systems Quote
And what did you put in there?
Advantages: Braking performance -> consistent from start to finish, no issues with vibrations, durable like original equipment (OE) and affordable.
Disadvantage: Brake discs are not yet available with a coating for all vehicle types. A little more dust on the rims - I personally haven't experienced this.
My front brakes are now due for replacement after 120,000 km and 7 years. They were still sufficient for the technical inspection (TÜV).
Translated on 07-08-2026, 9:58.
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Can defective bearing bearings make a squeaking noise? Diesel Engine Technology
No new posts Brake response Transmission, Chassis, Body & Interior
No new posts Brake Maintenance: How to Protect Your Brakes Transmission, Chassis, Body & Interior
No new posts Brembo Bremsen Transmission, Chassis, Body & Interior
