Heat Exchanger A3 8L: Supply & Return
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post21-07-2012, 0:06    Subject: Heat Exchanger A3 8L: Supply & Return Quote
Can someone tell me which of the two hoses connected to the heat exchanger is the inlet and which is the outlet?
I'm always surprised by that.
They are next to each other; I can also take a picture if you'd like.
Thank you.
Translated on 17-08-2026, 8:45.
Post21-07-2012, 10:27    Subject: Heat Exchanger A3 8L: Supply & Return Quote
There are 2 possibilities:
- using standard hose clamps
----> Supply line to the water tank on the driver's side.
- with quick-connect fitting; supply line to the water tank on the passenger side.
klahaui
Avatar-klahaui
Post21-07-2012, 20:12    Subject: Heat Exchanger A3 8L: Supply & Return Quote
You're welcome.
For me, they are clamp connectors.
Translated on 17-08-2026, 8:46.
This topic is locked, you cannot edit or reply. Color for upstream and downstream at the tank sensor? Diesel Engine Technology
No new posts Was kann den Rücklauf in den Tank blockieren? Diesel Engine Technology
No new posts Polo 6N Heat Exchanger Transmission, Chassis, Body & Interior
No new posts Oil-Water Heat Exchanger Retrofit, MKB AGR Diesel Engine Technology
