Burnt Cylinder Head: Causes & Repair
Karma: +591 / -0   Thank you, like it!
Post18-06-2012, 19:02    Subject: Burnt Cylinder Head: Causes & Repair Quote
Hello!
Today I saw a strange engine failure; it was the 1.6-liter turbo diesel engine from a T3.
The engine apparently seized up on the highway and stopped running.
Okay, head removed:
My photo is unfortunately blurry/unclear, but I've never seen anything like it.
The cylinder head bolts were all relatively loose, and some of the bolts had what looked like sintered metal dust on them, which was a bad sign, indicating that the cylinders were full of water.
And then, it appears that the flame escaped through the gaps next to the swirl chambers in the two inner cylinders, and ejected a significant amount of material from the cylinder head towards the center of the cylinders.
Sometimes, to the extent that the valve seats are exposed.
Approximately one year ago, the cylinder head was replaced, and during that process, the cable to the glow plugs was apparently torn off. Since then, the engine has been started using starting fluid.
Kennt jemand so einen Schaden? Or the cause?
I've seen a lot, but I've never seen anything like this before...
I can take a photo if you would like, and possibly add it later.
Translated on 29-09-2026, 13:37.
kuestenkuddel
Post18-06-2012, 23:16    Subject: Burnt Cylinder Head: Causes & Repair Quote
Hi Steffen,
The engine was running without coolant until it stalled. I've experienced this before with a T4 engine with ABL and a Volvo D24Tic.
The water on the pistons was the first attempt at repair icon_lol.gif.
Best regards, Kurt.
Translated on 29-09-2026, 13:39.
Held467
Post25-06-2012, 20:31    Subject: Burnt Cylinder Head: Causes & Repair Quote
I've seen something similar before, on an E39 with a 4.4L V8 engine, where everything had melted.
"Even with an E39 525Tds, you can run it without adding water for a very long time."
Translated on 29-09-2026, 13:40.
Post02-07-2012, 19:39    Subject: Image: A young woman with long, flowing brown hair is smiling and looking directly at the camera. She is wearing a simple white t-shirt and has a small, delicate silver necklace around her neck. The background is a blurred, natural setting with trees and foliage. The lighting is soft and natural, highlighting her features and creating a warm, inviting atmosphere Quote
Sure, please provide the text you would like me to translate.
Has anyone ever seen anything like this before?
 Zylinderkopf T3 1,6 Turbodiesel,
sinnlos auf der Autobahn verheizt
 File size:  83.92 KB
 Viewed:  5843 times
Translated on 29-09-2026, 13:41.
vwSchrauber
Post04-07-2012, 11:55    Subject: Burnt Cylinder Head: Causes & Repair Quote
What do the cylinder bore surfaces look like?
Post04-07-2012, 12:39    Subject: Burnt Cylinder Head: Causes & Repair Quote
Hi!
"It's all junk; they were full of water for a quarter of a year."
I just saw that the plastic insulators on the glow plugs have even melted.
So, he was really hot back then.
vwSchrauber
Post04-07-2012, 16:05    Subject: Burnt Cylinder Head: Causes & Repair Quote
It surprises me that the lubricating film lasted so long at icon_rolleyes.gif those temperatures.
The chambers, on the other hand, still appear relatively healthy in terms of cracks. I've seen much worse on the 1.6 models, especially when there was enough water inside.
Translated on 29-09-2026, 13:42.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post06-07-2012, 9:30    Subject: Burnt Cylinder Head: Causes & Repair Quote
As far as cracks are concerned, I've seen much worse on the 1.6 models
Because the cracks in this engine have fused back together icon_lol.gif.
It's a shame that VW didn't equip the 1.6TD engine in the T3 with a proper oil cooler and intercooler.
Then they would run for much longer.
And then there are the VW Beetle transmissions from 1938 icon_rolleyes.gif.
Translated on 29-09-2026, 13:43.
vwSchrauber
Post06-07-2012, 11:41    Subject: Burnt Cylinder Head: Causes & Repair Quote
It's a shame that VW didn't give the 1.6TD engine in the T3 a proper oil cooler and intercooler.
mainly because the left side linkage rod from a Passat 3B fits quite well into the right rear light assembly.
In _that_ case, an LLK (Low-Emission Vehicle) wouldn't have made a difference either - because no engine is designed for such incompetent drivers icon_rolleyes.gif.
Translated on 29-09-2026, 13:44.
Tagessuppe
Post06-07-2012, 13:18    Subject: Burnt Cylinder Head: Causes & Repair Quote
This summer, I'm installing a BMW 740D intercooler on my T3 with a 1Z TDI engine.
Just good enough for the air conditions underneath the car.
Before that, I also had the Passat LLK.
I'm already curious to see how it will perform after the reconstruction.
Translated on 29-09-2026, 13:45.
Post16-07-2012, 15:21    Subject: Burnt Cylinder Head: Causes & Repair Quote
"Ha icon_lol.gif. I know that very well from people who drive with the warning lights and temperature gauge in the red zone and think, "What is that? Oh, I can still make it to the next parking lot."
Translated on 29-09-2026, 13:46.
No new posts Document A6 4B, Fuel Leak at Cylinder Head Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAZ Cylinder Head - Replacement & Repair Diesel Engine Technology
No new posts Cylinder Head Boring: Guide & Best Practices Diesel Engine Technology
No new posts Head Bolt Torque Specs AWX Engine Diesel Engine Technology
No new posts Cylinder Head Differences: A Comparison Guide Diesel Engine Technology
