Hello!
I'm having a problem with my Lupo 6X where the central locking system, including the horn and turn signals, is randomly activating without any apparent reason.
I also tried disconnecting the interior sensor, hoping to finally get some peace, but unfortunately, this afternoon it started honking and flashing again.
Tuesday, August 7, 2012, 4:38:56 PM: 12188
VCDS Version: RKS 11.11.3
Data as of: 20120406
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 6X - VW Lupo
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
Vehicle Identification Number: WVWZZZ6XZ1W06XXX Mileage: :XXXX
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\045-906-019-AMF.clb
Part number: 045 906 019 S.
Component: 1.4L R3 EDC 0000SG 1208
Encoding: 00005
Operating number: WSC 01236
VCID: 2545A16DBFFA271
WVWZZZ6XZ1W06XXXX VWZ1Z0A1197496
2 errors found:
17978 - Motor control unit locked.
P1570 - 35-10 - - Intermittent.
17911 - Generator terminal DF overload signal.
P1503 - 35-00 - implausible signal.
Readiness: 0 0 X X X
Address 03: Brakes Label file: RKS\6X0-907-379.lbl
Part number: 6X0 907 379 B.
Component: ABS 30 IE CAN V004
Encoding: 05603
Operating number: WSC 01233
VCID: 43811FF5518EF91
"1 error found:"
00668 - Voltage at terminal 30.
16-10 - Signal out of tolerance - Intermittent.
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 601.
Part: 1R AIRBAG VW5 0006
Encoding: 12626
VCID: F0EB0039B0B8B29
"1 error found:"
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
Address 17: Combination instrument. Label file: RKS\6X0-920-xxx-17.lbl.
Part number: 6X0 920 801 D
Component: COMBINATION INSTRUMENT BOO V22
Encoding: 00132
Operating Number: WSC 00000
VCID: 36677621125C5C9
No error codes found.
Address 25: Immobilizer
Label file: RKS\6X0-953-257.lbl
Part number: 6X0 953 257.
Component: IMMO 0008
Encoding: 00001
VCID: FDF5290DF7EACF1
WVWZZZ6XZ1W066XXX VWZ1Z0A1197496
Address 35: Central Locking
Label file: RKS\1C0-962-258-II.lbl
Part number: 1C0 962 258 N
Component: 1N Central Locking System 0001
Encoding: 00257
VCID: 326F4A31FE34409
2 errors found:
00849 - S-terminal at the ignition switch (D)
25-10 - Undefined switch state - Intermittent.
01135 - Sensors for interior monitoring.
36-10 - Interruption - Sporadic.
Address 45: Interior Monitoring. Label file: RKS\6Q0-951-171.lbl
Part number: 6N0 951 171 D
Component: Interior monitoring system 0003.
VCID: 306B4039F038729
"1 error found:"
01463 - Alarm triggered by sensor for anti-theft system.
35-10 - - - Sporadically
After disabling the Sonsor interior monitoring system, it no longer appears in the vehicle scan, but the error is now present.
36-10 - Interruption.
saved.
Is there a way to remove this DWA?
A6 AFB
A6 BRE DPF
