Removing the Climatronic control unit from a Volkswagen Golf 3
Andy
Post11-04-2003, 18:49    Subject: Removing the Climatronic control unit from a Volkswagen Golf 3 Quote
What tricks and techniques should be considered to remove the Climatronic control unit as a component from the dashboard?
Best regards, Andy.
Translated on 19-07-2026, 20:46.
Varianti
Post14-04-2003, 15:13    Subject: Removing the Climatronic control unit from a Volkswagen Golf 3 Quote
What's the problem?
First, carefully pry off the control panel from all sides. Then, loosen and remove the four screws and pull it out. If that doesn't work, completely unscrew the frame (where the ashtray is located). This will give you easy access.
Actually, it's quite simple. I've never had any problems with it.
Translated on 19-07-2026, 20:47.
Andy
Post14-04-2003, 15:47    Subject: Removing the Climatronic control unit from a Volkswagen Golf 3 Quote
Thank you for the information.
Just wanted to check beforehand if anything is likely to break easily.
Broken plastic hooks are always annoying.
Best regards, Andy.
Translated on 19-07-2026, 20:48.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 2 Speedometer Removal: Guide & Instructions Transmission, Chassis, Body & Interior
No new posts Starter Motor Removal: VW Golf 3 Guide Diesel Engine Technology
No new posts Removing rear door panels on a Golf IV (5-door) Transmission, Chassis, Body & Interior
No new posts Climatronic control unit adaptation On-Board Diagnostics (OBD)
