Throttle valve - describing conditions
Post16-07-2003, 9:33    Subject: Throttle valve - describing conditions Quote
HI.
Can any of you TDI drivers with naturally aspirated engines describe the conditions you're experiencing?
- When you turn on the ignition, should it start automatically or should it already be in the "on" position?
- It is advisable to keep it on while the device is in operation.
- It will automatically close as soon as you stop it.
- Will she stay there? Or will she leave again?
As far as I know, it's closed by vacuum. Do all newer TDIs have a vacuum reservoir to keep this thing closed?
Thank you.
P.S. I'm considering buying my 1Z a SRK icon_wink.gif.
Translated on 20-07-2026, 23:34.
Post16-07-2003, 10:11    Subject: Re: Throttle valve - describe the condition Quote
dieselmartin wrote:
HI
In TDIs without (switchable) water-cooled EGR, the intake manifold flap is actuated by vacuum. For example, in the AXR engine, the intake manifold flap is actuated by an electric motor.
When the machine is stopped, the flap closes and then opens again about 5 seconds later. As far as I remember, the flap is always open (regardless of the system), but it briefly closes when the machine is stopped to reduce the impact of stopping.
Translated on 20-07-2026, 23:36.
PrivatBereich
Post16-07-2003, 10:17    Subject: Throttle valve - describing conditions Quote
The valve only needs to be open during operation and close for a few seconds at the moment when ignition is switched off. After that, the engine is already stopped, and it doesn't matter whether the valve remains closed or opens again, because the vacuum slowly leaks away.
The flap must definitely open again when the ignition is turned on (to start the engine), but whether it's already open beforehand doesn't matter.
Does the constant power cycling really bother you that much that you're willing to invest time and money into fixing it?
-Private
Translated on 20-07-2026, 23:38.
PrivatBereich
Post16-07-2003, 10:18    Subject: Throttle valve - describing conditions Quote
Oops, it seems Bertil was faster. And I apparently took over six minutes to write my answer... icon_redface.gif
Translated on 20-07-2026, 23:39.
Post16-07-2003, 10:54    Subject: Throttle valve - describing conditions Quote
Hmm, well, the really bad rattling comes from the tractor when it's running!
But an SRK would be really cool. I enjoy tinkering with things. And when it comes to the development history of TDIs, a 1Z engine still has a lot of potential for upgrades and modifications icon_smile.gif.
Is there anything cheaper than the AGR unit (which costs €100, as far as I'm aware)?
WarLord
Post16-07-2003, 16:45    Subject: Throttle valve - describing conditions Quote
What cool things can you build with a 1Z (assuming it's a specific type of device or component)? I can only think of adding a multi-function display and cruise control to my car, but those aren't related to the engine.
Best regards, WarLord.
Translated on 20-07-2026, 23:40.
Post17-07-2003, 7:38    Subject: Throttle valve - describing conditions Quote
On my G3, the first thing I did was use the already unlocked GPU (Graphics Processing Unit).
http://people.freenet.de/golf-schrauber/Billisch_GRA.jpg
With noise tuning, one could probably spend years working on a 1Z engine icon_eek.gif.
Greetings.
Translated on 20-07-2026, 23:41.
WarLord
Post17-07-2003, 13:28    Subject: Throttle valve - describing conditions Quote
Sound tuning on the 1Z? Probably not possible. But you're not really using the GRA (presumably referring to a specific feature or system), are you?
Translated on 20-07-2026, 23:42.
Post17-07-2003, 13:38    Subject: Throttle valve - describing conditions Quote
Meanwhile, I had the original sentence installed.
I only built this awesome version to test whether it's already unlocked, so I don't have to hear later that nothing works, etc.
I was really sweating when I first turned it on, worried that I might immediately damage the engine control unit icon_rolleyes.gif.
Currently, I'm working on an EGR valve cover that is intended for the 1Z engine.
"Before"
http://people.freenet.de/golf-schrauber/TDI_Motorraum.jpg
The new one:
http://people.freenet.de/golf-schrauber/TDI-Abdeckung.jpg
Translated on 20-07-2026, 23:43.
Kruegerjean
Post17-07-2003, 22:06    Subject: Throttle valve - describing conditions Quote
If you're looking for noise reduction in a G3 TDI, I have a tip for you.
I placed a felt mat between the engine compartment and the splash guard. Of course, I cut it appropriately to accommodate the steering linkage, etc. I attached the mat to a metal strip that runs approximately across the middle of the engine compartment and is fastened to the body with bolts on both ends. It essentially covered the entire engine. Unfortunately, I don't have any pictures of it because I no longer own the car, but it did make a difference...
Greetings.
Jean.
Translated on 20-07-2026, 23:44.
WarLord
Post18-07-2003, 13:34    Subject: Throttle valve - describing conditions Quote
@dieselmartin
How much did the steering wheel control cost you?
Translated on 20-07-2026, 23:46.
Post18-07-2003, 13:38    Subject: Throttle valve - describing conditions Quote
Thank you for the tip, Jean.
While I can't quite picture it, the TDI engine in the G3 already has a pad on the firewall. This part, which has an aluminum coating in the middle and an aluminum rail, is designed to prevent the brake line from getting too much heat.
In addition, I installed the soundproofing pads in the water tank, which are supposedly standard equipment on the TDI models, but were naturally missing from mine.
But my tractor makes a sound more like something is catching or large masses are being moved.
When the engine is idling, it sounds normal from the outside, and when you put your head inside (e.g., through the open door), a dull rumbling sound is added to the noises icon_evil.gif.
The AGR cover is (almost entirely) just for show – although it's very elaborately lined with soundproofing material on the inside.
Translated on 20-07-2026, 23:47.
Post19-08-2003, 11:32    Subject: Throttle valve - describing conditions Quote
Oops, I still owe you an answer.
It didn't cost me anything because I opted out of the included GRA installation when I bought it.
As far as I know, there's an aftermarket kit available for around €75. It should include everything you need.
In my car's engine control unit (ECU), the Graphics Processing Unit (GPU) function was already unlocked, which is why my cheap GPU worked.
Here's an invoice from someone else:
http://people.freenet.de/golf-schrauber/gra.jpg
Translated on 20-07-2026, 23:49.
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle valve 2 for 3.0 V6 TDI Diesel Engine Technology
No new posts BLS intake flap Upload
No new posts ALH Intake Manifold Flap Problem & Fix Diesel Engine Technology
No new posts Ansteuerung N239 Saugrohrklappe On-Board Diagnostics (OBD)
