Checking parking distance control (PDC) sensors
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post26-09-2012, 23:31    Subject: Checking parking distance control (PDC) sensors Quote
If you don't have a diagnosis readily available, you can still use your hearing to help.
Intact PDC sensors emit a "clicking" sound at a relatively fast frequency.
If someone remains silent, there's a 90% chance you've found the culprit.
Maybe it will help someone or another at some point icon_wink.gif.
Greetings.
Post27-09-2012, 9:17    Subject: Checking parking distance control (PDC) sensors Quote
Are the other, non-defective ones activated when one fails?
Not that they will all be shut down in the event of a problem. And then it becomes impossible to distinguish between the living and the dead.
Because I was just about to suggest positioning yourself in a way that the PDC (Parking Distance Control) doesn't "see" you, and then using your hand to deliberately "cover" individual sensors. The defective item will not report anything.
However, for this to work, the system itself must remain active even if a sensor is not cooperating.
klahaui
Avatar-klahaui
Post27-09-2012, 11:47    Subject: Checking parking distance control (PDC) sensors Quote
It's not possible to simply disable it manually or similar, because if a sensor is defective, the entire system shuts down, but the sensors that are still working will continue to emit that sound.
Post27-09-2012, 12:24    Subject: Checking parking distance control (PDC) sensors Quote
Ah, okay.
Okay, I'll try to capture the tone.
klahaui
Avatar-klahaui
Post27-09-2012, 13:41    Subject: Checking parking distance control (PDC) sensors Quote
I tried comparing VAG vehicles, BMW, and Kia, and they all seem to have the same sound.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sensor Characteristics: Initial Values & Data On-Board Diagnostics (OBD)
No new posts AGT sensors on 2.0 TSI engines? Gasoline Engine Technology
No new posts ABS Sensors VW Golf 3 On-Board Diagnostics (OBD)
No new posts das Sensoren Verkaufsprogram Diesel Engine Technology
