Temperature flap actuator (V158) or G220
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
anywhere
Post22-07-2012, 23:37    Subject: Temperature flap actuator (V158) or G220 Quote
Hi everyone,
I'm currently experiencing an issue where the aforementioned actuator motor in my Passat is no longer finding its correct value and is constantly adjusting, resulting in a noisy sound inside the dashboard.
Approximately nine months ago, the V158 occasionally reported errors in the error memory. After re-pairing, it worked correctly for about six months, but now it's showing errors again (of course, with constant engine adjustments).
"The car will be going to the workshop soon to have the problem fixed under warranty. However, I'm now wondering if they should replace the second actuator motor at the same time. According to VW, that part costs about €108... That's a lot of money to replace something just based on suspicion..."
I've attached two diagrams (sorry for the photo – I can't seem to find the original file). To me, the G221 looks perfectly fine; a little adjustment is allowed, and it reaches the final values immediately without any fluctuations.
What do the experts say? Should you invest the extra €110 or hope that he doesn't give up?
Thank you very much and best regards,
Marco.
 G221 - okay?
 File size:  100.39 KB
 Viewed:  8810 times
 G220 - offensichtlich defekt
 File size:  115.01 KB
 Viewed:  6578 times
Translated on 20-07-2026, 21:49.
Georg-TDI
Post17-10-2012, 10:57    Subject: Temperature flap actuator (V158) or G220 Quote
Hello Marco.
Currently, I'm experiencing the same problem with my Passat (as indicated in my profile) related to part number V159.
'Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag.'
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day.
01810 - Temperature flap actuator, right side (V159).
000 - - - Sporadic
Environmental conditions:
Error status: 00100000
Error priority: 3
Error frequency: 8
Lost Count: 14
It's really annoying when the servo motor constantly oscillates around its target value.
Re-calibrating the end stops no longer helps.
The log shows a similar picture to what you're seeing with your V158.
Could you please post the part number for the stepper motor here?
I want to change it myself. The right side is also easier than the left.
Thank you.
Georg
Translated on 20-07-2026, 21:53.
anywhere
Post18-10-2012, 2:10    Subject: Temperature flap actuator (V158) or G220 Quote
Hi Georg,
Code:
ERSATZTEILE:                           Preisliste gültig ab: 01.06.2012
DVN   TEILE-NUMMER   TEILE-BENENNUNG                 ANZ  EUR/ST EUR
10131 (3C1907511F    STELLMOTOR TEMP.-REGELKLAPPE L. 1           64,50
That's exactly what it says on my cost estimate. Google says that the part number seems likely icon_wink.gif.
Marco.
Translated on 20-07-2026, 21:56.
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Stellmotor für Temperaturklappe Transmission, Chassis, Body & Interior
No new posts Passat 3B temperature flap control motor On-Board Diagnostics (OBD)
No new posts Check temperature flap or servo motor - Audi Coupe Transmission, Chassis, Body & Interior
No new posts Temperature flap servo motor - no target value? (V159, ri... Transmission, Chassis, Body & Interior
