Document startup issues, adjusting initial quantity (Solution)
Michael II
Post10-05-2002, 16:46    Subject: Document startup issues, adjusting initial quantity Quote
If the engine starts easily with the temperature sensor disconnected, it is possible that the calculated fuel injection amount is insufficient.
This can be adjusted using a diagnostic device.
(This feature is not available on all control units.)
"For this, use a diagnostic tool (e.g., 1551, 1552, VAS, or VAG-Com...)"
to access the engine control unit.
Perform a login using the code 12233.
Select "Function Adaptation".
In channel 5 (initial value), the value can now be adjusted upwards.
This results in a slightly increased initial amount.
Specifically, PD motors require a starting speed of at least 500 RPM. If this is not achieved, check the starter and battery.
Tschüss
Michael II
Ratings - Document startup issues, adjusting initial quantity
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Startmenge erhöhen Diesel Engine Technology
No new posts Increase initial fuel quantity with VAG-COM on A6 V6 TDI Diesel Engine Technology
No new posts Exact meaning of starting amount (MWB 5, 2) On-Board Diagnostics (OBD)
No new posts Increase Startup Amount with Diagnostic Tool Diesel Engine Technology
