Load-Dependent Brake Force Limiter Golf III
Vasmodis
Post15-04-2003, 22:15    Subject: Load-Dependent Brake Force Limiter Golf III Quote
The Volkswagen Golf III has a pressure-dependent and a load-dependent brake force distribution system, depending on the model. As far as I understand, that's all clear.
Now, there are two different (but similar) part numbers for load-dependent braking force regulators, is there also a technical difference? icon_rolleyes.gif
VAG 1HO 612 151 C for models with disc brakes (BOSCH 0204131***).
VAG 1HO 612 151 for models with drum brakes (BOSCH 0204131***).
No differences were observed on the brake testing equipment at VW (regarding the conversion of disc brakes from a VR6 to a GOLF III TDI (1Z) using 4-hole discs).
Visually, there is no difference to be observed.
Thank you.
Vasmodis.
Translated on 19-10-2026, 4:04.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Funding start dependent on the amount of funding Diesel Engine Technology
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
