Engine Swap: Is It Possible?
schlauchdruide
Post26-01-2014, 20:04    Subject: Engine Swap: Is It Possible? Quote
The original engine is a 2.0L TDI with engine code BPW, from an Audi A4, manufactured in 2006.
The engine to be installed is a 2.0L TDI with engine code BMN, from a VW Passat manufactured in 2006.
My question:
Audi crankshaft position sensor (CKP) located in the engine block, sensor wheel on the crankshaft.
Passat OT sensor on the front cover, clutch side; sensor disc inside the front cover.
Can the OT (output torque) signal from the BMN motor be processed in the Audi?
Thank you in advance for your help.
Translated on 06-10-2026, 20:44.
mullemaus
Post26-01-2014, 21:44    Subject: Engine Swap: Is It Possible? Quote
It is processed by the engine control unit. You need to install this (in addition to the engine wiring harness), and then it will work. icon_wink.gif
Translated on 06-10-2026, 20:45.
schlauchdruide
Post26-01-2014, 22:31    Subject: Engine Swap: Is It Possible? Quote
Thank you for the response.
But that's exactly what I wanted to avoid.
The BPW Audimotor receives two signals per kilowatt revolution (two tooth gaps offset by 180 degrees on the encoder disc).
I have no idea about the BMN Passat engine.
Translated on 06-10-2026, 20:46.
mullemaus
Post26-01-2014, 22:37    Subject: Engine Swap: Is It Possible? Quote
Thank you for the answer.
Regarding the BMN Passat engine, I have no idea.
You don't need any special knowledge. Just install the wiring harness and control unit that are compatible with the engine, and everything will work icon_wink.gif.
Translated on 06-10-2026, 20:47.
schlauchdruide
Post26-01-2014, 22:50    Subject: Engine Swap: Is It Possible? Quote
Okay, then I will do it that way.
Thank you again.
chriskross
Post27-01-2014, 8:26    Subject: Engine Swap: Is It Possible? Quote
If you modify the engine control unit (ECU), you will likely encounter problems with the immobilizer system, and the programming process will not work.
A6 AFB
A6 BRE DPF
Translated on 06-10-2026, 20:48.
schlauchdruide
Post27-01-2014, 11:25    Subject: Engine Swap: Is It Possible? Quote
I think I'm going to sit down again and carefully consider whether it wouldn't be more sensible to have the engine repaired.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post27-01-2014, 14:45    Subject: Engine Swap: Is It Possible? Quote
Audi/VW will certainly adjust that for you at a very affordable price icon_wink.gif.
chriskross
Post27-01-2014, 21:18    Subject: Engine Swap: Is It Possible? Quote
klahaui wrote:
Audi/VW will certainly adjust that for you at a very cost-effective price icon_wink.gif
The only option is to turn off the WFS (Immo OFF) icon_smile.gif, and then it should work. However, it needs to be tested to see how compatible the other control units are, such as the gateway, combination instrument, ABS, and ESP. You would also need to check the CAN BUS IDs, etc.
A6 AFB
A6 BRE DPF
Translated on 06-10-2026, 20:49.
klahaui
Avatar-klahaui
Post27-01-2014, 22:20    Subject: Engine Swap: Is It Possible? Quote
Certainly, Audi can use the tester to reprogram the immobilizer icon_wink.gif.
mullemaus
Post28-01-2014, 0:27    Subject: Engine Swap: Is It Possible? Quote
Yes, Audi can use the tester to reprogram the immobilizer icon_wink.gif.
Since there are different performance levels, I wouldn't generalize it like that. icon_lol.gif icon_cool.gif icon_wink.gif
Translated on 06-10-2026, 20:50.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 2.0 TDI Engine Swap: Guide & Tips On-Board Diagnostics (OBD)
No new posts AEE engine conversion Gasoline Engine Technology
No new posts Engine Swap AFB to AKN Diesel Engine Technology
No new posts Kombiinstrument+Motorumbau On-Board Diagnostics (OBD)
