P2563 - Positionsgeber für Ladedrucksteller: unplaus. Signal (Solution)
Post03-02-2016, 12:23    Subject: P2563 - Positionsgeber für Ladedrucksteller: unplaus. Signal Quote
The error code P2563, "Boost pressure control valve position sensor - implausible signal," is set when the position feedback from the boost pressure control valve is not within the expected range. With our diagnostic systems HEX-NET and HEX-V2, you can easily identify this issue and conduct further troubleshooting. For other vehicle brands, we offer our OBD diagnostic system.
Possible causes:
- Faulty electrical wiring/connections to the position sensor.
- Faulty boost pressure control valve (e.g., the vacuum sensor does not hold a vacuum, or an electric actuator like those found in 3.0 V6 TDI engines is mechanically or electrically defective).
- The turbocharger's wastegate is stuck or difficult to move (the actuator cannot properly adjust the valve).
- Engine control unit (ECU) defective (due to water ingress or similar).
 Ladedrucksteller am 2.0 CR TDI CFFB
 File size:  214.62 KB
 Viewed:  104684 times
Translated on 23-07-2026, 10:46.
pitmeesta likes this.
Post14-02-2018, 20:08    Subject: P2563 - Positionsgeber für Ladedrucksteller: unplaus. Signal Quote
Slotti20 wrote:
Hello diesel mechanics,
I tried to reply to your article P2563, but I'm not a moderator. I wanted to add that this problem can also occur due to a fault in the vacuum system. In my case, it was a broken air connection on the vacuum actuator of the EGR valve in a T5 built in 2014 with a 2.0 TDI engine. This causes the vacuum actuator in the turbocharger control system to operate at its full range, and the sensor then reports an error. It starts with a flashing preheating indicator, followed by the engine check light illuminating.
Best regards, Slotti20
Thank you for the information! Yes, a lack of or incorrect vacuum pressure can also be caused by something else. You can use VCDS and the actuator test function to test the actuators in the vacuum system.
Translated on 14-08-2026, 21:43.
Ratings - P2563 - Positionsgeber für Ladedrucksteller: unplaus. Signal
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts P2563 Error: Turbocharger Overboost Fault (CR-TDI) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G581 Turbocharger Positioner: Find & Check Now Diesel Engine Technology
No new posts Help: 2.0 TDI P2563 - Boost pressure control valve, impla... Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Turbocharger Boost, Engine BMR Values Needed Diesel Engine Technology
