Gas Exhaust System for ARL Engine.
polo2f
Post28-12-2012, 15:03    Subject: Gas Exhaust System for ARL Engine. Quote
Hello.
I'm installing a diesel engine (ARL) into an Audi TT 8N and I'm currently working on the exhaust system. The system shouldn't be too loud, ideally the same volume as the stock exhaust. I'll be using the downpipe with the catalytic converter from the ARL engine. After the catalytic converter, I have three options. Which option makes the most sense? Considering the amount of work involved, I would prefer the 1.8T exhaust system. How does it look in terms of performance?
1. Complete ARL exhaust system. This will require me to close off both cutouts on the bumper for the exhaust tips.
2. 1.8T 225 HP exhaust system. Includes mid-section (MSD) and end silencer (ESD). Diameter: Up to the MSD 65 mm, after the MSD 60 mm.
3. 3.2-liter V6 exhaust system with valve control, where the valve control would not be active. Includes mid-section (MSD) and end silencer (ESD). Diameter: up to the MSD 65 mm, after the MSD 60 mm.
Paul.
Translated on 05-10-2026, 7:09.
Post28-12-2012, 15:17    Subject: Gas Exhaust System for ARL Engine. Quote
It would be advisable to plan ahead in this case.
Has anything been done or planned regarding the ARL to improve its performance?
Translated on 05-10-2026, 7:10.
polo2f
Post28-12-2012, 15:28    Subject: Gas Exhaust System for ARL Engine. Quote
Currently, it's a series production model. I'm not doing anything beyond that. I doubt you can achieve more than, say, 170 horsepower with standard components.
Translated on 05-10-2026, 7:11.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-12-2012, 23:29    Subject: Gas Exhaust System for ARL Engine. Quote
I would access the 63.5-inch system in the ARLschon if there's an option for a customizable tuning file.
reflexsilber met.
Post02-01-2013, 7:40    Subject: Gas Exhaust System for ARL Engine. Quote
polo2f wrote:
I don't do anything other than software. I think more than 170 horsepower won't be achievable with standard components, right?
Based on my experience, with the ARL hardware, you can expect about +30 horsepower, and torque up to approximately 420 Nm.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Ist Auspuffanlage TDI Motorkiller ????? Diesel Engine Technology
No new posts Golf TDI Exhaust: 110 kW Performance Upgrade Diesel Engine Technology
No new posts Exhaust Corrosion Protection: Tips & Solutions Transmission, Chassis, Body & Interior
No new posts Fahren ohne Auspuffanlage (kl. Erfahrungsbericht) Diesel Engine Technology
