22-09-2010, 16:57 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
HI.
Can someone explain the difference between the standard parts "1K0129618BQ" and "1K0129618BJ", or better yet, show me a picture?
The part number 1K0129618BJ is the "anti-kink intake manifold" connecting the throttle body to the air filter housing.
Thank you.
Translated on 14-08-2026, 16:32.
Profile PM Garage |
Profile PM Garage |
07-10-2010, 11:04 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
DrTek did it - THANK YOU!
| Description: |
| File size: |
77.3 KB |
| Viewed: |
3930 times |
Translated on 14-08-2026, 16:33.
Profile PM Garage |
Vatte
Joined: 05/06/2008 Posts: 9 Karma: +1 / -0 Location: Berlin
Registered VCDS User
03-05-2011, 21:48 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Hello dieselmartin,
As I see, you're working on the BLS again. What do you hope to achieve with this revision?
Another question is whether straightening the hose section, as well as the plastic pipe starting from the 90-degree bend above the alternator, would be beneficial. I'm hoping for a "faster" response at low RPMs and/or after gear changes.
For example, through the fraternal sharing of parts (see first suspect)...
"Vatte" translates to "father" in English.
| Description: |
| Habe mich mal an deinen Bildern bedient. ;-) |
| File size: |
124.68 KB |
| Viewed: |
5887 times |
Translated on 14-08-2026, 16:34.
03-05-2011, 21:58 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Hi.
I don't think the "bow" and the "accordion" make a difference.
In the 140 hp BMP Passat, they were even mixed and matched, with some having one type of component and others having a different type.
The "cotton" tube in the BLS (presumably referring to a specific device) primarily serves to dampen suction noises.
But our BLS doesn't whine; it only rumbles a bit when you really push it, meaning when you rev it up just above the minimum stable speed and then demand full torque.
Just typical for a city. But that's more likely due to this: https://community.dieselschrauber.org/en/viewtopic.php?t=25124&highlight=pendelst%FCtze
Translated on 14-08-2026, 16:36.
Profile PM Garage |
Vatte
03-05-2011, 22:10 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Okay, thank you.
I was almost certain that the flexible hose was more of a superficial improvement. If anything, one should probably opt for aftermarket parts from companies like Samco, or extend hoses taken from the BKC engine.
My question about the piece of paper was also answered well by Google.  What do we/I learn from this? First read, then post.
Besides that, I want to install the intake manifold and air filter housing from the VR6 models. This is also why I'm searching online again for information about intakes, and that's how I came across your thread.
| Description: |
| File size: |
748.85 KB |
| Viewed: |
2399 times |
Translated on 14-08-2026, 16:38.
03-05-2011, 23:02 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Why would anyone want to renovate something at the BLS?
The small turbocharger has the same "environment" as the 1.5 bar GT1749VC turbocharger with its boost pressure system. And even that one gets enough air thanks to it.
Then it's better to replace the air filter more often, even if the recommended replacement interval hasn't been reached yet.
Translated on 14-08-2026, 16:39.
Profile PM Garage |
Vatte
03-05-2011, 23:10 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
dieselmartin wrote: | | The small turbocharger has the same "environment" as the 1.5 bar GT1749VC turbocharger monster from BMR. |
At first glance (we've only had the 3C for a few days), I would say that at least the diameter varies. I want to modify it because the turbine has to do more work thanks to the adjusted engine control, which may alleviate some of its "suction effort." You probably know the background by heart, but I'll refer to it again for the other readers: https://community.dieselschrauber.org/en/viewtopic.php?t=6593.
Seat Altea 5P '05 BKC+
Seat Altea 5P '08 BLS+
Seat Exeo ST 3R '11 CAGC
VW Passat Variant 3C '06 BMR
VCDS
Translated on 14-08-2026, 16:41.
03-05-2011, 23:41 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Quote: | | that at least the diameter varies. |
What is the diameter?
Since BLS/BKC engines use counterflow designs and the BMR engine uses a crossflow design, the piping from the turbocharger onwards is significantly different anyway.
After the LMM (likely referring to a specific standard or regulation), both BLS and BMR have the same type of spring band attachment, so there won't be any difference between them in that regard.
A modified BLS will certainly not produce more suction than a standard BMR.
You won't be able to use parts from a 3C-V6 engine because it has the air filter where other models have the battery, which means you would need to relocate the battery, adding even more work.
Apparently, the same applies to the Volkswagen Golf 5.
http://tinyurl.com/644y6ar
Translated on 14-08-2026, 16:42.
Profile PM Garage |
Vatte
tokimo likes this. |
04-05-2011, 12:20 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
It seems I recall that the diameter up to the air filter box is larger on the BMR model. I'll measure it tonight to confirm...
I am aware of the battery in the trunk, and it's a side effect that I desire. The effort involved is clear, and the benefit is theoretically also clear, but it can't hurt either.
If I have the time, I would like to accompany this process with measurements. To that end, I have the option of using a MPST (Multi-Point Surface Temperature) sensor. In order for a "natural" charging effect to occur through the airflow, the charger can only provide supplemental power and potentially shift the smoke boundary. Common sense dictates that up/down and left/right movements are not conducive to good airflow.
VCDS
Translated on 14-08-2026, 16:44.
04-05-2011, 13:07 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Quote: | | The diameter up to the air filter box is larger on the BMR. |
But the filters are identical – and they certainly offer more resistance than a small piece of pipe.
" Quote: | | "natural" charging via wind resistance | ".
"Take a look at this information about ramjets... Does your BLS already approach the speed of sound? Because that's when they start to work."
Quote: | | Common sense dictates that this up/down and right/left movement cannot be beneficial for the airflow. |
Wow, that's exactly how it is!
The "stuff" *before* the filter is extremely important for water separation. And if you look at the "dirt marks" inside, you can see that it works wonderfully.
The piping after the turbo is simply a consequence of using large front-mounted intercoolers.
However, they compensate for this with pleasant intake air temperatures of 4-18 Kelvin above the outside temperature.
A Volkswagen Golf 3 1Z with a ridiculously low 0.9 bar boost and only 90 horsepower already produces an exhaust temperature of 30 degrees Celsius above the ambient temperature.
I've also considered having a follow-up measurement for BLS-BMR.
Translated on 14-08-2026, 16:47.
Profile PM Garage |
Vatte
04-05-2011, 13:53 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
dieselmartin wrote: | | But the filters are identical - and they certainly offer more resistance than a bit of pipe. |
Okay, and I don't think the difference in diameter has anything to do with the air requirement. Due to the combustion principle, there is already an excess of air. And regarding the identical box, I want to convert it to the 3.2-inch size because it won't be mounted transversely to the direction of travel, it will be larger and therefore not the first bottleneck.
dieselmartin wrote: | | Especially the "stuff" BEFORE the filter is very important for water separation. And if you look at the "dirt marks" inside, it works wonderfully. |
"Also, that's also correct, but the water separation system exists and functions properly in both the 3.2-liter and 3.6-liter engines."
dieselmartin wrote: | | I've also had BLS-BMR measurements done before. |
Okay, then we can put our measurement skills to the test and compare the results. We might also uncover other changes that are specific to different model years.
VCDS
Translated on 14-08-2026, 16:51.
04-05-2011, 14:08 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Build it yourself  .
But take lots of pictures so we have something to look at!
Translated on 14-08-2026, 16:53.
Profile PM Garage |
Vatte
04-05-2011, 16:43 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Sure, I will.
Even though here, here it is about a naturally aspirated gasoline engine with indirect ignition, the content is quite interesting and may be partially applicable.
VCDS
04-05-2011, 20:25 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Quote: | That's also correct, but the water separation system exists and functions for both the 3.2-liter and 3.6-liter engines.
Quote: | | Even though this concerns a naturally aspirated gasoline engine with indirect injection, the content is quite interesting and may be partially applicable. |
And that's exactly when the water separation  stops.
Translated on 14-08-2026, 16:54.
Profile PM Garage |
19-02-2013, 9:30 Subject: 1K0129618BJ Part Photo: Buy Online Now! |
Okay, please provide the text you would like me to translate from German to English. I will only provide the translation.
Since the front of the vehicle was completely disassembled anyway, I also decided to replace the exhaust pipe on the tractor.
We never really had the classic "kauderwelsch," but he wasn't exactly quiet either.
With the new pipe, I believe that certain noises have disappeared.
- This gurgling/glugging sound at idle
- Accelerating from a constant speed in the city now only produces torque noise, but nothing that suggests increased intake.
Problem:
The pipe consists of a solid section and a "padded" section.
The transition is a kind of collar.
This fin is only a few millimeters away from the fan housing.
(Photo follows)
I still need to clarify whether there will be any physical contact involved.
Translated on 14-08-2026, 16:56.
Profile PM Garage |
