Customize Audi S4 B7 Startup Screen to "S4"
Go to page: 1, 2  Next
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
dave81
2005 Audi A3
Post28-02-2013, 11:27    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Morning.
Here's the translation:
"My brother has a problem with his S4 B7. We replaced the original RNS-E 192 with a unit ending in 193G. We copied the coding from the original radio, and so far everything seems to be working fine. However, the S4 start screen isn't displaying. It's coded into the radio, but instead, the standard Audi MMI start screen is showing."
Does anyone have any idea what might be causing this?
The two errors listed under address 37 have already been resolved – the necessary adjustments have been made.
Log-OB SX 42-WAUZZZ8E96A238267-115360km.txt
 File name:  Log-OB SX 42-WAUZZZ8E96A238267-115360km.txt
 File size:  8.54 KB
 Downloaded:  1727 times
Translated on 21-08-2026, 22:11.
Post28-02-2013, 12:26    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Hi there,
Have you tried using a plausible operating number with the encoding?
Translated on 21-08-2026, 22:12.
dave81
2005 Audi A3
Post28-02-2013, 13:15    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Roger wrote:
Have you ever tried the encoding with a plausible operating number?
No, I must also admit, to my shame, that I'm not very familiar with that topic. Perhaps you could explain it to me in more detail?
Dave
Translated on 21-08-2026, 22:13.
dieselschrauber likes this.
Post28-02-2013, 13:43    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
You took WSC 00001 001 00001.
I would have probably used the waste spark coil from the engine control unit instead.
Translated on 21-08-2026, 22:14.
Post28-02-2013, 17:26    Subject: Customize Audi S4 B7 Startup Screen to "S4" Translating...
[Translating...]
dave81
2005 Audi A3
Post01-03-2013, 11:34    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Good morning.
Thank you both very much. I will test it during the day and write some feedback about it.
Certainly! Here's the translation:
"Thank you very much."
David.
Translated on 21-08-2026, 22:15.
Post01-03-2013, 11:49    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Serial number: 00000000000000
Quite an unusual odometer reading. icon_wink.gif Tampered with? If so, who knows what has been altered.
Please post the `coding.log` file so that we can see what code was generated.
dave81
2005 Audi A3
Post01-03-2013, 16:47    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Tampered with? If so, who knows what has been ;-)altered.
Best regards, Rainer
Hello Rainer,
We weren't aware of that. The vehicle was purchased from a large Audi dealership at the time. During a problem with the xenon headlights or headlight range adjustment, the dealership updated the instrument cluster (IC).
Unfortunately, there has been no success yet regarding the startup screen. The device ID has been adjusted, first to the one from the old radio and then to the one from MSTG.
The logs are attached.
CodingLog.TXT
 File name:  CodingLog.TXT
 File size:  17.13 KB
 Downloaded:  612 times
Log-OB SX 42-WAUZZZ8E96A238267-115500km.txt
 File name:  Log-OB SX 42-WAUZZZ8E96A238267-115500km.txt
 File size:  16.31 KB
 Downloaded:  762 times
Translated on 21-08-2026, 22:17.
Post01-03-2013, 17:45    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
"8P0035193G is for the A3 / A3 Sportback models, and it simply won't have the S4 logo on it."
Translated on 21-08-2026, 22:18.
dave81
2005 Audi A3
Post01-03-2013, 17:52    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Okay, that was modified using parts from an Audi A4. The radio is completely reprogrammed for an A4. Shouldn't it still work even if the system says: "I am an A3 component"?
Is there no way to do that?
Translated on 21-08-2026, 22:19.
Post01-03-2013, 21:18    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
...why should it? I guess things won't progress much further here.
dave81
2005 Audi A3
Post01-03-2013, 21:33    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
And what are you basing that on?! Sorry, maybe I'm mistaken, but the components are always the same regardless of whether it's an A3, A4, TT, etc. You can even code a Lamborghini startup screen into an Audi (just an example), so why wouldn't it be possible to have an S4 startup screen in an S4? The radio is already coded for an A4.
Translated on 21-08-2026, 22:20.
Post01-03-2013, 22:04    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
The hardware might be the same or very similar, but the software on the device will not be identical.
Reprogramming an RNS-E for an A4 to function as if it were in an S4 will definitely be a much more promising endeavor. icon_wink.gif
Translated on 21-08-2026, 22:21.
dave81
2005 Audi A3
Post01-03-2013, 22:44    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Reprogramming an RNS-E for an A4 to function as an S4 will definitely be a much more promising endeavor. icon_wink.gif
Well, it's not impossible. A friend of mine from Berlin did the conversion on his RS4 and it worked. He also installed a 193G ECU from an A3. However, it seems that it works for some people but not for others.
Translated on 21-08-2026, 22:22.
Post01-03-2013, 22:49    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
What do part numbers even mean for electronic components?
Same part number, but with different software installed, and it's something completely different.
A good example is the RCD510 – the part number is the same, but one version has white buttons on the touchscreen while the other has black ones.
And now try to change it... but you can't.
So, keep up the good work with your constant complaining, even though you can't seem to achieve anything.
Translated on 21-08-2026, 22:23.
Post01-03-2013, 23:12    Subject: Customize Audi S4 B7 Startup Screen to "S4" Quote
Visit contacts in Berlin. He seems to have the right skills to obtain missing data... If nothing more useful comes up, I suggest we proceed with this option here.
Translated on 21-08-2026, 22:24.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 2.5 TDI error code "00575 intake manifold pressure" Diesel Engine Technology
No new posts Audi 100 "Keilriemen" wechsel - heute als Notfall Diesel Engine Technology
No new posts Audi A6 Battery Problem: Weak Battery Warning Light Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Diesel Engine Technology
