Set readiness
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Faxe
Post30-04-2013, 10:09    Subject: Set readiness Quote
I'm having a problem with a Polo 9N2, engine code AZQ.
He keeps complaining about the cat's effectiveness, sometimes for months without any yellow light.
Every three days, of course, and today is one of those days, as I have a TÜV appointment at 3:00 PM.
After clearing the error, you typically need to drive at least 100 km before the 'Readiness' indicator comes back on.
I saw that it's possible to set a 'readiness' status. Which script do I need for that?
Here's the error.
Monday, April 29, 2013, 12:10:52:32621
VCDS Version: RKS 11.11.5
Address 01: Engine, File name: RKS\03E-906-033-AZQ.lbl
Control unit part number: 03E 906 033.
Component and/or version: 1.2l/4V SIMOS3 00HS4340
Encoding: 00071
Operating number: WSC 00788
Extended information: WVWZZZ9NZ2Y058252 VWZ7Z0A4734618
VCID: DDB4BCE9574E63F0EAA
'1 error found:'
16804 - Catalytic converter system; Bank 1.
P0420 - 35-00 - Insufficient effect.
Readiness: 0000 0001
After deletion:
Vehicle type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
Vehicle Identification Number: WVWZZZ9NZ2Y058252 Mileage: 117,340 km
'Der schnelle braune Fuchs springt über den faulen Hund.'
Address 01: Engine Label file: RKS\03E-906-033-AZQ.lbl
Part number: 03E 906 033.
Component: 1.2L/4V SIMOS3 00HS4340
Encoding: 00071
No error codes found.
Readiness: 0000 0101
Do you have any ideas?
Faxes.
Karma: +796 / -0   Thank you, like it!
Post04-05-2013, 9:29    Subject: Set readiness Quote
The following is provided without warranty; please test it on the engine control unit.
- Engine idling, basic settings 071 and 070 (EVAP test).
- increased engine speed*, basic setting 034 and 036 (O2 sensors), basic setting 046 (catalytic converter)
- Engine idling, basic setting 077 (secondary air).
* In the basic settings dialog, click the [On/Off/Next] button at the top, then press both the brake and accelerator pedals simultaneously. The engine control unit then increases the engine speed.
If there is no [On/Off/Next] button, maintain the speed at approximately 2500 rpm by using the accelerator pedal.
Please provide feedback.
Faxe
Post12-05-2013, 15:27    Subject: Set readiness Quote
Hello Rainer,
The sizes 34/36/46 fit perfectly, and they also have the corresponding [items/sizes].
Bits set in the readiness status.
70, 71, and 77 don't seem to be useful here.
Thank you for your help.
Faxes.
Post13-05-2013, 10:15    Subject: Set readiness Quote
Thank you for the feedback! So, is everything ready now?
No new posts Readiness-Codes On-Board Diagnostics (OBD)
No new posts An Werkstatt-Profis: Wie setzt Ihr den OBD-Readiness-Code? On-Board Diagnostics (OBD)
No new posts Reset ash mass to 0 On-Board Diagnostics (OBD)
No new posts Service Intervall zurück setzen bei UDS On-Board Diagnostics (OBD)
