Timing belt pulley, KW brand, worn out - AFN engine
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Upload
Kiko
Avatar-Kiko
1996 Volkswagen Golf
Post20-05-2017, 14:30    Subject: Timing belt pulley, KW brand, worn out - AFN engine Quote
Photos of a damaged AFN timing pulley:
 Gegenhalter für Zahnriemenrad an der Kurbelwelle
 File size:  92.77 KB
 Viewed:  1547 times
 File size:  141.72 KB
 Viewed:  1432 times
 File size:  150.26 KB
 Viewed:  1444 times
 File size:  131.52 KB
 Viewed:  1245 times
 File size:  172.83 KB
 Viewed:  1363 times
 File size:  176.26 KB
 Viewed:  1303 times
 File size:  169.12 KB
 Viewed:  1302 times
 File size:  176.8 KB
 Viewed:  1588 times
 File size:  181.76 KB
 Viewed:  1301 times
 File size:  127.46 KB
 Viewed:  1235 times
 File size:  133.43 KB
 Viewed:  10697 times
 File size:  182.8 KB
 Viewed:  1372 times
Translated on 05-07-2026, 19:36.
Karma: +642 / -0   Thank you, like it!
Post20-05-2017, 18:22    Subject: Timing belt pulley, KW brand, worn out - AFN engine Quote
These are images that I've seen in real life before. In these cases, solutions might include using a milling machine, replacing the crankshaft, or installing a "rebuilt" engine.
"Some people have already secured the rear wheel using a dowel pin, and the really dedicated ones have even welded it in place."
I would try using the end mill.
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spurstangendämpfung ausgeschlagen? Transmission, Chassis, Body & Interior
No new posts Knacken von der VA. Querlenkerlager ausgeschlagen? Transmission, Chassis, Body & Interior
No new posts Saugrohr-Halterung ausgeschlagen (1Z, AHU, AFN, ALE) Diesel Engine Technology
No new posts Zahnriemenrad festschweißen? Diesel Engine Technology
