Flexible Interval - Channel Meaning
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post05-04-2013, 16:35    Subject: Flexible Interval - Channel Meaning Quote
Hello!
I performed an oil change on my vehicle 3000km ago and reset it using VCDS in the routine. Everything is fine. When I look at the currently read data, I have a question about the meaning of channels 49, 50, 51, 52, 53, 54 and 55. Are these channels for fixed intervals? Do these also constantly change depending on time and distance, but are not read out by the control unit because it is coded for long life? Or what exactly is behind it?
Greetings
Brezelmann
2013_04_05Zwischenauslesung bei 50200KMLog-Log.txt
 File name:  2013_04_05Zwischenauslesung bei 50200KMLog-Log.txt
 File size:  2.42 KB
 Downloaded:  506 times
No new posts Tracking Channels: Which Ones to Log? On-Board Diagnostics (OBD)
No new posts VCDS 16.8.0: Channels Unavailable After Update On-Board Diagnostics (OBD)
No new posts ZR Interval: ASV & 120,000 km Diesel Engine Technology
No new posts Alarm Source Meaning A8 4E On-Board Diagnostics (OBD)
