Oil Temperature Gauge: Add-on Instrument
Tobias
Post03-05-2002, 9:11    Subject: Oil Temperature Gauge: Add-on Instrument Quote
Hello fellow diesel enthusiasts,
I would like to install an additional instrument to display the oil temperature.
Imagine a digital display (not an analog one with moving needles).
The level on the dipstick or drain plug.
Can you tell me where I can find something like that?
Thank you very much and greetings from Lake Constance.
Translated on 24-07-2026, 14:23.
Docter
Post03-05-2002, 10:14    Subject: Oil Temperature Gauge: Add-on Instrument Quote
either
on eBay
or D&W.
Or search for VDO, EQUUS, or RACIMEX.
You'll definitely find something. Just one question: Does the dipstick fit every vehicle?
Translated on 24-07-2026, 14:24.
oern
Post11-05-2002, 19:20    Subject: Oil Temperature Gauge: Add-on Instrument Quote
Hey!
Greetings from Lake Constance again.
What kind of car do you have and what engine does it have? That dipstick is useless; why don't you just install the sensor where the original one was located?
Translated on 24-07-2026, 14:25.
Tobias
Post13-05-2002, 6:16    Subject: Oil Temperature Gauge: Add-on Instrument Quote
I have an Audi A3 with an ASV engine.
Do you have any addresses for that?
Thank you and greetings from Lake Constance.
Asterix
Post13-05-2002, 23:45    Subject: Oil Temperature Gauge: Add-on Instrument Quote
Hello Tobias,
I built a digital oil temperature display myself.
You will need the following items:
1. Donor:
- Get a VDO oil pan gasket.
- Remove the NTC sensor and insert a PT1000 sensor (Heraeus Sensor Nite) with heat-resistant cable into the housing, filling the space around it with UHU Endfest 300 epoxy adhesive.
The adhesive is completely resistant to heat, aging, and oil!
I've been using this modified sensor in my TDI 110 HP engine for about 1.5 years now.
2. Advertisement.
The advertisement is for a 'Siemens Multifunction Display' and it's available at Conrad Electronics.
Since the display requires 5V, you'll need a voltage regulator.
Oh yes, you can also buy the Pt 1000 at Conrad!
Okay, that's all.
The ad is subtle and reliable, unlike those from companies like D&W and others.
Asterix.
Translated on 24-07-2026, 14:27.
Diesel-Dirk
Post15-05-2002, 9:29    Subject: Oil Temperature Gauge: Add-on Instrument Quote
I installed a thermometer with a 7-segment display from Conrad, and it runs on 12V.
I embedded the temperature sensor into an original VW housing (but using thermally conductive adhesive). This was necessary because the resistance curve of my sensor runs in the opposite direction to that of the VW sensor.
Translated on 24-07-2026, 14:29.
No new posts Oil Temperature: How to Check & Optimize Diesel Engine Technology
No new posts Oil Temperature: Where to Measure It? Diesel Engine Technology
No new posts Oil temperature sensor Diesel Engine Technology
No new posts What oil temperature is too high for the cylinder head ga... Diesel Engine Technology
