PD Injector Data: 3-Cylinder Engine Performance (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 20:30
Target data for measurement blocks in 3-cylinder engines with pump-nozzle injectors (PD)
Engine codes: AMF (Lupo 3L, Audi A2 3L) and ANY (Audi A2 1.2 TDI). Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value.
Measurement block 0 - Baseline values
FieldDescriptionAMF LLAMF VLANY LLANY VL
1Engine speed41..47134..15426..42134..154
2Start of injection117..9779..56126..11676..56
3Accelerator pedal position02550255
4Injection quantity11..37156..17511..29109..131
5Intake manifold pressure-177..21688..108161..210
6Atmospheric pressure--181..222181..222
7Coolant temperature80..3680..3680..3680..36
8Intake manifold temperature--190..51190..51
9Fuel temperature--85..17885..178
10Intake air mass60..96> 21054..87> 180
Measurement block 1 - Baseline values at idle
FieldDescriptionAMF LLANY LL
1Engine speed in RPM900..980800..880
2Injection quantity in mg/stroke3..103..8
3Delivery duration in °crank angle4..73..7
4Coolant temperature in °C80..11080..110
Measurement block 2 - Operating state at idle
2Accelerator pedal position in %00
3Operating state010010
Measurement block 3 - Air masses / EGR at idle
2Air mass setpoint in mg/stroke220..300200..270
3Actual air mass in mg/stroke200..320180..290
4EGR valve duty cycle in %30..8030..80
Measurement block 4 - Delivery start / Synchronization
1Engine speed in RPM900..9802800..3200800..8802800..3200
2Delivery start setpoint in °BTDC3..915..220..316..22
3Delivery duration setpoint in °crank angle4..717..244..615..23
4Synchronization angle in °crank angle-5..+5--3..+3-
Measurement block 5 - Starting conditions at idle
2Starting quantity in mg/stroke9..2013..18
3Start synchronization11
Measurement block 8 - Injection quantities at full load
FieldDescriptionAMF VLANY VL
1Engine speed in RPM2800..32002800..3200
2Injection quantity, driver demand in mg/stroke50..6545..51
3Torque limitation in mg/stroke43..4831..36
4Smoke limitation in mg/stroke46..5529..40
Measurement block 10 - Full load boost pressure
1Actual air mass in mg/stroke> 700> 600
2Atmospheric pressure in mbar-900..1100
3Intake manifold pressure in mbar1800..22001650..2140
4Accelerator pedal position in %100100
Measurement block 11 - Boost pressure control
2Boost pressure setpoint in mbar900..11001800..2100900..11001650..2100
3Actual boost pressure in mbar900..11001800..2100900..11001650..2140
4Boost pressure valve duty cycle in %25..9540..9525..9540..95
Measurement block 13 - Smooth running control at idle
1Smooth running regulator cylinder 1 in mg/stroke-2,8..+2,8-1,9..+ 1,9
2Smooth running regulator cylinder 2 in mg/stroke-2,8..+2,8-1,9..+ 1,9
3Smooth running regulator cylinder 3 in mg/stroke-2,8..+2,8-1,9..+ 1,9
Measurement block 18 - PD element status at idle
1PD element 1 status00
2PD element 2 status00
3PD element 3 status00
Source: community.dieselschrauber.org – Michael II
Translated on 09-08-2026, 10:07.
Ratings - PD Injector Data: 3-Cylinder Engine Performance
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts Measurement Data Blocks: Different Expected Values? Diesel Engine Technology
No new posts MKB AFB: Solldaten & Data Diesel Engine Technology
No new posts T5 AXE: Data Logging & Measurement Block Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
