Golf 6: RCD510 Coding Guide & Instructions
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post03-05-2013, 16:35    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
My helpful neighbor bought a used RCD510 on eBay and installed it in his new Golf. It seems to work mostly, but something related to the parking assist isn't working quite right because it was previously installed in a Sharan (?).
He asked me if I could code it appropriately.
I might have the necessary tool (VCDS), but I have absolutely no knowledge of how to program electronics beyond the core systems like the engine and steering.
Can anyone give me a few quick tips on how to properly code the RCD510 for use with a G6 vehicle?
Translated on 25-08-2026, 0:39.
Post03-05-2013, 18:19    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Hi Ulf,
It's always best to post a full car scan in these situations.
With a bit of bad luck, the RCD might have software that's compatible with the Sharan but not suitable for the new car. But first, let's see if we can make it work through coding.
Translated on 25-08-2026, 0:40.
Post03-05-2013, 20:31    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Okay, let's see when I can catch up with the neighbor about the car scan.
Translated on 25-08-2026, 0:41.
Post04-05-2013, 17:19    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Just now, I was able to run the car scan.
To begin with, the only apparent problem seems to be the incorrect top-down vehicle image displayed by the parking assistant, and that the parking assistant displays react very slowly, according to my neighbor's observation.
The Autoscan:
Code:
Samstag,04,Mai,2013,16:29:48:64765
VCDS Version: RKS 11.11.3
Datenstand: 20120406
Fahrzeugtyp: 7N0
Scan: 01 03 08 09 10 15 16 17 19 20 25 42 44 46 52 56 61 77
Fahrzeug-Ident.-Nr.: WVWZZZ1KZCW341164
01-Motor -- Status: OK 0000
03-Bremsen -- Status: OK 0000
04-Lenkwinkelsensor -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: OK 0000
10-Einparkhilfe 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: OK 0000
17-Kombiinstrument -- Status: OK 0000
19-CAN-Gateway -- Status: OK 0000
20-Fernlichtassistent -- Status: OK 0000
25-Wegfahrsperre -- Status: OK 0000
42-Türelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: OK 0000
46-Komfortsystem -- Status: OK 0000
52-Türelektr. Beifahr. -- Status: OK 0000
56-Radio -- Status: Fehler 0010
61-Batterieregelung -- Status: OK 0000
77-Telefon -- Status: OK 0000
Adresse 01: Motor (J623-CBZB)       Labeldatei: RKS\03F-906-070-CBZ.clb
   Teilenummer SW: 03F 906 070 GG    HW: 03F 907 309 S
   Bauteil: SIMOS10.13AH10 2653
   Revision: --H10---    Seriennummer: 00000000000000
   Codierung: 001900B6230401080000
   Betriebsnr.: WSC 01357 011 00200
   ASAM Datensatz: EV_ECM12TFS02103F906070GG 004004
   ROD: EV_ECM12TFS02103F906070GG_VW36.rod
   VCID: 6DDA1F00BC8ADF1
Readiness: 0000 0000
Adresse 03: Bremsen (J104)       Labeldatei: RKS\1K0-907-379-60EC1F.clb
   Teilenummer SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Bauteil: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Codierung: 113B200D092600FB880C04EA901D0050350000
   VCID: 7BFE2158FAFE411
Adresse 08: Klima/Heizung (J255)       Labeldatei: RKS\5K0-907-044.clb
   Teilenummer SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Bauteil: Climatronic   H18 1112
   Revision: 00001004
   Codierung: 0000004003
   ASAM Datensatz: EV_Climatronic A01010
   ROD: EV_Climatronic_VW36.rod
   VCID: 8004D6B41B18A29
Adresse 09: Bordnetz (J519)       Labeldatei: RKS\1K0-937-08x-09.clb
   Teilenummer SW: 1K0 937 086 N    HW: 1K0 937 086 N
   Bauteil: BCM PQ35  M+  110 0651
   Revision: 00110 AC
   Codierung: 40180A3A88251A90400800C8740081E44B510288636D8D60648087200041
   VCID: 3B7EE158BA7E811
   Subsystem 1 - Teilenummer: 5K1 955 119   Labeldatei: RKS\1KX-955-119.CLB
   Bauteil: Wischer 21041  26  0512
   Codierung: 009795
   Subsystem 2 - Teilenummer: 1K0 955 559 AH  Labeldatei: RKS\1K0-955-559-AG.CLB
   Bauteil: RLS 240412 05  54  0403
   Codierung: 0230AD
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei: RKS\3C8-919-475.clb
   Teilenummer SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Bauteil: PARKHILFE 8K  H01 0012
   Revision: --------    Seriennummer: 12561206600384
   Codierung: 108001
   VCID: 3874FE548B48AA9
Adresse 15: Airbag (J234)       Labeldatei: 5K0-959-655.clb
   Teilenummer SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Bauteil: AirbagVW10    013 0613
   Seriennummer: 003G5RAJLE1U
   Codierung: 00004431
   ASAM Datensatz: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_VW36.rod
   VCID: 3162C37060327B1
   Crashsensor für Seitenairbag Fahrerseite:
   Subsystem 1 - Teilenummer SW: 5K0 959 354     HW: 5K0 959 354
   Bauteil: S.Sens.Fahr.V  H01 ----
   Seriennummer: 3572MSME1E7A216EZZZ5
   Crashsensor für Seitenairbag Beifahrerseite:
   Subsystem 2 - Teilenummer SW: 5K0 959 354     HW: 5K0 959 354
   Bauteil: S.Sens.Beif.V  H01 ----
   Seriennummer: 3582MSME6C48226DZZZ4
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Bauteil: S.Sens.Fahr.H  --- ----
   Seriennummer: 3512QSME4E4D147DZZZ8
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Bauteil: S.Sens.Beif.H  --- ----
   Seriennummer: 3522QSME764A104BZZZZ
Adresse 16: Lenkrad (J527)       Labeldatei: 5K0-953-569.clb
   Teilenummer SW: 5K0 953 507 BB    HW: 5K0 953 549 D
   Bauteil: Lenks.Modul   008 0080
   Revision: --------    Seriennummer:  90440LDN0005B
   Codierung: 108A040000
   ASAM Datensatz: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS_VW36.rod
   VCID: 71E20370A0B23B1
   Steuergerät für Multifunktionslenkrad:
   Subsystem 1 - Teilenummer SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Bauteil: E221__MFL-TK6  H07 0022
   Seriennummer: 70000000000000484815
   Codierung: E20000
Adresse 17: Kombiinstrument (J285)       Labeldatei: RKS\5K0-920-xxx-17.clb
   Teilenummer SW: 5K0 920 872     HW: 5K0 920 872
   Bauteil: KOMBI         H03 0607
   Codierung: 170F01
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: ECDC92040790569
Adresse 19: CAN-Gateway (J533)       Labeldatei: 7N0-907-530-V2.clb
   Teilenummer SW: 7N0 907 530 N    HW: 1K0 907 951
   Bauteil: J533  Gateway H43 1623
   Revision:   H43       Seriennummer: 240412F1003117
   Codierung: 350002
Adresse 20: Fernlichtassistent (J844)       Labeldatei: RKS\8K0-857-511.clb
   Teilenummer SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Bauteil: FLA           H04 0012
   Revision: AA001002
   Codierung: 01018B6B74745D545420363E00
   VCID: 2D5ADF00740A1F1
Adresse 25: Wegfahrsperre (J334)       Labeldatei: 5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H03 0607
   Codierung: 000000
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD0941C0D64489
Adresse 42: Türelektr. Fahrer        Labeldatei: RKS\1K0-959-701-MAX3.lbl
   Teilenummer SW: 5K0 959 701 J    HW: 5K0 959 701 J
   Bauteil: Tuer-SG         009 2105
   Codierung: 0135222
   VCID: 3972FB507042B31
Adresse 44: Lenkhilfe        Labeldatei: RKS\1Kx-909-14x-44.clb
   Teilenummer: 1K0 909 144 P
   Bauteil: EPS_ZFLS Kl. 68     3305
   Revision: 00H22000
   VCID: 3776FD684656A51
Adresse 52: Türelektr. Beifahr.        Labeldatei: RKS\1K0-959-702-MAX3.lbl
   Teilenummer SW: 5K0 959 702 J    HW: 5K0 959 702 J
   Codierung: 0135478
   VCID: 3A70E45C7544B89
Adresse 56: Radio (J0503)       Labeldatei: Keine
   Teilenummer SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Bauteil: Radio RCD510  005 0234
   Revision: 00000001    Seriennummer: VWZ1Z3M7278263
   Codierung: 0500040004000D
   Betriebsnr.: WSC 00020 790 00000
   VCID: 244C3A2427C0DE9
2 Fehler gefunden:
00856 - Antenne; am Radio
            011 - Unterbrechung - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00101011
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 225
                    Kilometerstand: 1048575 km
                    Zeitangabe: 0
00821 - Antenne 2 für Radio (R93)
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 225
                    Zeitangabe: 0
Adresse 61: Batterieregelung (J840)       Labeldatei: RKS\1K0-907-534.clb
   Teilenummer SW: 7N0 907 534     HW: 1K0 907 951
   Bauteil: Batt.regelung H43 1623
   Codierung: 032F7864
   VCID: F1E2837028B2BB1
   Subsystem 1 - Teilenummer SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Bauteil: J367-BDM  H07 0180
Adresse 77: Telefon (J412)       Labeldatei: RKS\7P6-035-730.clb
   Teilenummer SW: 5K0 035 730 F    HW: 5K0 035 730 F
   Bauteil: TELEFON       H09 2902
   Revision: 1B001001    Seriennummer: 00007662298790
   Codierung: 0A00000000000001
   ASAM Datensatz: EV_UHVNA A01719
   ROD: EV_UHVNA_VW36.rod
   VCID: 28542E1453E83A9
Ende   --------------------------------------------------------------------
Translated on 25-08-2026, 0:42.
Post04-05-2013, 21:34    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Hello Ulf,
When you update to VCDS-RKS version 11.11.5, device information and coding information will be available for the device. According to your Autoscan, it appears that the checkbox is likely missing in byte 0 of the long coding for "Parking assist system installed."
Post05-05-2013, 10:46    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
dieselschrauber wrote:
If you update to VCDS-RKS 11.11.5, there is device information and coding information available.
Ah, thanks, good to know.
I will try it and get back to you icon_smile.gif.
Translated on 25-08-2026, 0:43.
Post05-05-2013, 19:20    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
1048575 km
Wow... Respect icon_mrgreen.gif.
Translated on 25-08-2026, 0:44.
Post05-05-2013, 19:28    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Hello Rainer,
When you update to VCDS-RKS 11.11.5, there is device information and coding information available for the device.
I have now updated to version 11.11.5, but the coding assistant still displays a message about missing STG information icon_sad.gif.
Is there a newer download of version 11.11.5 available? I saved mine a few months ago, but haven't installed it yet.
Here's another scan of the car, along with the extended ID using version 11.11.5:
Code:
Sonntag,05,Mai,2013,17:38:00:64765
VCDS Version: RKS 11.11.5
Datenstand: 20130111
Fahrzeugtyp: 7N0
   VCID: 6DDA1F00BC6D0370FAA
   Revision: 00H31001
   VCID: 7BFE2158FA199DC074E
   Revision: 00001004
   VCID: 8004D6B41BFF7E18A1C
   Revision: 00110 AC
   VCID: 3B7EE158BA995DC034E
   Codierung: 009795
   Codierung: 0230AD
   Codierung: 108001
   VCID: 3874FE548BAF76D8D9C
   Codierung: 00004431
   VCID: 3162C37060D5A7909E2
Adresse 16: Lenkrad (J527)       Labeldatei: RKS\5K0-953-569.clb
   VCID: 71E20370A055E790DE2
   Codierung: E20000
   Codierung: 170F01
   VCID: ECDC920407778A786D4
Adresse 19: CAN-Gateway (J533)       Labeldatei: RKS\7N0-907-530-V2.clb
   Codierung: 350002
   Revision: AA001002
   VCID: 2D5ADF0074EDC370BAA
Adresse 25: Wegfahrsperre (J334)       Labeldatei: RKS\5K0-920-xxx-25.clb
   Codierung: 000000
   VCID: EAD0941C0D8394481F8
   Codierung: 0135222
   VCID: 3972FB5070A56FD0262
   Revision: 00H22000
   VCID: 3776FD6846B179A0D06
   Codierung: 0135478
   VCID: 3A70E45C75A364C82F8
   VCID: 244C3A2427270238654
3 Fehler gefunden:
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 225
                    Zeitangabe: 0
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 225
                    Zeitangabe: 0
03138 - Eingang AUX IN
            011 - Unterbrechung
                    Fehlerstatus: 01101011
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 198
                    Kilometerstand: 3082 km
                    Zeitangabe: 0
                    Datum: 2011.14.08
                    Zeit: 16:26:29
   Codierung: 032F7864
   VCID: F1E28370285567905E2
   VCID: 28542E14530FE65849C
Code:
Sonntag,05,Mai,2013,17:33:14:64765
                Adresse 56: Radio
   Steuergerät-Teilenummer: 5K0 035 190 B
  Bauteil und/oder Version: Radio RCD510  005 0234
            Betriebsnummer: WSC 00020
Erweiterte Identifikation
     Identifikation: BVX-003
     Revision: 00000001
     Datum: 31.08.12
     Herstellernummer: 1052
     Prüfstandsnummer: 0301
Flash Status
     Programmierungs Versuche(Anwendung): 1
     Erfolgreiche Versuche(Anwendung): 1
     Programmierungs Versuche(Daten): 0
     Erfolgreiche Versuche(Daten): 0
     Programmierungs Status: 00000000
     Flash Datum: 0000.00.00
     Flash Tool Nummer: 00000 000 00000
     Flash Tool Nummer(Daten): 00000 000 00000
Software
     BAP: 01.04.01
     TP 2.0: 03.04.00
Sonstiges
     Hardwarenummer: 5K0 035 190 B
     Systemkurzzeichen: J0503
     Ausstattung/PR-Code: 0000000000000000
VCDS Info:
       Labeldatei: Keine
Translated on 25-08-2026, 0:45.
Post06-05-2013, 6:57    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Hello Ulf,
It's very strange. Could you please post the contents of the file "5K0-56.lbl" from the label directory and check if the file "5M0-035-1xx-56.CLB" is also located there?
Try using the value 0800040004000D instead of the current encoding 0500040004000D.
Translated on 25-08-2026, 0:46.
Post06-05-2013, 16:27    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Could you please post the contents of the file "5K0-56.lbl" from the label directory and check if the file 5M0-035-1xx-56.CLB is also in it?
So:
a) The file "5K0-56.lbl" is not available in my version 11115 installation; all files starting with "5K0" have a ".clb" extension.
b) The component "5M0-035-1xx-56.CLB" is present eight times.
Translated on 25-08-2026, 0:47.
Post06-05-2013, 17:30    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Hello Ulf,
I think there might be something wrong with your installation, like write protection or other issues.
If in doubt, delete everything except the "Log" and "Debug" folders and then re-compile it all.
Translated on 25-08-2026, 0:48.
Post06-05-2013, 17:53    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
If in doubt, delete everything except the Log/ and Debug/ folders and re-flash it.
Translated on 25-08-2026, 0:49.
Post06-05-2013, 18:24    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
Okay, I believe you. I made a typo; it should be 5K-56.lbl. That file contains the part number of the RCD without an index, and it redirects to the other file you mentioned.
"Please add the following line (without quotation marks) at the end of the file named '5K-56.lbl':"
"REDIRECT,5M0-035-1xx-56.CLB,5K0-035-190-B ; RCD510"
It might resolve itself with the next release.
Translated on 25-08-2026, 0:50.
Post06-05-2013, 18:42    Subject: Golf 6: RCD510 Coding Guide & Instructions Quote
I misspelled it, 5K-56.lbl.
I have that one.
Please add the following line (without quotation marks) at the end of the file "5K-56.lbl":
Completed.
Let's see when the neighbor has time again...
Sure, no problem!
Translated on 25-08-2026, 0:52.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock/code GRA Golf VII On-Board Diagnostics (OBD)
No new posts How to code US-style features in a Golf V? On-Board Diagnostics (OBD)
No new posts Golf VI 1.6TDI (CAYC) GRA codieren (oder auch nicht) On-Board Diagnostics (OBD)
No new posts Tausch RCD500 gegen RCD510 Transmission, Chassis, Body & Interior
