Completely disable consumer functionality
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
menzinger68
Post10-07-2013, 8:52    Subject: Completely disable consumer functionality Quote
I'm frustrated that the battery keeps draining because I often leave some devices turned on when I lock the car.
Is it possible to configure the vehicle's electrical system in my Audi B4 so that when the car is locked, all consumers, including the parking light, are completely turned off?
Thomas.
Audi A4 Avant, 2,5 TDI V6 , BJ 1999, Motor AFN
Getriebe DAJ DEY
Post10-07-2013, 9:33    Subject: Completely disable consumer functionality Quote
Audi A4 Avant, 2.5 TDI V6, manufactured in 1999
No, in that car, the lighting and other functions are not yet controlled by a central control unit (ECU). Therefore, when the corresponding switch is closed, the circuit is active.
Post10-07-2013, 11:37    Subject: Completely disable consumer functionality Quote
Is it possible to configure the on-board network of my Audi B4 so that when the car is locked, all consumers, including the parking light, are completely switched off?
That would not be legal. It's also not much use if you forget to icon_wink.gif.
Post10-07-2013, 11:39    Subject: Completely disable consumer functionality Quote
Possibly, an additional warning buzzer could be installed that beeps when the ignition is off and the lights are on. icon_idea.gif
DieselBär30x
Avatar-DieselBär30x
Post10-07-2013, 15:20    Subject: Completely disable consumer functionality Quote
Hello everyone!
A warning buzzer is installed and reliably goes off when the parking/boundary light is on, the ignition key is removed, AND the driver's door is open.
In the latter case, the door lock, or more specifically, its microswitch, is usually broken, and as a result, the horn will no longer work. icon_rolleyes.gif
Best regards from Munich!
No new posts AFN Ladedruck komplett weg Diesel Engine Technology
No new posts Replace Steering Rack: Why Not Just Replace It? Transmission, Chassis, Body & Interior
No new posts Bremsanlage entlüften bzw Bremsflüssigkeit komplett ers... Transmission, Chassis, Body & Interior
No new posts Audi CAGA: Engine Failure & Complete Breakdown Diesel Engine Technology
