Klausel Blaumann
17-05-2013, 21:44 Subject: VCDS: Diagnose crankshaft bolt loosening symptoms. |
I have an AFN engine in my Volkswagen Golf 3 (252,000 km).
Given that the issue of the gradually loosening crankshaft bolt is also known in AFN engines, I'm wondering if there are any symptoms that could be detected based on the injection timing rate (using parameter MWB 4) or in the TDI timing graph.
Thank you for the responses.
Best regards, Klaus.
G III, 1x0 PS, Mj.98, 333 tkm, AFN
Polo 6R, TSI 110 PS
Translated on 23-10-2026, 14:27.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
17-05-2013, 22:04 Subject: VCDS: Diagnose crankshaft bolt loosening symptoms. |
I think that if it becomes visible, you can also see it by observing a wobbling pulley/vibration damper.
Translated on 23-10-2026, 14:28.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
18-05-2013, 10:20 Subject: VCDS: Diagnose crankshaft bolt loosening symptoms. |
Yes, you can see that by looking at the fluctuating values in the TDI timing checker. However, as mentioned before, it would be easier to check the vibration damper/pulley, as you need to have a comparison to "before" via diagnostics, or you could check it every day.
Profile PM WWW Garage |
Herbert Profi-Schrauber
18-05-2013, 12:51 Subject: VCDS: Diagnose crankshaft bolt loosening symptoms. |
Hi there.
The emphasis is on "fluctuating" or "varying". Fluctuations of, for example, 50 +/- 2 for the value 2 in MWB 0 are normal.
If you suspect a problem, confidently grip the central screw with the wrench and turn it counterclockwise. Either it will loosen, or it won't.
Translated on 23-10-2026, 14:29.
vwSchrauber Profi-Schrauber
22-05-2013, 11:28 Subject: VCDS: Diagnose crankshaft bolt loosening symptoms. |
Quote: | | If you suspect a problem, confidently grip the central screw with the wrench and turn it counterclockwise. | Either it will loosen, or it won't.
If it's properly secured, it shouldn't open with a key or a 1/2" T-piece.
Translated on 23-10-2026, 14:30.
