1.6TDI DPF: Mystery Solved - Zero Ash Mass
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
Blackfrosch
Post27-05-2013, 0:00    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Hello everyone,
Here's a 1.6 TDI (see Autoscan) and I don't understand what the DPF is doing.
Approximately 80 km before the attached log, I had the DPF cleaning light illuminated and VCDS showed 25 grams of particulate mass. I then reduced it to 4 grams by running the engine at 200 km/h.
Following the instructions didn't achieve anything.
The engine was idling. I would like to know how "full" the DPF is.
Since the EGR valve needs to be replaced, the DPF (Diesel Particulate Filter) has to be removed anyway.
Is it normal for the particle mass to increase from 4g to 8g over a distance of 80km?
Once, I drove 40 km with a fuel consumption of 3.2 liters, and twice I drove 20 km with a fuel consumption of 4.5 liters.
Hi Blackfrosch,
Log-WVWZZZ6RZAY162581.txt
 AutoScan des Fahrzeuges
die beiden Fehler waren sporadisch, sind nicht wieder aufgetreten.
 File name:  Log-WVWZZZ6RZAY162581.txt
 File size:  7.46 KB
 Downloaded:  996 times
LOG-01-1001-1011-1171-1221-1241-1251-3931-3941-3961-4621-4631-4761.csv
 Alles was mir VCDS zum Partikelfilter ausspuckt. Andere nĂŒtzliche Werte gibts nicht.
Messwertblöck gibts beim 1.6TDI sowie so keine. **********************. Aktueller VW Datenstand ist auch schon drauf.
 File name:  LOG-01-1001-1011-1171-1221-1241-1251-3931-3941-3961-4621-4631-4761.csv
 File size:  3.99 KB
 Downloaded:  586 times
Translated on 23-09-2026, 23:03.
Karma: +1343 / -0   Thank you, like it!
Post27-05-2013, 5:39    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Please use more polite language. And please think carefully about what you write about whom.
Translated on 23-09-2026, 23:04.
Blackfrosch
Post27-05-2013, 8:25    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Okay, sorry, I didn't mean to attack anyone personally. But I'm a bit frustrated with the 1.6 TDI engine; it just causes problems. It's probably another case of cost-cutting measures.
Does anyone have any ideas on how to explain the 0.0 g/l ash/oil ash reading? Is it intentional, so that it can no longer be read out? Is it a fault in VCDS? Or is it (still) a software bug?
Best regards and thank you.
Translated on 23-09-2026, 23:05.
fuerni
2007 Audi A3
Post27-05-2013, 9:30    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
What do you mean by "burned out" on 4G?
As far as I know, you can only regenerate the loading status. However, this has nothing to do with the amount of ash. If the ash content exceeds a specific limit, the particulate filter needs to be replaced or cleaned.
Translated on 23-09-2026, 23:06.
Blackfrosch
Post27-05-2013, 9:43    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
On a 4g particle mass reading. The ash mass is always 0.0g on our 1.6 TDI. Neither software updates nor the VCDS Beta 12.10 have changed anything.
It also increases every 5 km at idle speed to allow for regeneration.
"Hello"
Translated on 23-09-2026, 23:07.
mullemaus
Post27-05-2013, 10:43    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Where and how was it checked? Were 'normal' measurement data blocks used, or those under the advanced settings?
Post27-05-2013, 11:14    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Since the EGR needs to be replaced, the DPF has to be removed anyway.
once 40km with a fuel consumption of 3.2 liters, and twice 20km with a fuel consumption of 4.5 liters.
If the DPF is going to be removed anyway due to an EGR replacement, I would force a regeneration immediately before removal and then clean it after removal to remove any existing ash.
It also increases every 5km at idle to regenerate.
Sure, does it regenerate, or is it just raising the idle speed for other reasons?
You should check the plausibility of all sensor data (temperatures, pressure differences, etc.) as much as possible.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 23-09-2026, 23:08.
Blackfrosch
Post27-05-2013, 11:50    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
mullemaus wrote:
Where and how was it checked? In the "normal" measurement data blocks or under the extended ones?
1.6 TDI Continental PCR2.1 - There are no standard diagnostic parameter groups available!
I guess I have to look under the "advanced" options.
Sure - does it regenerate, or does it increase the idle speed for other reasons?
Yes, I even charged the battery, but it's still doing it.
Forced regeneration no longer works on the 1.6 TDI engine. Replacing the AGR valve is only possible at a VW workshop due to the specialized tools required.
They probably won't clean the DPF anyway.
But to answer the original question:
Why is it showing 0.0g of ash mass? Does anyone have another good 1.6 engine that they could take a look at?
"Hello"
Translated on 23-09-2026, 23:11.
Post27-05-2013, 12:22    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
What is the mileage?
Translated on 23-09-2026, 23:12.
Blackfrosch
Post27-05-2013, 13:03    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
81,207 km
Post27-05-2013, 13:49    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Can you rule out the possibility that someone tampered with the system and set the ash mass to zero? Do you know the complete history of the vehicle?
Otherwise, there is apparently a rounding bug in VCDS regarding the ash content, which will only be fixed in one of the upcoming software versions and only in the beta.
I would consider a 4g speed increase of 80km to be completely normal.
Translated on 23-09-2026, 23:13.
Blackfrosch
Post27-05-2013, 15:55    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Yes, I know the vehicle's history; we are the first owners. It had two inspections done by VW, and then one at an independent garage. I checked it when it had 40,000 km, and it already showed 0.0g there.
12.10.5 Beta also also displays 0.0g.
I haven't yet found an adaptation channel for the ash mass.
"If a soot increase of 4g is considered normal, does that mean it regenerates every 400km with approximately 20g of soot? Is that correct? And if the soot level reaches 25g and the regeneration process constantly fails (resulting in limp mode), is that the cause?"
Sure, here's the translation:
"Hello"
Blackfrosch.
Translated on 23-09-2026, 23:14.
Post27-05-2013, 16:55    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Blackfrosch wrote:
12.10.5 Beta also shows 0.0g.
I also wrote "in a future data state" for the beta. Therefore, not yet in the current version!
If a soot increase of 4g is considered normal, then it regenerates every 400km with approximately 20g of soot? Is that correct? And if the soot reaches 25g, does the gas burner activate if the regeneration process is constantly interrupted? (AGR - limp mode)
My 2.0 CR does it roughly every 385 km. The interval only gets much longer if I drive a longer stretch of highway at speeds of 200+ km/h. But I haven't seen the warning light come on yet.
I only know the limits of the 2.0 version.
"At"
- 18g initiates active regeneration.
- At 24g, a regeneration trip is requested (DPF light is on).
- If 40g is reached, a service regeneration is requested (all three lights are on).
- 45g indicates a clogged DPF -> DPF replacement needed.
Translated on 23-09-2026, 23:17.
mullemaus
Post27-05-2013, 19:27    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
Was translated to English:
'Was the car's software updated or flashed? Sometimes, software updates reset certain values, which then appear as 0.'
Translated on 23-09-2026, 23:18.
Post27-05-2013, 21:38    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
They probably won't flush the DPF anyway.
It's not much trouble to flush it from back to front with the water hose, especially since the DPF is located nearby. If necessary, I would do it myself.
Who really knows how much ash is actually contained in it?
Translated on 23-09-2026, 23:19.
Blackfrosch
Post29-05-2013, 0:41    Subject: 1.6TDI DPF: Mystery Solved - Zero Ash Mass Quote
The vehicle has been flashed multiple times. However, the ash mass was already at 0.0g before the first software update. I can also say with 100% certainty that the particle mass is not lost. After an "update" without starting the engine, the value is the same as before.
I need to see if I can convince a VW workshop to either clean the DPF for me, or let me borrow it (if I have the time).
Hi Blackfrosch,
Translated on 23-09-2026, 23:20.
No new posts Rough running 1.6 TDI Cayenne, constant injector failure Diesel Engine Technology
No new posts Golf VI: CAYC Engine Coding (or Not) On-Board Diagnostics (OBD)
No new posts RĂ€tsel: Abregeldrehzahlen bei der AU Diesel Engine Technology
No new posts LLT Puzzle: Weather dependency? Diesel Engine Technology
