05-09-2013, 12:03 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
Hi.
While searching for information about action 26H7, I noticed that...
that the intake manifolds of the 177 hp TDIs (e.g., A6 2.0 TDI CGLC) apparently no longer have swirl flaps.
Is that correct?
Does anyone know the background story behind why these features were switchable, then adjustable, and then ultimately discontinued in the BMR (presumably referring to a specific system or technology)?
Translated on 27-09-2026, 21:08.
Profile PM Garage |
Jan6K
05-09-2013, 14:14 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
The CFHx also doesn't have it anymore. It was probably too expensive or prone to defects... and apparently, it works fine without it.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 27-09-2026, 21:09.
05-09-2013, 15:19 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
Cool.
Then I'll turn mine off too and see what happens  .
Profile PM Garage |
Jan6K
05-09-2013, 16:43 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
Most likely, the software will complain if it's monitoring that.
The CAYx system has similar flaps, but they were not controlled (at least initially). I have no idea whether they added that functionality later.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 27-09-2026, 21:10.
06-09-2013, 12:55 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
Jan6K wrote: | Hi,
Well, you shouldn't disconnect the solenoid valve, but rather the vacuum hose.
Jan6K wrote: |
The CAYx has similar flaps, but they were not controlled (at least initially). I have no idea whether they added that functionality later.
To the best of my knowledge, they are still dead.
Translated on 27-09-2026, 21:11.
Profile PM Garage |
08-09-2013, 11:03 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
The first test was pointless because the bike was in the regeneration phase and therefore felt quite unstable.
But that's one way to do it quickly.
text
such-Hint:
Swirl flaps OFF.
| Description: |
| BMR Motor mit Drallklappen OFF durch Tupperware Klip |
| File size: |
177.15 KB |
| Viewed: |
5947 times |
Translated on 27-09-2026, 21:12.
Profile PM Garage |
Jan6K
08-09-2013, 12:07 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
What are you actually trying to achieve with this?
Without software adjustments, this is likely to have more negative consequences.
Jan.
1Z5 CFHF  / AHB H4D
08-09-2013, 12:43 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
Jan6K wrote: |
Which one?
And why?
What was achieved by changing the injection start timing on the 1Z engine?
Negative: Emission values - As if I care.
Positive aspects: Consumption and airflow.
Absolutely positive for me as a driver.
If the throttle valves worked the same way, I would drive without them.
Or, if I operate it alone, and the wave doesn't erode the suction port due to the lack of activation, I've already won another 400 euros.
And besides, it's about  playing around with it.
Translated on 27-09-2026, 21:13.
Profile PM Garage |
Jan6K
08-09-2013, 14:20 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
The idea behind these things is that the air-fuel mixture is improved at low speeds through the creation of swirl. That's at least what they claim.
I have no idea what happens if you turn this off without the control system knowing about it... if the effect is really as described, then at least some kind of change must occur. Whether that change is disruptive is, of course, another question.
I completely understand the other arguments, especially those regarding durability and playfulness, and I'm curious to see if you can observe any effects.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 27-09-2026, 21:15.
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
08-09-2013, 19:27 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
The purpose of the swirl control is simply to achieve a slightly cleaner combustion process in the partial load range. The cross-sectional reduction in the swirl control causes the intake air to flow more forcefully and quickly into the combustion chamber, where it mixes better with the fuel.
In a test vehicle (Citroen Jumpy 2006 2.0hdi 16V, without DPF, yellow environmental sticker), we were unable to detect any difference in performance or the emitted, barely visible exhaust gases, whether operating in 8V or 16V mode.
The pop-off valve doesn't really care about any of that. But it might be a problem for the DPF. I don't think it's a good idea to disable the system on this particular vehicle.
reflexsilber met.
Translated on 27-09-2026, 21:16.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
08-09-2013, 20:41 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
I have simply removed these dirty things from many 6-cylinder BMWs, Mercedes, and Fiats because they kill the engine by breaking or loosening the flaps, which are then sucked into the engine!  There are no problems with or without the DPF, and neither does the MSTG complain, nor does the driver notice anything.  It is important to leave the solenoid valve electrically connected, otherwise the MSTG will complain.
Or, without these annoying things, you can't see anything from the outside, and they can be navigated normally.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 27-09-2026, 21:18.
Profile PM Email Garage |
chli1976 Profi-Schrauber
09-09-2013, 5:03 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
I've heard that BMWs are prone to breaking down.
Has this happened to anyone else with the 2.0 models (e.g., CAGA)? Should I also expand those?
I've already deactivated the swirl flaps via the software on the V6 engines, and I couldn't detect any difference.
VCDS
Translated on 27-09-2026, 21:19.
09-09-2013, 8:16 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
The current V6 engines have a central swirl valve and then a two-branch intake manifold.
In the 16V PPD systems, the adjustment shafts tend to leak.
I haven't read anything about problems related to the CR.
Translated on 27-09-2026, 21:20.
Profile PM Garage |
Jan6K
09-09-2013, 8:32 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
"But the newer CR models don't have them either... maybe too many of them broke down within the warranty period."
Then just get rid of that stuff  .
Jan.
1Z5 CFHF  / AHB H4D
09-09-2013, 8:43 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
Jan.
Do you really think that customer complaints and emission standards are in the same league?
There's nothing quite like adhering to completely arbitrary pollution limits.
I even bet that in energy management systems, lambda sensor heaters are deactivated only after airbags and ESP are deactivated, because they are considered "more important"!
If swirl flaps can somehow affect the emissions, it doesn't matter  whether they occasionally end up in the combustion chamber, because then the engine needs to be built to last more than the lifespan of a car - and the customer will pay for that, because it's designed to last a nice } 1462 (*) days.
(*) 4 years, one leap day, and then one extra day just to be sure.
Translated on 27-09-2026, 21:21.
Profile PM Garage |
Jan6K
09-09-2013, 9:35 Subject: TDI: Magnet. CR Engine, No Swirl Valves |
If that were the case, they would have kept them. Apparently, it works fine without them, so they're getting rid of them.
Reading this, I'm really glad I don't have that problem. And it's probably not so bad that the CFHF doesn't have a compensation wave module. It does drone a bit more between 1300 and 1400 Hz, but I'm sure I'll get used to it.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 27-09-2026, 21:23.
