Shock Absorbers & Washers
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post10-09-2013, 23:13    Subject: Shock Absorbers & Washers Quote
Hi.
Here's the translation:
"It's about a T3 model from 1989."
On the new Bilstein B4 shock absorbers, these dust covers were located on the piston rod.
However, on the one hand, this disc was too thick to be accommodated in the buffer, and on the other hand, the piston rod was already thicker than the old one (presumably an original VW part).
I had no other choice but to install the shock absorbers without those discs.
Is this a devilish creation, or is it simply the only way to do it?
Greetings.
 File size:  102.6 KB
 Viewed:  1097 times
 File size:  176.76 KB
 Viewed:  1500 times
Translated on 15-10-2026, 10:49.
Post11-09-2013, 0:29    Subject: Shock Absorbers & Washers Quote
The T3 has been manufactured for a very long time. Perhaps something was changed in the recording process at some point.
I assume you've already checked to see if it fits properly.
Possibly, you are now missing 10mm of suspension travel icon_wink.gif.
Have you checked to see if the spacer might be getting stuck under the fitting (nut), or if that would even make sense?
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 15-10-2026, 10:50.
Karma: +1344 / -0   Thank you, like it!
Post11-09-2013, 5:42    Subject: Shock Absorbers & Washers Quote
You need that disc (or bushing?), otherwise there won't be a counter-bearing for the piston connection at the top of the bearing. The piston will then come out from the top.
Ich wĂŒrde DĂ€mpfer, Scheiben, Buchsen, Puffer fahrzeugspezifisch (AKTE) im Satz kaufen. FĂŒr die DĂ€mpfer gibt es verschiedene AusfĂŒhrungen (SchlechtwegeausfĂŒhrung, aufgelastete Fahrzeuge,...). Es mu"It doesn't match."
Sure, here's the translation:
"Best regards," or "Sincerely,".
Translated on 15-10-2026, 10:51.
Post11-09-2013, 9:38    Subject: Shock Absorbers & Washers Quote
Herbert wrote:
You need the disc (= bushing?), otherwise the counter bearing for the piston connection at the top of the bearing will be missing. The piston will then come out from the top.
No, he doesn't.
A buffer (reference: additional spring) (with a protective tube at the bottom) is placed on the threaded part of the rod, and this buffer also contains a bushing. This bushing sits on the ledge of the piston.
And this combination (protective sleeve, buffer, and socket) fit perfectly onto the bare piston rod, BUT NOT when the Bilstein sleeve was on it.
According to the documents, there are only 2 shock absorbers.
BM: It's not 10mm, because the ferrule is like a cap, so it can only be a maximum of 5mm high.
 File size:  142.76 KB
 Viewed:  957 times
Translated on 15-10-2026, 10:52.
Post11-09-2013, 16:31    Subject: Shock Absorbers & Washers Quote
There are indeed different types of shock absorbers, as HerbÀrt mentions. The VW documentation likely only lists a few that are specifically matched to the vehicle's chassis number. Several shock absorbers are listed in the aftermarket parts catalogs! For example, I installed heavy-duty van shock absorbers, and it worked fine; that was about 10 years ago. The important thing is that the thread on top fits, as well as the bump stops.
What exactly is the problem, which I may not be recognizing, besides the thicker piston rod of the new damper?
Translated on 15-10-2026, 10:54.
Post11-09-2013, 19:48    Subject: Shock Absorbers & Washers Quote
The piston of the new damper appears thinner than the disc on the piston of the old damper. Without this disc, a smaller surface area on the bushing above it is loaded (does it perhaps have a slot?), and this could become a problem. This is all related to the vehicle's suspension system.
At the very least, the disc should be removable from the old damper; it's probably just stuck. Otherwise, you'll need to obtain a new one. A construction plan (RLF) would be helpful, as the spare parts diagrams are often misleading.
Translated on 15-10-2026, 10:55.
Post11-09-2013, 22:03    Subject: Shock Absorbers & Washers Quote
At the very least, the seal should come off the old damper; it's probably just stuck. Otherwise, you'll need to get a new one. A construction plan (RLF) would be helpful.
Do you mean the disc with the groove on the underside?
This only makes sense if there is a clamping ring/split ring (like on older starters) on the damper, which secures the disc.
If that were the case, he would need to contact Bilstein. Unfortunately, the photos/sketch don't show what's important.
Translated on 15-10-2026, 10:57.
No new posts Raise Vehicle with Gas Shock Absorbers? Transmission, Chassis, Body & Interior
No new posts Lowering a Golf IV T...just springs or also dampers (35mm)? Transmission, Chassis, Body & Interior
