Golf 3 Door Hinge: What to Replace? (Solved)
Go to page: 1, 2  Next
New Topic 🔒 Locked 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
bindpe
Karma: +5 / -2   Thank you, like it!
Post15-09-2013, 13:32    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Hello everyone,
"On my Golf III, the driver's side door always drops down a few millimeters when opened. According to the AKTE parts catalog, there are a total of 4 parts per door (2 separate hinge pieces). Do I need to replace all of them? Or is it only one half of the hinge that typically fails?"
THANK YOU.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 31-08-2026, 22:59.
Karma: +1338 / -0   Thank you, like it!
Post15-09-2013, 15:53    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
How does the door drop? Is there excessive play in the hinges, or is the door with the lock simply too deep for the locking bolt?
Translated on 31-08-2026, 23:00.
Post15-09-2013, 16:30    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
The parts on the door side (the ones with the hinge pin) need to be replaced.
First, check which hinge is affected and whether the set screws are properly tightened. These screws secure the hinge pins to the hinge half attached to the car body.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 31-08-2026, 23:01.
bindpe
Post15-09-2013, 18:19    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Hello.
"If the door is open, you can get it to lift quite a bit. Then you can see that the lower hinge is mostly the one that's loose."
The set screws are tight. If I unscrew them, will the hinge fall apart into two pieces?
"Are the parts on the door frames the same for the 4-door model, right? Could I get some from a scrapyard then? The rear ones are usually in pretty good condition."
THANK YOU.
Spritmonitor.de
Post15-09-2013, 18:39    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Could I get some from Schrotti, or what?
It's not worth it - they cost 15.- each when icon_lol.gif new.
Translated on 31-08-2026, 23:02.
bindpe
Post15-09-2013, 20:05    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Are they already painted, or at least primed?
Spritmonitor.de
Post15-09-2013, 23:12    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
It is known that the hinges, especially in cars frequently used by grandparents (OMAs & OPAs), tend to wear out quickly, particularly those used for holding the door while getting in and out. icon_wink.gif
It is usually delivered primed and can be easily painted with a spray can in the desired color. Before installation, it is a good idea to lubricate the hinges properly for a longer lifespan.
Translated on 31-08-2026, 23:03.
bindpe
Post16-09-2013, 11:06    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Okay, I've skipped over the part about grandma and grandpa for now. I've actually been driving like this for 9 years, but now it's gotten so bad that the TÜV (German technical inspection) is objecting to it.
How do I best do that? Should I unscrew the set screws and then be able to lower the door?
How can I disconnect the cable connection?
THANK YOU.
Spritmonitor.de
Translated on 31-08-2026, 23:04.
Post16-09-2013, 12:19    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
How do I do that best? Should I unscrew the set screws, and then will I be able to lower the door?
Actually, the door doesn't need to be installed for that.
First, replace the broken hinge.
Loosen the screw on the door, completely unscrew the set screw. An assistant holds the door firmly, replace the hinge, insert the set screw and tighten it properly, adjust the door alignment, and tighten the hinge.
The same applies to the upper hinge.
If necessary, adjustments may need to be made on the body to ensure the door is properly aligned, especially if it still sags. If the door is slightly too high when opening, it can be pressed down slightly in the rear area of the door frame. Ideally, the door should move slightly upwards when opening, as this allows the hinges to settle and prevents the door from sagging further due to its own weight.
Translated on 31-08-2026, 23:05.
bindpe
Post16-09-2013, 17:57    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Thank you for your help. I ordered the hinges today. They cost 25 euros for 2 pieces.
I will report back after the installation.
vg
Spritmonitor.de
Translated on 31-08-2026, 23:07.
bindpe
Post16-09-2013, 20:32    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Do I need this tool? "Hazet 2597 Quick-Release Bit Holder"
Spritmonitor.de
Post16-09-2013, 21:37    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Do I need this tool
A better option would be to use a Torx bit, but it can also be done with a suitable Torx bit and two sturdy, flat ring wrenches.
It's not a problem on the door side.
It becomes problematic if you need to detach the body side halves. The front screw of the lower hinge is partially covered by the fender.
Overall, you need a bit of improvisational talent.
Translated on 31-08-2026, 23:08.
bindpe
Post18-09-2013, 21:35    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Sure, here's the translation:
"Another question: Am I not allowed to paint the area where the door rests against the frame, specifically where the hinges are?"
THANK YOU.
Spritmonitor.de
Translated on 31-08-2026, 23:09.
Post18-09-2013, 22:01    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
No, you shouldn't do that, because the door might shift, or you might have to tighten the screws to their maximum load capacity.
A touch of color haze doesn't really hurt.
Then, apply some spray wax or spray lubricant around the edges of the hinge.
Okay, enough chatting --> now let's get to work icon_wink.gif.
bindpe
Post19-09-2013, 21:05    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
"Okay, enough talk --> let's get to work."
Yes, the Meister icon_wink.gif door hinges are already painted.
Thanks again for the tips.
Spritmonitor.de
Translated on 31-08-2026, 23:10.
bindpe
Post24-09-2013, 17:24    Subject: Golf 3 Door Hinge: What to Replace? (Solved) Quote
Thank you again for your help.
The replacement went smoothly. It turned out that only the lower outer part was damaged.
"vg"
This is a common abbreviation for "very good" in German. It is often used in online forums and chat rooms.
Peter.
Spritmonitor.de
Translated on 31-08-2026, 23:11.
No new posts Doku Audi 8P, TĂŒrscharnier Knarr-/KnackgerĂ€usche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Werkstattaktion 2D, GlĂŒhkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Audi 80 B4: Replacing Headlight Adjustment Motor Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 5 1.9TDI, 2004: Transmission fluid change GQQ / 0A4 ... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Leaky Golf 3 Radiator: Other Causes & Fixes Diesel Engine Technology
No new posts Door Lock, Microswitch, or Grounding Issue? Transmission, Chassis, Body & Interior
