Brake Problems: Saltwater & Air Channels in Winter?
Go to page: 1, 2  Next
Post17-12-2011, 22:02    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Hi.
I had an idea for my Passat 3C.
The 1.6-liter gasoline engine and the Bluemotion models do NOT have air ducts that cool the front brakes.
In the winter, cooling is more like showering with saltwater, so it's not very pleasant.
Da es im Winter aber auch kalt ist, ich nicht mit einem Wohnwagen oder ähnlichen Lasten rumfahre, nicht schnell fahre (wobei ein BM auch 200 schafft), also gar nicht so sehr die Kühlluft nötig ist, kam mir die Idee, zwei org. TeI want to buy something.
The BM has smooth wheel housings - On the 1.6 model, the channels are only "clipped" in place.
You can buy these earplugs... Spending 6 euros per side might be worth it to try and contain the saltwater.
Or what?
Translated on 31-08-2026, 0:32.
Karma: +1359 / -0   Thank you, like it!
Post17-12-2011, 22:49    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Doesn't the shower actually come from the water that's being swirled up by the wheel itself?
Translated on 31-08-2026, 0:33.
haithamina
Post18-12-2011, 10:18    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
I would use it during the period when salt is being spread. You probably only need this extra cooling during the summer, especially on long downhill stretches.
haithamina
Karma: +1102 / -0   Thank you, like it!
Post18-12-2011, 12:22    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
The fine spray of road moisture kicked up by the tires is enough to keep the wheels and brakes wet. The salt that settles there binds the moisture, ensuring that it remains there for a long time, allowing the salt to exert its corrosive effect.
It would be beneficial to regularly rinse away salt deposits, and to clean and re-lubricate the vulnerable sliding surfaces of brake calipers and pads at regular intervals with the appropriate lubricant. In my opinion, the rear axle brakes are more susceptible to damage from winter conditions than the front axle brakes due to their lower usage.
Translated on 31-08-2026, 0:34.
Post18-12-2011, 20:51    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Okay.
Then I also need a set of winter alloy wheels.
http://volkswagen-zubehoer.de/shop_media/images/product_images/popup_images/3C0071497A_8Z8.jpg
Thanks to the 5-spoke design, I can more easily access the brakes for cleaning.
Translated on 31-08-2026, 0:35.
Post18-12-2011, 21:14    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
...or steel rims with closed wheel covers. They let less spray through and perhaps also less of the salty brine. icon_wink.gif
Translated on 31-08-2026, 0:36.
BM
Avatar-BM
Post19-12-2011, 0:03    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Whether there's a little more or a little less gout, salt is still salt.
3B5 AJM
haithamina
Post19-12-2011, 3:59    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
BM wrote:
Whether it's a little more or a little less gout...
I mean: neither a little more nor a little less, but rather much less gout! icon_wink.gif
haithamina
Post19-12-2011, 7:25    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Gout? icon_eek.gif Absolutely not! icon_wink.gif Clean the sliding surfaces of saddles and coverings before winter, apply a thick layer of paste for preservation, and if they start to become difficult to move, clean them again and repeat the process.
Translated on 31-08-2026, 0:37.
Post19-12-2011, 8:33    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
The org. 3C caps are almost finished.
Post02-01-2012, 17:07    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Tomorrow, the lids will be tested with a "Munich and back" run icon_wink.gif.
 Radhausschale Passat 3C
 File size:  85.18 KB
 Viewed:  3760 times
Translated on 31-08-2026, 0:38.
haithamina
Post02-01-2012, 22:09    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
While not related to brake ventilation for the 3C model, here's information about the radiator grille cover for the 3BG model:
I'm going to test: a) Aerodynamic advantages, yes/no, similar to Bluemotion; b) Reduction of salt accumulation on the radiator and engine compartment; and c) Faster engine warm-up due to short trips, currently with the radiator fins blocked by a 35 mm heating pipe insulation (see T5 forum: Tuning, a different approach). a) is further enhanced by a grille closed off on the passenger side, next to the fog light (where the second SMIC is located in the V6 TDI, which I don't have).
"So far, there are no noticeable aerodynamic or fuel efficiency benefits, despite the fantastic reports in the T5 forum about advantages of -0.5 L/100 km. Even at the current ambient temperature of around 10°C and on long highway drives (140-160 km/h), my coolant temperature never exceeds 89°C and usually stays between 87-88°C (measured via OBD). Apparently, the ventilation of the radiator provided by the VW emblem and the grille below the license plate is sufficient. The operating temperature might be reached faster in freezing conditions, which will be tested under appropriate ambient temperatures."
Conclusion regarding brakes and ventilation: I don't think Martin's brakes will overheat!
haithamina
 Abdeckung Kühlergrill im 3BG
 File size:  150.5 KB
 Viewed:  928 times
Translated on 31-08-2026, 0:39.
Post02-01-2012, 22:14    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
It's too tight for me on the left side as well.
Back then, when the Bluemotion grid cost 7 EUR and not 24 EUR icon_wink.gif.
Does the transmission also not overheat?
Bad weather --- I'll just put those things in tomorrow morning icon_smile.gif.
Translated on 31-08-2026, 0:41.
haithamina
Post02-01-2012, 23:27    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Are you installing the infrared temperature measurement system for the brake discs at the same time?
haithamina
Translated on 31-08-2026, 0:42.
brezelmann01
Post24-01-2012, 18:44    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
Hi Martin!
Since my A3 8PA also experiences significant braking problems in wet or salty conditions, I would be very interested in the results of your experiment.
What surprises me is that shouldn't our ABS/ESP systems also integrate the "dry braking" function during wiper operation? How/where can I check for this function in the ESP control unit?
Dirk.
Post24-01-2012, 23:06    Subject: Brake Problems: Saltwater & Air Channels in Winter? Quote
So, all the 3C models have the brake disc wipers.
To verify, I would:
- Make it rain.
- to drive with the windshield wipers running.
- DO NOT brake.
- log the brake pressure.
-> He needs to go up periodically.
Unfortunately, it hadn't been salty at all for us yet - even the first, large tour with the "earplugs" was quite dry and rather fuel-consuming icon_twisted.gif.
Translated on 31-08-2026, 0:44.
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seal Trim Holes: Repair & Fix Guide Transmission, Chassis, Body & Interior
No new posts AGR Valve Stuck? Reasons & Solutions Diesel Engine Technology
No new posts Sooting behavior in winter Diesel Engine Technology
No new posts Winter Climatronics: Tips & Tricks Transmission, Chassis, Body & Interior
