Golf 5: Replace Brake Light Bulb
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1099 / -0   Thank you, like it!
Post14-02-2014, 10:28    Subject: Golf 5: Replace Brake Light Bulb Quote
Does anyone have a quick, step-by-step guide on how to replace the brake light bulb in a Golf 5 hatchback, and what type of bulb is required?
Translated on 19-09-2026, 4:42.
Post14-02-2014, 10:39    Subject: Golf 5: Replace Brake Light Bulb Quote
edit @AutoserviceViewing profile: Autoservice: Link removed. You know why...
Post14-02-2014, 10:45    Subject: Golf 5: Replace Brake Light Bulb Quote
It is blocked here. icon_wink.gif The P21W lamp type, the "Gockel" (a German term, likely referring to a specific source or system) already informed me about this. My question is whether I can help a very nice colleague during the remaining 10 minutes of her lunch break, or if I should let it be.
Translated on 19-09-2026, 4:43.
Post14-02-2014, 10:49    Subject: Golf 5: Replace Brake Light Bulb Quote
Oh, I see...
Ideally, you'll need a ratchet and a 10mm socket with an extension. Disconnect the connector, loosen two nuts, remove the taillight assembly, and clip out the lens from the taillight housing.
P21W BA15s for brake light/turn signal.
H6W Navigation Light.
Translated on 19-09-2026, 4:44.
Post14-02-2014, 10:50    Subject: Golf 5: Replace Brake Light Bulb Quote
Hutfahrer wrote:
I can either help a very nice colleague with something she needs during the remaining 10 minutes of her lunch break, or I can choose not to.
Ask her to come to your house... with the offer to then immediately check all the lamps for potential swaps.icon_wink.gif
Post14-02-2014, 11:00    Subject: Golf 5: Replace Brake Light Bulb Quote
...he's not allowed to do any repairs or modifications at home, otherwise he'll get a formal warning...
Translated on 19-09-2026, 4:45.
Post14-02-2014, 11:13    Subject: Golf 5: Replace Brake Light Bulb Quote
Is a 10mm wrench needed for the plastic nuts? Does the Golf not have a tool for that?
I don't have the H6W in stock, but I have the rest at home. I could give you a P21W from my own stock.
Post14-02-2014, 11:29    Subject: Golf 5: Replace Brake Light Bulb Quote
The mounting brackets are fastened with 10mm (metal) nuts, and the top nut is recessed quite deeply into the metal sheet. Without a socket wrench or ratchet, there's no way to loosen them.
The standard toolkit usually only includes a 10/13mm open-end wrench, if I recall correctly.
Translated on 19-09-2026, 4:46.
Post14-02-2014, 11:40    Subject: Golf 5: Replace Brake Light Bulb Quote
Okay, so it's not until Monday, and then I'll bring the "Ratschkasten" with me...
Post14-02-2014, 12:18    Subject: Golf 5: Replace Brake Light Bulb Quote
H6W Standlicht
I'm still wondering where the H6W model is supposed to be located.
The two half-rings are P21W... because I have them coded for both the reverse light AND the brake light, "Grill the guy behind you"... for an incredibly bright 84W brake light icon_twisted.gif.
EDIT: Or maybe not... I need to take a look.
Golf 5 hatchback
What is that?
You mean the "regular" Golf, not the Variant or the Jetta?
Okay, here's the translation:
"So, that one:"
 File size:  83.33 KB
 Viewed:  2741 times
 File size:  78.84 KB
 Viewed:  2748 times
Translated on 19-09-2026, 4:47.
Post14-02-2014, 13:18    Subject: Golf 5: Replace Brake Light Bulb Quote
I'll just have to see what's inside. The P21W label makes me feel uneasy; I've had enough of that.
Translated on 19-09-2026, 4:48.
Post15-02-2014, 9:46    Subject: Golf 5: Replace Brake Light Bulb Quote
Here's how it's done.
 File size:  101.67 KB
 Viewed:  2561 times
 File size:  94.21 KB
 Viewed:  2509 times
 File size:  91.53 KB
 Viewed:  6713 times
 File size:  56.05 KB
 Viewed:  2610 times
 File size:  58.94 KB
 Viewed:  2557 times
 File size:  82.92 KB
 Viewed:  2555 times
Translated on 19-09-2026, 4:49.
Post15-02-2014, 10:28    Subject: Golf 5: Replace Brake Light Bulb Quote
Unlike what is shown in the video, it actually appears here that there might be a provision for a wrench to be used on the upper nut.
Post15-02-2014, 10:39    Subject: Golf 5: Replace Brake Light Bulb Quote
Roger wrote:
Unlike what is shown in the video, it actually appears here that there is a provision for a wrench to be used on the upper nut.
Whew... I have no idea.
But a socket and a 1/4" extension are more fun anyway, because after a short loosening moment, it's just a matter of effortlessly turning the nut. And the nut is less likely to fall off inside the socket.
Oh yeah:
Disconnecting the electrical connection:
Pull the turquoise-colored latch backward, then unplug the connector.
It should almost engage "in one motion" when you place your thumb on the locking mechanism.
Translated on 19-09-2026, 4:50.
Post18-02-2014, 8:37    Subject: Golf 5: Replace Brake Light Bulb Quote
Thank you for your support! Yesterday, after work, we tackled it in the local parking garage. Flipping up the trunk liner worked as described. The stiff thing doesn't leave much space, but it was enough. The nuts used in the specific vehicle were made of hard plastic, long and cylindrical, so they weren't metal like the ones shown in a cap nut shape. After loosening these two nuts with a ratchet and a 14mm socket (without an extension - there wasn't enough space!), the entire taillight could be pushed out with some force. Disconnecting the connector (red slider on the connector, quite stiff) worked well from the outside. After that, the taillight could be completely removed. However, I couldn't disconnect the electrical connector from inside the trunk. I couldn't reach the release slider.
Removing the lamp holder from the light housing was no longer a problem after that. The outer lamp, a P21W, was completely black and defective. It was quickly replaced. Next to it is an H6W, which is responsible for illuminating the taillight in the inner half of the illuminated ring. It was already showing signs of silvering inside, but was still emitting light. It will likely need to be replaced soon. I wonder if a T4W with a BA9S base (with the approval of the bulb monitoring system) could be used as a replacement. The base is the same, and I have a large quantity of these lamps that don't fit in my vehicle. Everything was assembled quickly, and the bulb monitoring system extinguished the corresponding warning light after a short time.
That Golf is identifiable by the markings on the windows, indicating it was manufactured in the early summer of 2008. The rear window and rear side windows are marked with dates from June/July 2008. Therefore, it likely belongs to the last batch of its production series.
Translated on 19-09-2026, 4:53.
Post18-02-2014, 12:40    Subject: Golf 5: Replace Brake Light Bulb Quote
Thank you for the feedback icon_wink.gif.
Unlocking the plug (red slider on the plug, quite stiff) worked well from the outside.
For this, there is a release tool, a kind of T-handle with a flat hook, which can also be used for the other connectors.
Translated on 19-09-2026, 4:55.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace T4 Dual Mass Flywheel Diesel Engine Technology
No new posts Replace V6 Injectors: Guide & Parts Diesel Engine Technology
No new posts Replace battery? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Turbocharger Replacement: How to Replace It Diesel Engine Technology
