Hardware Suggestion: Small & Useful
Go to page: 1, 2  Next
Post06-09-2015, 14:23    Subject: Hardware Suggestion: Small & Useful Quote
Hello Rainer,
The LED on the VCDS interface is a great idea for estimating the area where the problem lies in case of communication issues.
When connected to a Polo 9N, it always blinks towards the driver. However, with the Ibiza 6L (which has a horizontally oriented OBD socket behind the small compartment), it points downwards. And while the Polo 6R has the OBD socket mounted diagonally downwards again, it's in the opposite direction, meaning the LED blinks at the driver's foot.
In the Rapid, the LED is mounted lengthwise, meaning it blinks to the right or left (I don't remember exactly which way).
Whether or not the LED is visible is therefore likely a matter of chance, depending on the orientation of the OBD sockets in the specific vehicle model.
My suggestion:
Incorporate more blinking LEDs into the interface so that the data dialogue is recognizable from all directions. Alternatively, distribute the light from the dual LED using transparent plastic parts/light guides to achieve a similar all-around visibility.
Translated on 16-10-2026, 13:12.
Post06-09-2015, 15:28    Subject: Hardware Suggestion: Small & Useful Quote
Thank you for the information. However, I still believe the likelihood of it happening is quite low.
Translated on 16-10-2026, 13:14.
Post07-09-2015, 6:50    Subject: Hardware Suggestion: Small & Useful Quote
Yes, it seems that the VCDS tools are selling well enough as they are.
But it would be a way to further increase acceptance of competing products. Skoda uses the advertising slogan "Simply clever" icon_cool.gif for such small things.
Karma: +1102 / -0   Thank you, like it!
Post07-09-2015, 7:23    Subject: Hardware Suggestion: Small & Useful Quote
If you don't want to change anything else about the layout, then a completely transparent enclosure might already achieve the desired effect. icon_wink.gif
Translated on 16-10-2026, 13:15.
dieselschrauber likes this.
Post07-09-2015, 7:28    Subject: Hardware Suggestion: Small & Useful Quote
I suspect that 80% of users don't understand the meaning of LED at all, 18% are not interested, and 2% would be happy about it. icon_lol.gif
The idea is nice, but it's actually not necessary at all. You don't necessarily have to constantly monitor the LED. Either the diagnosis works, in which case no one will look at it, or it doesn't work, in which case you can also just glance briefly under the dashboard. icon_wink.gif
Translated on 16-10-2026, 13:16.
Post07-09-2015, 8:31    Subject: Hardware Suggestion: Small & Useful Quote
TDI-GTI-4-Motion wrote:
Either the diagnosis is correct, in which case no one will look at it, or it's incorrect, in which case you might as well hang your foot in the footwell for a moment. icon_wink.gif
If you ever do that during a test drive, I'd like to see a video of it.icon_razz.gif
Post07-09-2015, 8:50    Subject: Hardware Suggestion: Small & Useful Quote
During a log transfer, you certainly don't need to do that, because if a log transfer even occurs, it seems that the connection has probably been established! icon_wink.gif
Translated on 16-10-2026, 13:17.
Post07-09-2015, 8:54    Subject: Hardware Suggestion: Small & Useful Quote
Then the connection was established successfully up to the beginning of the log. However, this doesn't guarantee that a connection will never be dropped – I've already experienced this with the Polo and the MED9.1 system, although it hasn't been reproducible so far.
Wiesel
dieselschrauber and TDI-GTI-4-Motion likes this.
Post09-09-2015, 9:12    Subject: Hardware Suggestion: Small & Useful Quote
Then, the LEDs will also indicate that the communication has stopped.
Advantage: You could immediately pull over to the right and restart.
Disadvantage: The device is still located near the left knee, which forces you to...
to avert one's gaze from the traffic.
Compromise suggestion: build an extension that allows you to position the interface so that THE LED is within your field of vision icon_wink.gif.
Translated on 16-10-2026, 13:18.
Post09-09-2015, 16:17    Subject: Hardware Suggestion: Small & Useful Quote
Or, we could make it even simpler, without even touching the hardware, and simply embed the "LED" in the software and display it somewhere on the screen. icon_wink.gif
Translated on 16-10-2026, 13:19.
Post09-09-2015, 19:25    Subject: Hardware Suggestion: Small & Useful Quote
Simply implant the "LED" into the software and display it somewhere on the screen. icon_wink.gif However, this would eliminate control of the on-board voltage supply. The real LED already lights up when you plug the interface into the OBD socket (even without the VCDS.exe running).
Translated on 16-10-2026, 13:20.
mullemaus
Post10-09-2015, 9:53    Subject: Hardware Suggestion: Small & Useful Quote
Or simply add an extension to it, then you can design the interface however you want icon_wink.gif.
Post10-09-2015, 10:56    Subject: Hardware Suggestion: Small & Useful Quote
Such an extension would be something for the diagnostics shop icon_cool.gif.
DieselBär30x
Avatar-DieselBär30x
Post10-09-2015, 11:45    Subject: Hardware Suggestion: Small & Useful Quote
Hello everyone!
Best regards from Munich!
PS: A pink Hello Kitty-themed interface would probably sell better icon_wink.gif.
Translated on 16-10-2026, 13:21.
Post10-09-2015, 14:00    Subject: Hardware Suggestion: Small & Useful Quote
DieselBär30x wrote:
P.S.: A pink Hello Kitty-designed interface would probably sell better. icon_wink.gif
Post10-09-2015, 15:11    Subject: Hardware Suggestion: Small & Useful Quote
.....or a TTS engine that says the words "the connection is interrupted" icon_cool.gif icon_rolleyes.gif.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 16-10-2026, 13:22.
No new posts Subaru Diagnostics: Using VCDS Hardware Troubleshooting & Guides
No new posts Ibiza Campervan Trip: Our Experience & Tips Diesel Engine Technology
No new posts SEO: German to English Translation Services Diesel Engine Technology
No new posts Expert Article Suggestion: [Topic] Diesel Engine Technology
No new posts Hardware for VAG-COM Diesel Engine Technology
