luiggi Schrauber
Joined: 02/19/2006 Posts: 392 Karma: +4 / -0 Location: Tirol /Zillertal
25-12-2013, 16:55 Subject: Particle filter emergency regeneration Audi FL 2009? |
I'm having another small issue with my particulate filter. The vehicle is a 2009 Audi 4F 2.7 TDI, which is the facelift model. The car is driving normally, and there's no warning light on. However, the error code in the diagnostic memory indicates "particulate filter overloaded, cannot be cleared" because it immediately reappears. The oil ash content is 0.35, which is within the acceptable range (the limit is 0.46 according to my VCDS). I was planning to start a service regeneration, as described in this forum, using login code 10016, and all the conditions seemed to be met. If I enter the code "11" in the "Encoding II - 11" field, I get the error message "11" is not allowed.
Can someone explain the forced regeneration process for the facelift model? Perhaps the description from the previous model doesn't apply here in this forum.
Thank you.
Translated on 05-07-2026, 5:03.
Joined: 04/12/2002 Posts: 18117 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
26-12-2013, 12:40 Subject: Particle filter emergency regeneration Audi FL 2009? |
You are confusing the amount of soot accumulated in the DPF with the ash content.
The forced regeneration process is working exactly as described for you.
The article describes when regeneration is still possible.
Okay, I'm ready. Please provide the German text you want me to translate.
Quote: | | Particulate filter loading state is below 68g. See measurement block 104, field 3. If the particulate filter loading is greater than 68g, the filter must be replaced, otherwise the filter could become too hot during regeneration and could catch fire! |
"Beladung" always refers to the amount of Russian material present in the filter. The biogas is burned periodically in a process called regeneration.
The ash will never decrease but will always accumulate, until the filter eventually needs to be removed, cleaned, or replaced.
Translated on 05-07-2026, 5:05.
Profile PM WWW Garage |
luiggi Schrauber
26-12-2013, 19:27 Subject: Particle filter emergency regeneration Audi FL 2009? |
I tried again today. The login isn't working for me. Specifically, with encoding II-11, it doesn't work. Then, with access permission 16, I was suggested the following code: 27971, and that was accepted. Unfortunately, I still couldn't start the regeneration. I opened all the MWB 100, 101, and 102, but nothing happened. At the very bottom left is the block "Basic settings visible," but for me, it remains bright and cannot be clicked.  Is this normal, or does the regeneration start immediately when all 3 main circuit breakers are opened?
Best regards.
Translated on 05-07-2026, 5:07.
26-12-2013, 20:05 Subject: Particle filter emergency regeneration Audi FL 2009? |
First, please perform an initial scan, then read the instructions again (check the prerequisites), and save the relevant measurements so that you can post them here later.
Translated on 05-07-2026, 5:08.
luiggi Schrauber
26-12-2013, 20:12 Subject: Particle filter emergency regeneration Audi FL 2009? |
Thursday, December 26, 2013, 16:33:12:17678
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: 12.12.0.0
Data as of: 20131128
Vehicle Identification Number: WAUZZZ4F19N018245 License Plate:
Mileage: 102990 km. Repair order:
Vehicle type: 4F (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 18 19 42 46 4F 52 53 55 56 5F
62 6D 72 76
Vehicle Identification Number: WAUZZZ4F19N018245 Mileage: 102,990 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
42-door electric. Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam angle adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
Rear hatch (6D) -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking Assist -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (CAN)
Label file: DRV\059-907-401-CAN.clb
Part number SW: 4F7 910 401 L, HW: 4F0 907 401 E.
Component: 2.7 TDI EDC17G000AG 0100.
Revision: 16H01--- Serial number:
Encoding: 010D002C191F0128
Operating number: WSC 61271 146 78252
VCID: 2C5305318F4E397E18B-8079
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\09L-927-760.lbl
Part number SW: 4F5 910 156 M, HW: 09L 927 156 C.
Part number: AG6 09L 2.7 TDI 140 0020.
Revision: --H04--- Serial Number: 4490824
Encoding: 0000002
Operating number: WSC 02325 785 00200
VCID: 326F1B49AD6A6F8E527-8067
Address 03: Brake Electronics Label file: DRV\4F0-910-517.lbl
Part number SW: 4F0 910 517 AL Hardware number: 4F0 614 517 BA
Component: ESP8 quattro H01 0060
Revision: 00000000 Serial number: 00000000000000
Encoding: 0020872
VCID: 6ED7CF3979D20B6E76F-803B
Address 05: Access/Startup. Label file: 4F0-910-852.clb
Part number SW: 4F0 910 852 B, HW: 4F0 905 852 D.
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial Number: 10602601221115
Encoding: 0000131
Operating number: WSC 02323 785 00200
VCID: 2545F015ECA40836C75-8070
Subsystem 1 - Part number: 4F0 910 132 E
Part number: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part number: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 08: Climate Control/Heating Module. Label file: 4F0-910-043.lbl
Part number SW: 4F0 910 043 B, HW: 4F1 820 043 AL.
Part number: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000000582144
Encoding: 0002326
VCID: 1D35D8F5C4F4C0F69F5-8048
Address 09: Central Electronics
Label file: DRV\4F0-910-279.lbl
Part number SW: 4F0 910 279 N, HW: 4F0 907 279.
Component: ILM Driver H22 0320
Revision: 00000000 Serial Number: 4F0907279
Encoding: 0033121
Operating number: WSC 02335 785 00200
VCID: 34631D51577E61BE40B-8061
Subsystem 1 - Part number: 4F1 910 113 D Label file: DRV\1KX-955-119.CLB
Part: Wiper blade, Audi C6, H10 0040.
Encoding: 00056595
Subsystem 2 - Part number: 8K0 910 557
Label file: DRV\8K0-955-559.CLB
Component: RAIN SENSORH04 0003
Encoding: 00146221
Address 0E: Media Player 1 (R41) Label file: DRV\4E0-910-111.lbl
Part number SW: 4E0 910 110 L, HW: 4E0 035 110 A.
Component: CDC-MP3-Pana H47 0050.
Revision: 00000011
VCID: 214DE405388CE416BBD-8074
Address 15: Airbag (J234) Label file: DRV\4F0-910-655-10.clb
Part number SW: 4F0 910 655 L, HW: 4F0 959 655 E.
Part number: Airbag AU1042 H06 0090.
Revision: -------- Serial Number: 003000000000
Encoding: 30314236303630303031554A304C34463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 306B11416B665D9E243-8065
Crash sensor for driver-side side airbag:
Serial number: 3574SRB400008258F2EE
Crash sensor for side airbag, passenger side:
Serial number: 3584SRB4000082291AC5
Rear side airbag crash sensor (driver's side):
Serial number: 35152RB402R7JI5AURRF
Crash sensor for rear side airbag, passenger side:
Serial number: 35252RB401V7EMTB7JUF
Crash sensor for front airbag, driver's side:
Serial number: 3554NRB4000047BB2E68
Crash sensor for front airbag, passenger side:
Serial number: 3564NRB4000047A8B251
Address 16: Steering wheel electronics Label file: DRV\4F0-910-549.lbl
Part number SW: 4F0 910 549 A, HW: 4F0 953 549 D.
Part: J0527 0410
Revision: 00H03000 Serial Number: 90055082810091
Encoding: 0002142
VCID: 2759FA1D96A81A26F59-8072
Subsystem 1 - Part number: XXXXXXXXXXX
Part: E0221 H02 0030
Address 17: Control panel module (J285)
Label file: DRV\4F0-920-xxx-17.clb
Part number SW: 4F0 920 933 A, HW: 4F0 920 933 A.
Component: COMBINATION INSTRUMENT. H08 0135
Revision: 00100000 Serial Number: AM202G81A
Encoding: 005F12050A000008000001
Operating number: WSC 61271 150 06295
VCID: 2545F0152CA40836C75-8070
Address 18: Auxiliary heater
Label file: None
Part number SW: 4F0 910 105 A, HW: 4F0 265 081 AA.
Component: Heater H08 0100
Revision: B Serial number: 09018641
Encoding: 0000111
Operating number: WSC 02145 785 00200
VCID: 1B31D6EDDAE0CEC6611-804E
Address 19: Diagnostic interface (J533)
Label file: 4F0-907-468.clb
Part number SW: 4F0 907 468 F. Hardware number: 4F0 907 468 F.
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial Number: 2100L08A15817A
Encoding: 000303
Operating number: WSC 02391 823 56573
VCID: 326F1B496D6A6F8E527-8067
Subsystem 1 - Part number SW: 8K0 915 181 C HW: 8K0 915 181 C
Part number: J367-BDM H07 0100.
Address 42: Door electronics. Driver (J386) Label file: 4F0-959-793.clb
Part number SW: 4F0 959 793 R, HW: 8K0 959 793 D.
Part number: TSG FA H11 0250.
Revision: Serial number: 0000100374792
Encoding: 011F02204040410001
VCID: 46875799F1E2E32EEEF-8013
Address 46: Comfort System
Label file: 4F0-910-289.lbl
Part number SW: 4F0 910 289 K, HW: 4F0 907 289 K.
Component: Comfort Device H27 0220.
Revision: 02200027 Serial Number: 01150832490000
Encoding: 3547889
Subsystem 1 - Part number: 1K0 951 605 C.
Part: LIN BACKUP HORN H03 1301
Subsystem 2 - Part number: 4F0 910 177.
Component: Interior monitoring H01 0020.
Address 4F: Central Electrics II Label file: DRV\4F0-910-280.lbl
Part number SW: 4F0 910 280, HW: 4F0 907 280 A.
Part: ILM Passenger Side H13 0100
Revision: Serial number: 00000000598905
Encoding: 0001113
VCID: DEB71FF909721BEE46F-808B
Address 52: Door opener (or electric door release). Front passenger seat. (J387) Label file: 4F0-959-792.clb
Part number SW: 4F0 959 792 R, HW: 8K0 959 792 D.
Part number: TSG BF H11 0250.
Revision: Serial number: 0000100368779
VCID: 45855095CCE4E836E75-8010
Address 53: Parking brake
Label file: DRV\4F0-910-801.clb
Part number SW: 4F0 910 801 D, HW: 4F0 907 801 B.
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Encoding: 0000521
VCID: 214DE405F88CE416BBD-8074
Address 55: Headlight range adjustment. Label file: DRV\4F0-910-357.lbl
Part number SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Encoding: 0000026
VCID: E9DD3C25C03C6C56A3D-80BC
Subsystem 1 - Part number: 4F0 941 329 D
Part: AFS module, left side, H01 0010.
Subsystem 2 - Part number: 4F0 941 329 D
Part: AFS module, right side. H01 0010.
Address 56: Radio (R) Label file: DRV\4F0-035-0xx-56.clb
Part number SW: 4F0 035 056 J, HW: 4F0 035 056.
Component: Radio U STD H44 0052.
Revision: AB001007 Serial number: 342J$087525369
Encoding: 010003020100000000
VCID: 2759FA1D56A81A26F59-8072
Address 5F: Information selection. I (J794) Label file: DRV\4E0-035-6xx-5F.clb
Part number SW: 4E0 035 666 D, Hardware number: 4E0 035 666.
Component: H-BN-EU H60 0143
Revision: -------- Serial Number: 345JU087530190
Encoding: 010100010002C3ED01000315EF6300030001
Operating number: WSC 61271 146 95860
Subsystem 1 - Part number: 8R0 060 884.
Part: EUROPE 2008 5505
Subsystem 2 - Part number SW: 4F0 919 604, HW: 4F0 919 604.
Component: DU7 High H43 0306
Subsystem 3 - Part number SW: 4F0 910 609 E, HW: 4F1 919 611 S.
Component: Control panel MM H01 0060.
Address 62: Door electric, high, left (J388)) Label file: 4F0-959-795.clb
Part number SW: 4F0 959 795 M, HW: 8K0 959 795 B.
Component: TSG HL H10 0251
Revision: Serial number: 0000100379232
Encoding: 010E00204040220001
VCID: 43814E8DC2D0D606C91-8016
Address 6D: Rear hatch
Label file: DRV\4L0-910-945.lbl
Part number SW: 4F9 910 591 HW: 4F9 827 851 G
Part: Valeo Rear Door H29 0410
Revision: --H29001 Serial Number: E5030000B
Operating number: WSC 98765 666 38354
VCID: ECD34531CFCE797ED8B-80B9
Subsystem 1 - Part number: 4F9 910 592.
Part: Valeo Rear Cover H29 0410
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD18.10.08--H29001001C0060.
Subsystem 4 - Serial number: 1C0060ÿ
Address 72: Door electric, upper right (J389) Label file: 4F0-959-795.clb
Part number: TSG HR H10 0251.
Revision: Serial number: 0000100390296
Address 76: Parking Assist
Label file: DRV\4Fx-910-283.lbl
Part number SW: 4F0 910 283 L, HW: 4F0 919 283 L.
Part: Parking Assist System, 4-Channel, H09 0210.
Revision: 00H09000 Serial Number: 52220828902778
Encoding: 0201016
Operating number: WSC 131071 1023 2097151
VCID: 2D550835B45430760F5-8078
End
Thursday, December 26, 2013, 16:29:04:17678
License Plate Number:
Address 01: Engine Control Module (4F7 910 401 L)
16:28:58 Block 100: Service restoration.
819 /min Motor speed (G28))
106.2°C Surface Temperature. Particulate filters.
0.0 (no unit)
0 Service regenerated. Status.
16:28:58 Block 101: Service regeneration.
00000000 Service regenerated. Release condition. 1
00000000 Service regeneration device. Release condition. 2
00000001 Service regenerated. Phase.
16:28:58 Block 102: Exhaust gas aftertreatment.
118.0°C - Temperature after the pre-catalyst.
106.2°C - Temperature after the particulate filter.
13 mbar. Differential pressure of the particulate filter.
0 mbar. Particle filter offset. Differential pressure.
Hopefully, you can find something useful in what I've recorded.
Best regards.
Translated on 05-07-2026, 5:40.
27-12-2013, 14:30 Subject: Particle filter emergency regeneration Audi FL 2009? |
It's likely that it will then work similarly to how it does with the 1.6/2.0 CR-TDIs. Please check the requirements listed there.
If the soot load is too high, the regeneration process will no longer work while the vehicle is stationary (due to the risk of the DPF overheating), and at even higher levels, it will also fail during driving.
Finding the root cause of why a situation deteriorated to the point where emergency measures were necessary is just as important as successfully implementing those measures.
Except for extreme short-distance traffic, there are essentially only defects or errors as possible causes.
Also, please provide the text you want me to translate from German to English. I will then provide only the translation, without any explanations.
Translated on 05-07-2026, 6:15.
luiggi Schrauber
27-12-2013, 15:47 Subject: Particle filter emergency regeneration Audi FL 2009? |
I will try that. I already replaced the differential pressure sensor as a precaution, and I will also check the temperature sensors. Should I be getting ambient temperature readings there when the engine is cold? My problem is really with very short distances, a maximum of about 15km.
At approximately what mileage does the regeneration process occur in a 2.7 TDI engine?
Thank you.
Translated on 05-07-2026, 6:16.
28-12-2013, 13:34 Subject: Particle filter emergency regeneration Audi FL 2009? |
They should be enough.
Yes, when the engine is cold, the temperature readings should be approximately the same. Please also check if the temperature readings are reasonably plausible when the engine is warm.
Translated on 05-07-2026, 6:17.
luiggi Schrauber
31-12-2013, 17:09 Subject: Particle filter emergency regeneration Audi FL 2009? |
Today, I analyzed the data from the MWB 099 temperature sensors after the vehicle had been stationary for about 2 hours, and the coolant temperature was 57 degrees Celsius.
15:13:12 Block 099: Exhaust gas temperature.
0 /min Motor speed (G28))
849.6°C Temperature before the exhaust turbocharger
5.9°C Temperature before the particulate filter.
224.2°C - Temperature after the particulate filter.
What do you think about the values? The sensor before the turbo is likely defective. I'm also not sure if the reading after the DPF is correct, as it's showing 224 degrees, while before the particulate filter, it's only measuring about 5.9 degrees.
Should I replace both of them, or just the one before the turbo?
As I said, there are no error messages (the "full load" message appeared repeatedly before, but it hasn't appeared for the last 2 days, so the error memory is now completely empty), but a DPF regeneration (forced regeneration) is not possible.
Translated on 05-07-2026, 6:19.
31-12-2013, 20:37 Subject: Particle filter emergency regeneration Audi FL 2009? |
luiggi wrote: | ...
224.2°C Temperature after the particulate filter... |
They are all perfect for the most important person. Since it's unlikely that all three are defective, I suspect there are cable problems, possibly due to damage from rodents or something similar.
Translated on 05-07-2026, 6:21.
31-12-2013, 23:38 Subject: Particle filter emergency regeneration Audi FL 2009? |
I would definitely recommend checking the values again after a longer period of inactivity (at least 12 hours).
After 2 hours, there is still residual radiant heat everywhere, which doesn't tell us much. Sure, the value before the turbocharger is definitely implausible, no question about it. MfG. Michael
Translated on 05-07-2026, 6:22.
Profile PM Garage |
luiggi Schrauber
01-01-2014, 15:21 Subject: Particle filter emergency regeneration Audi FL 2009? |
This morning (so, with the vehicle completely cool) and with an outside temperature of 1 degree Celsius, I read the following values again when the ignition was turned on, without the engine running:
11:49:26 Block 099: Exhaust gas temperature.
Temperature before the exhaust turbocharger: 849.6°C.
-17.7°C Temperature before the particulate filter.
"After I started the engine, only the middle value (temperature before the DPF) immediately increased, while the other two remained unchanged. Is it really possible that both sensors are defective, or is it more likely a weasel bite? I haven't had time to get it on a lift for a visual inspection of the cables yet. Unfortunately, my vehicle is not yet listed on Erwin's website. Does anyone happen to have a wiring diagram for the DPF and its sensors?" Engine is CANC.
Best regards.
Translated on 05-07-2026, 6:24.
Herbert Profi-Schrauber
01-01-2014, 23:37 Subject: Particle filter emergency regeneration Audi FL 2009? |
Hi Luiggi,
Check the Irrwinn catalog under A6, models 2005-2007, RLF (Rear-wheel drive), power transmission, 6-cylinder TDI Common Rail, 2.7L and 3.0L engines. The CANC (likely referring to a specific component) is located there. If you click on the MKB codes, all of them will become visible.
Happy New Year!
Herbert. Horch A4 8K CJCD
Translated on 05-07-2026, 6:25.
