TDI No Power After Start - Troubleshooting
smoere
Post28-04-2003, 8:42    Subject: TDI No Power After Start - Troubleshooting Quote
hello everyone,
This is a cry for help!
I've been struggling with a problem for two years now, and no one has been able to help me so far.
After starting, my TDI (1Z, 90 hp) has no power (it feels like it's in limp mode, but the error light doesn't come on). It only starts running normally after I rev it once to around 3200 rpm (whether it's at idle or under load). Then, as soon as I turn it off and restart it, the problem starts again.
'The only error message is: 'implausible signal from mass airflow sensor (intermittent)'. The mass airflow sensor has already been replaced, as has the EGR valve. The voltage at the mass airflow sensor is fine, and the resistance at the EGR valve is also within the acceptable range. The engine control unit has been temporarily replaced, but that didn't solve the problem either.'
Can someone help me?
Thank you very much for your support.
Best regards from Smøre.
Translated on 27-08-2026, 3:48.
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger/Compressor System No Power - P2263 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 TDI: No Power After Head Replacement / Starting Issues Diesel Engine Technology
No new posts No power after removing the EGR valve on an AFN TDI Diesel Engine Technology
No new posts AXE Performance Issues After PD Migration Diesel Engine Technology
No new posts Audi C4 AAT: No Power After 3 Months Idle Diesel Engine Technology
