A4 B6 2.5 TDI: Running Rough - Troubleshooting
MrMcFly79
Post30-04-2020, 22:39    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
Hello everyone,
The car had been parked in the yard for a quarter of a year due to accident damage. I've now started the repairs. The entire front end needs to be replaced, including the crossmember, radiator, etc. During disassembly, I noticed that the "indicators" (I'm not sure what else to call them) on the tensioner pulley for the pump's drive belt were not aligned. I loosened the nut on the tensioner pulley and realigned the "indicators" using a hexagonal wrench, then tightened the nut.
Okay, I started the car, and it's running quite unevenly and also smoking a bit when I accelerate.
After loosening the tensioner, it relaxed, and the indicator needles moved far apart, making the belt quite loose. However, I can hardly imagine that it jumped off. Now, the belt is actually properly tensioned.
Then I wanted to check the injection timing, and I discovered that the crankshaft position sensor is likely defective (it's shorted to ground, so the injection timing isn't being displayed -_-.
I disconnected the hub, but there's no change. Could it be a problem with the hub itself? I've driven before with the hub disconnected, and it worked normally then. It seems like it's relatively unimportant whether the hub is connected or not, especially on the 2.5 models...
Translated on 22-09-2026, 11:41.
MrMcFly79
Post01-05-2020, 12:08    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
Let's assume the belt has jumped a tooth; wouldn't that shift the injection timing so drastically that the engine wouldn't even start?
Translated on 22-09-2026, 11:43.
Karma: +1343 / -0   Thank you, like it!
Post01-05-2020, 17:03    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
The fuel injection system of the BAU engine only functions with the signal from the needle lift sensor.
Whether there is a short circuit to the positive terminal or not, the motor runs in emergency mode.
Translated on 22-09-2026, 11:44.
MrMcFly79
Post01-05-2020, 18:11    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
Oh, I'm so silly, it's a BDH. As I mentioned, it worked without any problems when the hub adapter was connected.
Post01-05-2020, 18:29    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
The fuel injection system of the BDH engine works the same way as the BAU engine.
Translated on 22-09-2026, 11:45.
Post02-05-2020, 16:26    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
When was the last time the engine ran smoothly?
Is it possible to identify which cylinder is not firing?
MrMcFly79
Post03-05-2020, 20:59    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
That was before the accident. I checked it again today. I let it run for 20 minutes, and it was better afterward. Let's see how it runs when it's roadworthy again.
Post05-05-2020, 19:19    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
When I hear about a type of engine, I immediately think of the camshafts... icon_cool.gif
Translated on 22-09-2026, 11:46.
MrMcFly79
Post05-05-2020, 21:41    Subject: A4 B6 2.5 TDI: Running Rough - Troubleshooting Quote
They look very good, at least they did six months ago when I replaced the nozzles icon_wink.gif.
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Not Running Smoothly? Troubleshooting Guide Diesel Engine Technology
No new posts 1.9 TDI (AWX) Audi A4 runs roughly when idling. Diesel Engine Technology
No new posts 1.4 TDI engine idling roughly Diesel Engine Technology
No new posts BMR unrund nach PPD Wechsel Diesel Engine Technology
